i have a thinkpad l480 after the patching only stay in entering setup some one can helpme
 Post the laptop serial number - https://www.badcaps.net/forum/troubl...before-posting .Flash back your backup and see if it bootsComment
 I need remove the supervisor password for Lenovo P16s Gen 2 AMD RYZEN 5,
 Motherrboard model
 KT4D2/KP4D5/KT6D2/KP6D5 Nm-f261 Rev 1.0
 Serial Number PF-5A8EOL
 Type Number 21K9-0034USAttached FilesComment
 Can someone help me with lenovo T450 patcher
 SN PC-07QL93Attached FilesComment
 patched fileAttached FilesComment
 Can someone help me pls with lenovo L560 patcher.
 TYPE: 20F2
 SN: MP-1425D7Attached FilesBadcaps Capacitor Search Engine & Electronics Repair ForumComment
 hereAttached FilesComment
 Unfortunately, the autopatcher is not working for my Lenovo P50. I tried the old and the new ones as well. If I flash the patched version, there's no picture at all, but if I flash back my original backup, there's a normal boot, but the password is obviously there.
 Can you help me patch this machine somehow? I'm attaching my original, working bios bin. This model has a Winbond 25Q128FV BIOS chip. I tried to flash similar BIOS bins from this topic, but none of them gave a picture.
 Type 20EQ-S28U03
 S/N: PC-0EQPM 16/08
 Thank you in advance!Attached FilesComment
 It doesn't work on the 8th generation l590 either, it just beeps and that's it...Hello,
 Type 20EQ-S28U03
 S/N: PC-0EQPM 16/08
 Thank you in advance!Comment
 dear Maxpower3 can you help me solve the problem of locked bios type x280, I didn't find anything that worked, S/N :PC0XVCCKAttached FilesComment
 Any advice?Hello,
 Type 20EQ-S28U03
 S/N: PC-0EQPM 16/08
 Hello friends!
 I trying lenovo_autopatcher_0.2 with my laptop Lenovo x280 board NM-B521 s/n: PC10YNRJ.
 patcher log is here:Using UEFIReplace to inject 2 DXE drivers...
 [1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
 [2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd)
 Looking for volumes to patch...
 [1/1] NVRAM_EfiSystemNvDataFvGuid (checksum 2609h):
 Found volume at offset 800000h (checksum 2609h)
 Replacing volume.
 Done.
 flashing patched bios, but laptop turn on with no display with beep code 0285.
 please help meAttached FilesComment
 try
 Thank you for trying to help me!
 I flashed all of them one by one but unfortunately none of them are working.
 Symptoms: Turning on for a second, little fan spin, then turns off with all, except this: 20250930_005915_FLASH_25128PP_PATCHED.bin
 With this one it tries to boot, restarts a few times, like it supposed to, but then the fans are speeding up and nothing happens, no picture, no reboots. It did the same with the bins that I patched with the old and new autopatcher. I don't have speaker connected so i don't know about beep codes.
 With my original attached bin there's a normal boot, just with SVP.Comment
 Try and raport!Attached FilesComment
			by macabookHello everyone,
							Channel: BIOS Requests ONLY!
 07-24-2025, 02:17 PM
			by piratiHello everyone,
			by jbonavitaHi, my laptop wont boot at all
 Some issues
 Things I tried
 1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
