could someone help me get rid of the supervisor password on this?? I've tried with autopatcher and some other things from forum but no luck, is e595 20NF thankyouuouou 💖
					LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
 Thanks.
 Done everything in the correct order. After the patch i flashed the original bios and i was able to access the setup without password. Then i shut the machine off. I connected an empty ssd and when immediately the bios password came back...
 Any ideas? I will do it again one more time.Comment
 Hello.
 I did the patching, put it on the laptop, turned it on, went through the steps. so far everything is fine.
 I restored the original bios. and now it doesn't do anything except for one led blink.
 If I unsolder the bios chip, it still does the same thing.
 Laptop is T470
 Help please!
 Hi.
 I have a E490 Device. The DXE Driver shows me 458478389 as Hardware-ID.
 Can anyone generate the Key for me?
 ThanksComment
 I could do it. A 33 ohm resistor came downHello.
 Laptop is T470
 Help please!Comment
 hi i have one lenovo t480 intel 8th gen with computrace ,i tried autopatcher but is stuck in entering setup endesly,any hel will be appreciated
 t480
 type 20l5-0018us
 sn pf-1s3ylg 1907
 Attached FilesComment
 try .. giving me feedback makes me happy to help moreAttached FilesComment
 If you use the AUTO-PATCHER offered here, you don't need a hardware ID.
 This point is simply skipped with enter.
 STEP 5: Press enter when it shows Hardware IDComment
 Thank you for responce.
 Before I found this forum, I bought a so-called "password unlock chip" and soldered it to the board.
 Now the notebook tells me something about wrong UEFI variables, shows me the hardware ID and expects a key.
 I also don't know what happens if I just press Enter. I don't want the whole thing to become worthless.
 Hello, you've caught quite a bit of fraud, the chip is worthless. After patching, you have to reinstall the original BIOS of the notebook. (which you don't have) I would read the original BIOS chip three times and compare the contents to see if everything matches. Patch the original BIOS with the autopatcher and then restore the original BIOS. Forget about the chewed chip.Comment
 When Supervisor Password is DISABLED and you just want to De-Activate Computrace, you must first set the Supervisor Password and then (read)-patch-program the patched BIOS file and perform the unlock procedure which will reset the known Supervisor Password and de-activate Absolute Computrace. To finish just program the Original BIOS.Comment
 lenovo t470s
 hi can someone help me. i need patch me please! Thanks!Attached FilesComment
			by macabookHello everyone,
 🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
							Channel: BIOS Requests ONLY!
 07-24-2025, 02:17 PM
			by piratiHello everyone,
 I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
			by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
 Operating system and OS version.If...-
			by jbonavitaHi, my laptop wont boot at all
 Some issues
 Things I tried
 1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
