 Hello Maxpower3, no problem. Your help is always very valuable.Comment
 Can it be the same problem with my P50? See above. It doesn't have a picture with any of the patched files, only with the original bin. I tried everything, asked for help but I'm out of ideas.Comment
 which programmer and which software
 Ch341 ??
 if you can't, try EC bypass
 https://www.badcaps.net/forum/troubl...-ec-pwd-bypassLast edited by Maxpower3; 10-05-2025, 08:13 AM.Comment
 Revelprog with its original software.
 Ch341 ??
 I didn't know there were LPC lines here that I could use to get into the BIOS. I used that method several times in the past. I will give it a try here as well.Comment
 I had to try a few times, but I was able to get into the BIOS with this method, and now the P50 board is finally supervisor password free. Thank you for all of your help! I wanted to leave a comment about the success for future visitors.
 Ch341 ??
 https://www.badcaps.net/forum/troubl...-ec-pwd-bypassComment
 thanks very much,its workingComment
 Hi, just wondering if you could share those pics again? I'm looking to fix my p50. I've already found one chip that could be the bios chip, close to the RAM, at position u5, but I'm not sure if it's the correct chip.Comment
 Can't seem to find an Edit button, so I guess I'll go like this.
 I just went for it, and it worked out. PW is removed, U5 is indeed the BIOS chip.
 Thanks  Comment
 "Is there a way to use a single master BIOS dump to unlock the Lenovo E595 Type 20NF with an AMD processor? I have around 10 units and it would simplify my work. I saw such a solution for the E495 model. Thank You for any helpComment
 Are you using the original BIOS of your laptop....Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
 Every donation made will go towards server fees and maintenance costs.Comment
 Yes, it is the original BIOS, but not the same version that the laptop was shipped with. The current BIOS installed on the laptop is the latest one, version 1.80. The laptop was shipped with BIOS version 1.50 tho.Comment
 hi everyone,help me remove Supervisor Password
 lenovo P1 type 20TH-003KUS
 code main:19770-1Attached FilesComment
 Hi, can anybody tell me if i can unlock with this method lenovo x1 extreme 2th gen ? Type number: 20qw-s1hu15. I tried patching bios but when the laptop powers on with a modified bios, there is no luck entering bios.Comment
 I've seen a few users reporting problems about "cmd closing imediatly after open the autopatcher". For those who are having this trouble, just try an older version of Python. I had the same trouble, but I fix it using the 3.13v. Glad if helps a little  Comment
			by macabookHello everyone,
							Channel: BIOS Requests ONLY!
 07-24-2025, 02:17 PM
			by piratiHello everyone,
			by jbonavitaHi, my laptop wont boot at all
 Some issues
 Things I tried
 1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
