LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
  • alext28
    • May 2020
    • 47
    Re: T480 superviser password remove
    Originally posted by andrew25
    can someone help me to patch this bios dump for T480, python on my pc not working
    try this
    • Markus1741
      • Sep 2020
      • 842
      • N/A
      #262
      Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
      It works on a Lenovo T450s Great job thanks a lot
      • Markus1741
        • Sep 2020
        • 842
        • N/A
        #263
        I had some problems with the Python script on Linux Ubuntu. For everyone who also gets an error message in Linux helps.
        chmod +x ~/Downloads/lenovo_autopatcher_0.2/lenovo_autopatcher/tools/UEFIReplace
        • pakastin
          • Mar 2020
          • Finland
          #264
          Works perfectly on T480s, thanks!
          • equalrock
            • Nov 2020
            • 3
            • Netherlands
            #265
            Originally posted by palembang
            hi i got this, i don't know what next
            I had the same issue, I used the normal commander. Just type CMD in the address bar in the python folder. Put the autopatcher and the original bios file also in this folder.
            • JOHNLAG7
              • Nov 2014
              • 19
              • Greece
              #266
              Hi can anyone help with this 7th gen type QE i patched it with autopatcher but no luck i take many beeps and black screen when i flash the original back works.
              I have unlock 6th gen previews with autopatcher i use svod3 programer and CH341A.
              SPI is 25q256jv
              • Linux200
                • Sep 2020
                • 12
                • Algeria
                #267
                HI
                Is this autopatcher compatible with ideapad 320 cause i can't patch bios dumped
                thank's in advance
                • Linux200
                  • Sep 2020
                  • 12
                  • Algeria
                  #268
                  Originally posted by Linux200
                  HI
                  thank's in advance
                  if someone can help me thank's in advance
                  • AAAC
                    • Jan 2020
                    • 457
                    • Mexico
                    #269
                    @Linux200
                    Ideapad 320 is not a ThinkPad, so that's probably why the autopatcher didn't work.
                    Try this for password:
                    ecppyong
                    • leva2407
                      • Jul 2016
                      • 89
                      • tbilisi
                      #270
                      • data tutashxia
                        • Nov 2020
                        • moscow
                        #271
                        pleas, unlock lenovo T431S. Thank you
                        • lapfix
                          • Mar 2020
                          • 2552
                          • my workshop
                          #272
                          What s the picture that appear ! the little one !
                          • danito
                            • Jun 2016
                            • 842
                            • Romania
                            #273
                            can you help me with removing spv psw for lenovo twist s230u?
                            is there a problem with me with the error in the picture?
                            thx
                            • Sainted
                              • Oct 2020
                              • United Kingdom
                              #274
                              Right, more help needed from more knowledgeable members of the forum.
                              T450 with a supervisor password. I follow the guidelines, erase the chip, apply the patched BIOS, remove the hard drive, power on the PC, and nothing. The power button remains illuminated, fan spins for the first 2-3 seconds, then stops. Nothing on the screen, no beeps or sounds. Hitting F1 yields no results.
                              I have tried CH341 own software, ASProgrammer and Colibri, BIOS file has been verified with no issues, which should rule out corruption when writing.
                              I have so far successfully patched two T440p using the same procedure, no issues at all.
                              Does anyone have any suggestions?
                              • Ghamidi
                                • Mar 2020
                                • 303
                                • France
                                #275
                                thx
                                search second eprom 8mo W25Q64FV U5 AND PS2408
                                • danito
                                  • Jun 2016
                                  • 842
                                  • Romania
                                  #276
                                  ok
                                  I found the U5 bios chip, only it's a CFEON, but I didn't find the PS2408.
                                  also with error when applying the path
                                  • Ghamidi
                                    • Mar 2020
                                    • 303
                                    • France
                                    #277
                                    ok
                                    i found the u5 bios chip, only it's a cfeon, but i didn't find the ps2408.
                                    Also with error when applying the path
                                    p24s08 location
                                    • danito
                                      • Jun 2016
                                      • 842
                                      • Romania
                                      #278
                                      [QUOTE=Ghamidi;1004461]p24s08 location[/QUOTE
                                      I'll watch tomorrow. and after what do i have to do?
                                      • Ghamidi
                                        • Mar 2020
                                        • 303
                                        • France
                                        #279
                                        [QUOTE=danito;1004477]
                                        you read this eprom
                                        if u have programmer RT809F OR H the method of read this eprom in picture
                                        • danito
                                          • Jun 2016
                                          • 842
                                          • Romania
                                          #280
                                          [QUOTE=Ghamidi;1004480]
                                          you read this eprom
                                          and that goes into the autopather?
