  • bear_2007
    • Aug 2025
    • 7
    • Україна
    #3961
    Originally posted by SMDFlea
    Does this it have a model number ? .Does it start if you flash the old bios back
    After the patcher, it stopped starting at all, I tried the saved lamps, it doesn't work...
      • 22084
      Originally posted by bear_2007
      Dump original
      Post the laptop serial number and your EC backup
      • bear_2007
        • Aug 2025
        • 7
        • Україна
        #3963
        Я одразу прочитав дамп BIOS, а EC — лише після того, як перепробував many options BIOS з форумів. I immediately read the BIOS dump, and the EC only after trying many BIOS options from the forums.
        • bear_2007
          • Aug 2025
          • 7
          • Україна
          #3964
          still svod 4 reads EC, but doesn't want to wipe
          • mariusdumi
            • Sep 2025
            • 7
            • Italia
            #3965
            Originally posted by Karol
            Test this patched file.
            Thanks for sharing.
            I tried the file you shared,
            I wrote it and verified it was written correctly.
            It has the same problem as above: it beeps 5 times twice, the fans spin for a few seconds, and then shuts down. No signal.
            rewriting my original, it goes back to how it was before with the password.
            • floppy1
              • Sep 2025
              • Tajikistan
              #3966
              Your model can be unlock if you provide 2kb file EEPROM container from MEC1663
              No main BIOS patch available for your model
              ok, thanks
              • mouse1972
                • Jul 2023
                • 13
                • Ukraine
                #3967
                Hello friends! I used autopatcher, rewrote the patched file in the bios, but as a result, when I press the power button, it blinks 3 times. Then nothing happens. Can someone help?
                Laptop Lenovo P50
                Type 20EQ
                Serial MJ-04TPLT
                • Stefan Steff
                  • Mar 2024
                  • 376
                  #3968
                  Laptop Lenovo P50
                  Type 20EQ
                  Serial MJ-04TPLT
                  Try with this attached content.
                  STEP 1: Flash and replace current BIOS with the P50_Bios_2_PATCHED.bin file
                  STEP 2: Boot the machine
                  STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                  STEP 4: Enter any character when asked for Supervisor Password
                  STEP 5: Press enter when it shows Hardware ID
                  STEP 6: Press space bar 2x when asked
                  STEP 7: Turn off machine
                  STEP 8: Restore original P50_Bios_1.bin BIOS content
                  STEP 9: Reset BIOS settings to factory default
                  Good luck!
                  • ofluffy
                    • Aug 2025
                    • 11
                    • US
                    #3969
                    This has bricked my T470s, great. Now the power button and keyboard flicker and it won't come on fully at all.
                    • ofluffy
                      • Aug 2025
                      • 11
                      • US
                      #3970
                      Flashing both chips back to their original states doesn't even fix it, it no longer boots at all after trying the PXE driver injector method...
                      • Stefan Steff
                        • Mar 2024
                        • 376
                        #3971
                        Please provide a serial number and model number.
                        Let's try to fix your laptop
                        • ofluffy
                          • Aug 2025
                          • 11
                          • US
                          #3972
                          It's a 2017 T470s
                          I think the original serial number stickers were replaced, all I can find is:
                          Type 20HG-S14D00 and S/N PC-OPTLL4 17/09
                          • Stefan Steff
                            • Mar 2024
                            • 376
                            #3973
                            It's a 2017 T470s
                            OK, that's good. (PC0PTLL4 with "zero" after letter C.
                            The 25Q80 chip is your PD controller SPI so must be untouched and write it back as is.
                            Write the content from the attachment and tell me if it works or not.
                            It's tested by me on several T470s laptops.
                            • ofluffy
                              • Aug 2025
                              • 11
                              • US
                              #3974
                              I flashed it just now, it still does the same thing. The keyboard and power button light up briefly then it shuts off. This happens once when power is plugged in, then it is unresponsive until unplugged and plugged back in once more.
                              • Stefan Steff
                                • Mar 2024
                                • 376
                                #3975
                                OK.
                                I see some differences between your PD Controller backup and what I have saved on my PC.
                                So here is mine to try.
                                • ofluffy
                                  • Aug 2025
                                  • 11
                                  • US
                                  #3976
                                  OK.
                                  Flashed that to the pd chip, same result... Not sure what on earth is going on. This all started after trying to use the auto patcher...
                                  • Stefan Steff
                                    • Mar 2024
                                    • 376
                                    #3977
                                    Do you use clips to flash the chips or you desolder them ?
                                    Check for missing or damaged components near the BIOS chip.
                                    If programming different versions of BIOS did not result in different behavior most likely you have a hardware issue...
                                    • ofluffy
                                      • Aug 2025
                                      • 11
                                      • US
                                      #3978
                                      Yes I used SOIC8 clip with CH341a programmer. Didn't happen until I went through the bios unlock process listed on the lenovo autopatcher. It showed the usual PXE driver screen, turned off, I flashed the original like it said to, then it wouldn't turn on. I'll inspect the board.
                                      After looking, I don't see any damaged connections or missing pieces, or any significant activity on thermal camera. However, I did just notice that once powered on, the fan continues to spin and stop, over and over like it's continuously trying and failing to boot. I've attached pictures of the rom chips, maybe I missed something.
                                      • Stefan Steff
                                        • Mar 2024
                                        • 376
                                        #3979
                                        It's very tricky to use clips...must be careful and check the reading/writing at least 2 or 3 times to be sure it's done correctly...
                                        As a last try ... here is the EC content.
                                        I hope you can and know how to use JTAG to read/write the MEC1653. (You find plenty of examples here on badcaps how to prepare the MB and use the JTAG to read/write MEC chips...
                                        An example: https://www.badcaps.net/forum/troubl...lock#post74632)
                                        I don't know about the MEC1653 but the MEC1633 has an internal 2Kb EEPROM in witch is the password stored so if this is true for MEC1653 then rewriting the EC content may help to bring your laptop back to life.(without clearing the password...)
                                        Also, I don't use CH341a (I use SVOD4 and before SVOD I used JTAG programming with RT809H) so I don't know if it supports JTAG programming...
                                        In conclusion, what I would do:
                                        1.- Write the 25Q80 with the original backup content
                                        2.- Write the 25Q128 with Thinkpad T470s-Type 20HG.bin
                                        3.- Write the MEC1653 with T470s_MEC1653.bin via JTAG (attached)
                                        If it's starts then patch the Thinkpad T470s-Type 20HG.bin file and follow the instructions.
                                        Write back your saved BIOS backup file or write back the Thinkpad T470s-Type 20HG.bin and make a BIOS update.
                                        Good Luck!
                                        • ofluffy
                                          • Aug 2025
                                          • 11
                                          • US
                                          #3980
                                          Good Luck!
                                          Can you send a link to a decent one? I don't have a JTAG programmer. I have heard of it though, but I usually avoid it and use UART with my raspberry pis, since I've only ever used it for serial debugging/console.
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
