  • aca2302
    • May 2024
    • Serbia
    #3241
    is it possible to remove superwisor password, x1 tablet 3rd gen 20kk?, thanks in advance.
    https://www.badcaps.net/forum/troubl...63#post3253463 is this patch compatible with other lenovo x1 tablet 3rd gen devices, or must make new one?, and how to flash or upddate bios with that file/
  • Rumbugger
    • Jun 2024
    • Netherlands
    #3242
    Hello, I just tried to patch the attached bios dump for my x380 yoga using the autopatcher but it is giving me this error:
    [1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
    afterflash1.bin is corrupted or does not contain a valid dump.
    There was an error... Aborting.
    However, when I flash the same dump onto the laptop it boots without issue (aside form the SVP still being active)
    checksum is correct also
    any idea on what I should do?
    thinkpad model : x380
    type: 20LH-0015US
    S/N: N-MP-19FRMU 18/12
      • 20311
      The attached file is only 1MB ,its the thunderbolt firmware.You chose the wrong chip !
      • danish yousuf
        • May 2024
        • UNITED ARAB EMIRATES
        #3244
        lenovo x280 bios patch file help
      • rddube
        Aspiring Expert
        • Jun 2013
        • 908
        Originally posted by rddube
        Need a bit of help here, although I was able to remove the password and recover my Lenovo Carbon Gen 4 with the procedure in the first post, for some odd reason my laptop keyboard is no longer functional, only the Windows key works, all other keys are DOA?? Any ideas? If I plug an external keyboard everything works fine, so does the screen keyboard, but the laptop keyboard is dead. Did I forget something when recopying my original Bios ? Please help and many thanks!
        Just thought I would update so that anyone in this same situation can benefit from it. It turns out that coincidental with the password removal, my keyboard died of a lonely death. Changed the keyboard and everything is back to normal!
        • Rhork
          • Apr 2020
          • 28
          • France
          #3246
          Hello !
          I followed the instructions, on an X270 motherboard (I work on the board alone so no battery or battery bios), the patch worked well no error and generate the file "patched".
          I did hold the anti-tamper switch down the whole time, but when the reboot finished I stayed on the "Lenovo" logo to press enter and nothing happened...
          I haven't done a clean ME.
          Any ideas?
          I'm attaching both but I'd especially like to understand why it's blocking, thanks in advance and thanks Knucklegrumble.
          Edit : board : DX270 NM-B061 Rev1.0 Serial number PN : 4511230120B
        • santoslao
          â €
          • Apr 2017
          • 94
          • BZ
          #3247
          Gentlemen, I come here to report a problem that is happening! I've been trying to remove the computrace from a thinkpad E490 model 20N9 for 2 days. I've tried autopatcher 01 and 02 dozens of times, it does the patch, but when I flash it the machine beeps on 01 or no image appears after pressing f1 on 02! I've already flashed the EC and it doesn't work! Computrace won't go away for nothing! I put a password in the bios, I made the patch in the EC file, I flashed the machine and it remains with computrace activated! Help me please!!!
          Thinkpad E490
          Model 20N9
          SN: PE05GBC6
          UEFI Bios Version: 1.29
          The attachment contains the original dump and the EC file extracted from the machine via SAS.
          • santoslao
            â €
            • Apr 2017
            • 94
            • BZ
            #3248
            Thinkpad E490
            Model 20N9
            SN: PE05GBC6
            I managed to find a clean Ec+Dump file, with great effort, I ran it through the machine and removed this damn function. I'll leave them here in case anyone else needs them, but I make it clear that all the ECs of this model that are on the forum are the incorrect size of 128kb, the correct size is 256kb, just like the one I post here.
            • wayyne
              • Jun 2024
              • N/A
              #3249
              Thinkpad T480s:
              Type: 20L7-001NGE
              S/N: PC13XSFF
              Mainboard: ET481 NM-B471
              Bios Chip: MXL12873F
              1. The computer which I am trying to run the LENOVO BIOS AUTO-PATCHER uses Win11
              2. When opening cmd and type command autopatch <mybios.ext> then i receive the following error
                C:\Users\Admin\Downloads\lenovo_autopatcher>autopatch Bios_T480s_new_outimage.bin
                Python konnte nicht gefunden werden. F³hren Sie die Verkn³pfung ohne Argumente aus, um sie ³ber den Microsoft Store zu installieren, oder deaktivieren Sie diese Verkn³pfung unter
                although I have Python 3.12.4 installed.
