Help please Lenovo T480S Bios Password
  • Stunt
    • Oct 2019
    • 203
    • South Africa
    Originally posted by SMDFlea
    RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
    You MUST:
    Hi sorry i understand but the bios i posted above it's working the problem it's got admin password.
    I tried using lenovo autopatch twice but on the patched files i get no display and a short melody.
    So i just wanted someone to patch it for me in case maybe i'm doing something wrong or my python got a problem
    I also tried the patched files T480S i found on this platform they boot but get stuck on lenovo logo
    Type 20L8-S4PR13
    S/N PC-13ZZJT
    • Markus1741
      • Sep 2020
      • 970
      • N/A
      Type 20L8-S4PR13
      S/N PC-13ZZJT
      It is very important with this model that no resistors on the chip are damaged when the patch is played back​.
      Try this files ....
      • Stunt
        • Oct 2019
        • 203
        • South Africa
        Try this files ....
        Thank you very much i really appreciate your time files worked flawless.
        I don't know what's wrong with my lenovo autopatcher
        • xred357
          • Jun 2023
          • 7
          Try this files ....
          I too am in Autopatcher hell. I did the autopatch on a T460S and it went flawlessly. Following the exact same process, it then failed on TWO T480s. I made it all the way throught the process to where you flash the original BIOS back on. Now both units are black screen and won't boot. Details;
          1st: Type: 20L8S0AS00 SN: PC0ZENVD
          2nd: Type: 20L8S0AS00 SN: PCOZEV82
          • xred357
            • Jun 2023
            • 7
            Hi All, I'm stuck in Autopatcher hell,,,. I did the autopatch on a T460S and it went flawlessly. Following the exact same process, it then failed on not one but TWO T480s. I made it all the way through the process to where you flash the original BIOS back on. Now both units are black screen and won't boot. Details;
            I have original (unpatched) BIOS for both if that helps
            • danito
              • Jun 2016
              • 1218
              #26
              try
                • 22168
                I have original (unpatched) BIOS for both if that helps​
                Thread merged.Don`t start another thread with the same request in future.Please read the rules ! https://www.badcaps.net/forum/troubl...before-posting
                • xred357
                  • Jun 2023
                  • 7
                  Originally posted by danito
                  try
                  Thanks! Same process as the autopatcher? Apply the patch version and then the unpatched version?
                  • danito
                    • Jun 2016
                    • 1218
                    #29
                    exactly
                    • lokifreyjava@gmail.com
                      Greylock16
                      • Jul 2024
                      I can't seem to run the autopatch.cmd file without it just crashing even though i have Python installed, I was wondering i anyone could give me aa hand in getting this working.
                      • xred357
                        • Jun 2023
                        • 7
                        exactly
                        Tried it on one of my two bricked T480s. I have confirmed it's taking the flash successfully. I flashed the images you provide, then read them back, save and run certutil to verify the hash on the flash and the original file match. When I try to boot I get the 3 flashes on the power button and a black screen and nothing else. CPU fan spins for 2 seconds, stops then tries to spin again.
                        Anything else I can try next?
                        • danito
                          • Jun 2016
                          • 1218
                          #32
                          Put a bios backup, maybe we can fix it...
                          • xred357
                            • Jun 2023
                            • 7
                            danito Thanks for the offer of help. Attached is a ZIP containing 2 BIOS, one from each laptop. These were the "B" pulls that were the second read verified against the first "A" read. Flashing these back after a successful Autopatch is what bricked both units.
                            • danito
                              • Jun 2016
                              • 1218
                              #34
                              try and report
                              • xred357
                                • Jun 2023
                                • 7
                                try and report
                                Tried both images. Programmed to the provided repaired image, then read it back and saved it and ran a comparison check to make sure programmed image matched the original file CRCs. Programming was successful but neither machine will post. Just as before plugging in power give three flashes and machine won't post. I've tried the hold power for 30 seconds as well as holding the reset button on the bottom for over 60 secs. Any other options I can try?
                                • xred357
                                  • Jun 2023
                                  • 7
                                  Bumping this post. Looking for any options has I have 2 T480s that are both bricked and won't come back. As noted they will take a flash but won't post. Thanks.
                                  • b4rdock
                                    • Jun 2017
                                    • 107
                                    • usa
                                    #37
                                    It is very important with this model that no resistors on the chip are damaged when the patch is played back.
                                    Try this files ....
                                    i try patch 8th generation also t480 autopatcher not works i try figure out how works for this model, how can find the evsa region with hex or what tool i can use for identify sir ?
                                    • frankfurbish
                                      • Apr 2019
                                      • nigeria
                                      #38
                                      I NEED PATCH BIN FOR LENOVO T480S
                                      • peste
                                        • 13803
                                        • ROMANIA
                                        #39
                                        post S/N, full name and model, motherboard model, TYPE,etc.
                                        post the contents of the bios chip even if it is corrupted..
                                        What's wrong with the laptop???
                                        • sauce
                                          • Sep 2013
                                          • 149
                                          • France
                                          #40
                                          I have a T480S with a bios password.
                                          I tried autopatcher but still asking for the password.
                                          Here is my information
                                          Type 20L8S39T05
                                          SN: PC185BLG
                                          Original bios file is attached.
                                          • RMDUiFT
                                            Should I buy a Lenovo Thinkpad E495 with bios password?
                                            by RMDUiFT
                                            Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                                            I have a few questions:
                                            • If I would buy this laptop and have
                                            08-25-2024, 09:00 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • lucaszmn
                                            by lucaszmn
                                            Problem:
                                            Initial Findings:
                                            • I concluded that the
                                            08-12-2025, 03:01 PM
                                          • baaligoga
                                            Help needed in unlocking BIOS Supervisor password - Lenovo X1 Yoga 5th Gen
                                            by baaligoga
                                            Good day, everyone!
                                            I'm encountering an issue with my Lenovo X1 Yoga 5th Gen laptop related to the BIOS supervisor password. I'm seeking assistance and guidance from the knowledgeable members of this community in resolving this problem.
                                            I am no expert and cannot perform soldering or unsoldering of the chip from the board. Therefore, I attempted to use an EZP 2023 programmer with a clip to extract the BIOS bin file without removing the BIOS chip from the motherboard. The BIOS chip has the following letters imprinted on it: "Winbond 25Q80DVNIG 2026". I used the...
                                            05-20-2023, 09:48 AM
                                          • darknwo
                                            Bios password Lenovo Legion 16IRX8H
                                            by darknwo
                                            Hi, can someone help me please with the removal of the bios password of this dump.
                                            Someone desoldered the bios chip, tried several "methods" but with no luck, and he gave me the dump to try to search some help.
                                            For now he deleted more things and bios password is gone but laptop doesn't show serial, model etc.
                                            Also, I updated bios to latest version, when he will write the dump again without password, it should be better to put back the old version that was orignally or doesn't matter? Because from what I've read this laptop has 3 bios chips, don't know if has...
                                            10-05-2024, 10:40 AM
