LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
https://www.badcaps.net/donate -
Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
@Alejandro3816
Did you checked that the MD5 of each file all match? You may also use WinRAR and put all 3 dump files in a RAR compressed file, then open the RAR file and check that the CRC32 column (far right) values of all 3 files match.
Once you have a verified "good" BIOS backup you just invalidate "SaDataBase" variable and save as a new file, just as I did:
DO NOT USE my file until you are sure you have a good BIOS backup.Attached FilesComment
@Alejandro3816
DO NOT USE my file until you are sure you have a good BIOS backup.Comment
Lenovo X390 8th need unlock please i try with lenovo patcher it give black screen and give beepsAttached FilesComment
.Comment
hello there my bios is beeps continuesly then some music and blank screen
my laptop lenovo thinkpad t490 i5 10th generation here is both my files Orignal and Patched
https://www.drop********************...******63g&dl=0
anyone have this fix?
serial number pf-29ca45
type number 20rx-s14700
20/5
compliance id tp00103a
nm-b902
rev 1.0
ft490/ft492
ft590/fp531
d2001
hsb
is there any fixes?Last edited by SMDFlea; 10-29-2023, 03:54 AM.Comment
https://www***********************os063g&dl=0
Attach files directly to your post instead of linking to external websites
.Last edited by SMDFlea; 10-29-2023, 03:56 AM.Comment
Hello new guy here
Can someone verify my bios read?
Lenovo x1 yoga gen1Comment
i did it thanks for help laptop unlocked
after clear bios password i fix the serial with lenovo-u1-tool-master
Lenovo utility not working
Steps :
Extract n1ctm04w.zip and run usbfmtpw.exe
Format the USB Drive
Disconnect the USB Drive
Extract u1u.zip (password for the zip is LenovoUone) and run u1.exe
Reconnect the USB drive and hit run.
Once the USB is created boot the USB Key and follow on screen instructions.
UPDATE (30/07/2021) [Try this if above method fails.]
I have Included a ZIP file containing all the script that Lenovo Uone tool uses to make the process simpler.Comment
my dosent works... give me a sounded beep
can i help?Attached FilesComment
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