              Therefore I am not able to patch my dump which contains Supervisor Password myself. I kindly ask for your assistance.
              More context to my case you find here:
              https://www.badcaps.net/forum/troubl...64#post3293364
              • Markus1741
                • Sep 2020
                • 842
                • N/A
                #3250
                Here is the patched file ...
                • wayyne
                  • Jun 2024
                  • N/A
                  #3251
                  Markus1741 thanks a lot for your help again. With your patched image and following the guide on the front page, the Supervisor Password got removed and I have a revived T480s. Thanks again.
                  • Rhork
                    • Apr 2020
                    • 28
                    • France
                    #3252
                    Any help please on my message posted above (#3246)?
                    I have tried a clean ME of the original bios before patching and still stuck on the LENOVO logo.
                    • Markus1741
                      • Sep 2020
                      • 842
                      • N/A
                      #3253
                      [QUOTE=Rhork;n3294580]Any help please on my message posted above (#3246)?
                      • Rhork
                        • Apr 2020
                        • 28
                        • France
                        #3254
                        Still the same problem, stuck on the Lenovo logo and impossible to press enter, I tried two different keyboards.
                        • Markus1741
                          • Sep 2020
                          • 842
                          • N/A
                          #3255
                          next one try ...
                          • Rhork
                            • Apr 2020
                            • 28
                            • France
                            #3256
                            next one try ...
                            Alors avec celui ci j'ai les mêmes choses que le bios original.
                            Bloqué à l'étape 5 :
                            [ HOW TO USE THE PATCH ]
                            STEP 1: Flash and replace current BIOS with the generated patch file
                            STEP 2: Boot the machine
                            STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                            STEP 4: Enter any character when asked for Supervisor Password
                            STEP 5: Press enter when it shows Hardware ID
                            STEP 6: Press space bar 2x when asked
                            STEP 7: Turn off machine
                            STEP 8: Restore original BIOS
                            STEP 9: Reset BIOS settings to factory default
                            After entering 3 random passwords in step 4, I don't have the ID and the PC reboots, nothing better.
                            Edit : I have the impression that it's the original bios, you wouldn't be mistaken?​
                            • Rhork
                              • Apr 2020
                              • 28
                              • France
                              #3257
                              Just so you know, I understood the problem of getting stuck on the LENOVO logo, I tried it on another Lenovo that got stuck (X1 Carbon) and I had the same problem, in fact you just need to spam Enter & F1 to get to the step before the logo if that helps!
                              And I unblocked both!
                              Thx for the forum
                              • invisiblewin
                                • Jun 2024
                                • usa
                                #3258
                                Hello. Can LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal be used for Lenovo X1 Yoga Gen.6
                                • Andreasbest
                                  • Aug 2014
                                  • 1133
                                  • Hellas ( Greece )
                                  #3259
                                  Can someone please confirm if T480s and/or T490s can be unlocked with Autopatcher OR if the password is in EC now and need SVOD tool?
                                  Please respond ONLY if you have tried and know for sure.
                                  Thank you!
                                    • 20311
                                    Thank you!
                                    search ,search ,search
                                    https://www.badcaps.net/forum/troubl...password/page2 T480s Autopatcher works
                                    https://www.badcaps.net/forum/troubl...ss#post3237235 T480s EC bypass works
                                    https://www.badcaps.net/forum/troubl...06#post3238406
                                      by Vesko356
                                      08-11-2023, 03:27 AM
                                    • jbonavita
                                      by jbonavita
                                      Some issues
                                      Things I tried
                                      04-29-2025, 09:38 PM
                                    • zenius
                                      by zenius
                                      12-08-2024, 06:13 AM
                                    • Wahaz
                                      by Wahaz
                                      10-30-2023, 08:42 PM
                                    • Bloodhoundje
                                      by Bloodhoundje
                                      03-16-2024, 03:12 PM
