HELLO!! Can you help me remove the password? I've tried lenovo_autopatcher but it doesn't work. Serial Number: PW-05DRJP MODEL: ThinkPad L14 Gen 3, LG4 LT5 ADL RT UMA MB 223030-1. 448.0PZ80.0011
BIOS ATTACHED. THANKS, COLLEAGUES.Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello! I tried using the autopatcher for my Lenovo T480s, but it only causes the system to beep and display a blank screen (sometimes a very dimmed Lenovo logo). I'm using AsProgrammer and have followed the main instructions in this thread. I have also tried the W25Q128JV@SOIC8_PATCHED.bin file.
I've attached my original bin file.
Lenovo Thinkpad T480s
TYPE NUMBER: 20LS-002CUS
S/N: PC-0Y188A
Bios: Winbond W25Q128JV5QAttached Filesif you find these attachements useful please consider making a small donation to the site
Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.Comment
OK, let's see if my method works for you...Hello! I tried using the autopatcher for my Lenovo T480s, but it only causes the system to beep and display a blank screen (sometimes a very dimmed Lenovo logo). I'm using AsProgrammer and have followed the main instructions in this thread. I have also tried the W25Q128JV@SOIC8_PATCHED.bin file.
S/N: PC-0Y188A
STEP 1: Flash and replace current BIOS with the attached Lenovo ThinkPad T480s_PATCHED.bin file
STEP 2: Boot the machine
STEP 3: Press ENTER/F1/etc. to enter BIOS settings
STEP 4: Enter any character when asked for Supervisor Password
STEP 5: Press enter when it shows Hardware ID
STEP 6: Press space bar 2x when asked
STEP 7: Turn off machine
STEP 8: Restore your saved Original.bin BIOS
STEP 9: Reset BIOS settings to factory default
Good Luck!Attached Filesif you find these attachements useful please consider making a small donation to the site
I had the same issue as elianadragon when using autopatcher (T480s, S/N PC-1678ZZ, w25q128jv). I tried your patched version and worked perfectly. Thanks!
Good Luck!Comment
I've tried reprogramming the backup, and I can enter the BIOS again with that. The screen is still very dim with it. (might be backlight, but I am using a brand new screen)
Thank you for responding!
Good Luck!
After I flashed this file, I pressed F1 and got four beeps. Then it shows a faint "Entering Setup" on the screen and hangs there.Comment
Flash your original BIOS again and check if the laptp starts ok and you can get to the Password screen.
If it's ok then flash the patched file and try again all steps from the beginningComment
I'm trying to remove the bios Password from my ThinkPad P50.
I have tried both lenovo_autopatcher_0.2 and the older lenovo_autopatcher.
In both cases the generated files (P50BK1_PATCHED_CLEAN and P50BK1_PATCHED) do not work.
After flashing I only get a black screen, 5 beeps, fans stop spinning, and no other signs of life.
I am not able to manually edit the NVRAM (VSS2 store) blocks with UEFITool.
**Tools available:**
- Windows 11
- CH341A PRO (2 units)
- AsProgrammer
- 3 original BIOS dumps (compared with HxD, all identical)
**Motherboard:**
- Lenovo BP500 NM-A451 Rev 1.0 (2015-11-06)
- BIOS chip: Winbond W25Q128FV
- Machine: ThinkPad P50, TYPE 20EQ-S3WF12, S/N PC-0GSV94 16/11
I know that many users face the same issue (after autopatcher → 5 beeps and black screen).
Has anyone already found a working patch for the P50, or could you help me clean the dump manually?
Thanks!Attached Filesif you find these attachements useful please consider making a small donation to the site
I need a patched BIOS version for X1 Yoga 4th generation. Autopatcher did not help, the laptop beeps many times, and the screen remains black.
MB: NM-B861
Type: 20QG-S4K100
Serial: PF-2622VP
Thank youAttached Filesif you find these attachements useful please consider making a small donation to the site
Can you patch this file for x480
Type the laptop serial number
read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
OK
Than connect an external HDMI screen for better view, and keep pressing the F1 key when start with the patched file. If you delay with F1 key it freeze in Lenovo screen.Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.Comment
Test this patched file.Hi everyone,
- Windows 11
- AsProgrammer
**Motherboard:**
Thanks!
Your model can be unlock if you provide 2kb file EEPROM container from MEC1663
No main BIOS patch available for your modelJoe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.Comment
Dump originalAttached Filesif you find these attachements useful please consider making a small donation to the site
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by piratiHello everyone,
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
