LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
  • HaiPa
    • Oct 2021
    • 42
    • United Kingdom
    #1181
    Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Originally posted by hoaca388
    I tried as you instructed but the CMD window just appeared and then disappeared quickly. Nothing happens next. I'm running Windows 10 64 bit, python 3.8.5. Lenovo Auto patcher 0.2
    Same for me, tried it in the past, was working like a charm, tried it today but the window just disappears so can't drag the bios file to be patched.
    If anyone has 10 sec to patch my bios I would be very grateful.
    • feherhollo
      • Nov 2019
      • 110
      • Hungary
      #1182
      This unlock method only works till 8th gen laptops or can be used on newer models as well? Like T490, T490s, T14 Gen1, T14 Gen 2
      • HaiPa
        • Oct 2021
        • 42
        • United Kingdom
        #1183
        Managed to get it now, you have to go on to the lenovo_autopatcher folder/patch copy your bios in to that folder ( always have 2/3 copies of it ) and drag the bios file abobe the autopatch phyton file.
        • hoaca388
          Badcaps
          • Jan 2022
          • 11647
          #1184
          Thanks for your help, this way is work well.
          • HaiPa
            • Oct 2021
            • 42
            • United Kingdom
            #1185
            Thanks for your help, but this also doesn't work.
            post your bios and I will do it for you if you are quick as I have something to do in a short while
            • hoaca388
              Badcaps
              • Jan 2022
              • 11647
              #1186
              Try
              • hoaca388
                Badcaps
                • Jan 2022
                • 11647
                #1187
                Thank you for your way. It worked well.
                • HaiPa
                  • Oct 2021
                  • 42
                  • United Kingdom
                  #1188
                  done with mine, is already in windows, installing updates , have to update bios as I get slow charge with the old bios that is got
                  • mrawzin
                    • Dec 2013
                    • tunisia
                    #1189
                    plz can any one help to unlock my bios
                    lenovo T490S i mtrying with lenovo autopatcher 0.2 without succes(biping blackscreen)
                    thx in advance
                    • Vesko356
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      #1190
                      thx in advance
                      https://www.badcaps.net/forum/showth...90S#post999840
                      Become a Badcaps supporter
                      Thanks to all supporters.
                      • meta99
                        • Sep 2021
                        • 27
                        • Vietnam
                        #1191
                        Thinkpad E560 with computrace activateed but without password bios
                        I try this autopatch but I can not get into bios with patched bios
                        Any one can help to remove computrace
                        Dump bios attached
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          #1192
                          Dump bios attached
                          For Computrace removal you will need to enable bios password first, and then try with the patch.
                          • darrkoo
                            • Feb 2015
                            • 44
                            • Poland
                            #1193
                            patch me please this dump T580
                            • Vesko356
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              #1194
                              • Karaman99
                                • Oct 2021
                                • Bulgaria
                                #1195
                                Hi everyone.Can someone tell me the real size of the bios dump from X1 Yoga 4th gen.I'm using ch341a programmer and when i'm reading the dump it gives me 1mb.And the second question is,is it possible to unlock that laptop with this method?Thanks.
                                • alfatech
                                  • Dec 2021
                                  • 7
                                  • canada
                                  #1196
                                  I have a lenovo t480s , i took a backup of the bios using ch341a and sop8 clip. Then i used the patcher to patch the bios. It turned on after flashing the patched bios. Up until when it says power off the laptop.
                                  After i flashed the original bios and the laptop has not turned back on since, no sounds , no lights except the charging light when charger is connected
                                  • alfatech
                                    • Dec 2021
                                    • 7
                                    • canada
                                    #1197
                                    look on the board sometimes laptops have 2 chips instead of one. not sure about yoga but i unlocked x1 carbon 6th gen successsfully
                                    • shochu
                                      • Nov 2021
                                      • 5
                                      • Finland
                                      #1198
                                      Hi!
                                      Please help me unlock the bios password.
                                      Br, Tommi
                                      • prspr
                                        • Jan 2022
                                        • Lithuania
                                        #1199
                                        Can anyone help with patching t470s BIOS bin?
                                        I have tried the autopatcher, but computer does not post with BIOS patched with autopatcher.
                                        Any help would be appreciated, thank you.
                                        • Saile2752
                                          • Dec 2021
                                          • 5
                                          • France
                                          #1200
                                          Hi, I have same issue for a Thinkpad X1 Yoga 3rd gen.
                                          Size of the bios was 16MB
                                          Laptop produced a 2 X 5 Bips sound, then nothing !
                                          only charging light .
                                          After, even if i update again the bios with patched one or the original one, nothing is produced by the laptop...
                                          Bios ship is W25Q128JVSQ.
                                          i used W25Q128JV and the CH431 for the update. i downloaded the programe in the forum and patched the bios.
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • Bloodhoundje
                                            HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                                            by Bloodhoundje
                                            I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                                            I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                                            After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                                            I have desoldered the bios chip (GigaDevice...
                                            03-16-2024, 03:12 PM
