LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
  • Iain21
    replied
    I need a patched bios for an X1 Yoga 4th gen please. I tried the autopatcher, but laptop just repeatedly beeps with the patched file.
    Type: 20QF-00ADUK
    Serial: PF-13G9NF
    Thank you​
  • TemporaryConnect
    replied
    Hey there.
    I just tried this solution on my Lenovo T480 20L5.
    I followed the guide [HOW TO USE PATCH] and after reflashing the original BIOS image, I am back to the Bios Lock.
    Am I missing something, I appreciate any suggestion.
  • Maxpower3
    replied
    Originally posted by Kokofli
    Tried it, and its working!!!! Unlocked 3 laptops relly easily if you understand how it works! Thank you for quidance!!!
    Many do not understand and brick their PCs
    You must read the instructions on the different posts.
    This remains a risky method that does not work every time.
    Thanks for the feedback​
  • Kokofli
    replied
    Originally posted by Stefan Steff
    Try with this method :
    https://www.badcaps.net/forum/troubl...ss#post3237235
    99% it will do the job if you're patient
  • Kokofli
    replied
    Here is your patched file:
    Thank you a lot!!!!
  • Paffo
    replied
    Originally posted by Paffo
    It worked, after flashing it i could access the Bios without being asked for a password.
    The only problem is that this is for the IA32 version of the bios instead of the 64 bit version, it won't boot any x86_64 OS.
    I tried flashing back the locked one, but the tablet hangs with black screen if i try to open the bios.
    At the same time if i try to use WinFlash to force a bios update, with the original one it will freeze at "Reading Current Bios", while with your unlocked one it reboots but the update never happens.
    Any idea perhaps?
    This is actually solved now after taking a fresh rom from the capsule.
    I don't know how to delete the post unfortunately
  • Stefan Steff
    replied
  • Kokofli
    replied
    Hey Y'all
    Can someone please help me to patch BIOS file? I have an issue and i think Win 11 dont patch it right.
    Machine Type Model : Lenovo X280 20KE-SAX000
    System Unit S/N : PC-115RG6
    BIOS Chip : 25Q128JVSQ winbond
    CPU: i5-8250U
  • Paffo
    replied
    Originally posted by danito
    try
    Any idea perhaps?
  • danito
    replied
    SN: MP06NDP9
    MTM: 20C10024UK
    Board ID: LA-A811P
    try
  • Paffo
    replied
    I am having an issue with the script, it always tells me that there's a dumping error.
    I have dumped 4 times with power cycles in between and all the files are (MD5) the same, so i don't think its a bad dump.
    Could anyone please check?
    The model is a T10 Thinkpad Tablet
    SN: MP06NDP9
    MTM: 20C10024UK
    Board ID: LA-A811P
    commented on 's reply
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
  • Paffo
    replied
  • AAAC
    replied
    Originally posted by kattyg
    Anyone get success with p72 ? gettin 3 beep and no boot after patch
    tryin 3 times
    I do have ThinkPad P72 (20MB, 20MC) [32MB]​ in my list of compatible ThinkPad models, meaning that I had patched it myself and confirmed working. I usually patch the earliest BIOS version downloaded from Lenovo website using Serial Number, then I use this patched BIOS Region and replace it in the Original BIOS, doing it this way I virtually eliminated any possible beep codes on patched files. You may have to add some padding at the beginning of the BIOS extracted from BIOS update to match the size of BIOS Region in your Original BIOS.
  • Stefan Steff
    replied
    tryin 3 times
    It's not about the model...
    It's about CPU type, if your CPU is i7-8850H then the autopatcher wont work.
    Try LPC method described here : https://www.badcaps.net/forum/troubl...ss#post3237235
    Good luck!
  • kattyg
    replied
    tryin 3 times
    BIOS Version N2CET71W (1.54)
    Embdedded Controler Version N2CHT26W (1.16)
    ME FIRMWARE 12.0.90.2072
    Machine Type Number 20MCS27300
    System Unit Serial number PF1RGGQP
    System Board serial number L1HF93S0025
    (ili tryin flash U9 MX25L25673G)
    also get success with lot of p50 ant t480, but p72 stomped me ;0
    post the laptop serial number https://www.badcaps.net/forum/troubl...before-posting
  • kattyg
    replied
    tryin 3 times
  • vzgherea
    replied
    The LPC approach worked for X1 Yoga 3rd Gen, Type 20LE (i7-8650U CPU). Thanks for the hint!
  • bardiasm
    replied
    It seems like the issue with black screen and error code 0285 is more common that I thought. Has anyone figure out a way how to get it to work? I'd really appreciate any help.
  • Vesko356
    by Vesko356
    08-11-2023, 03:27 AM
  • jbonavita
    by jbonavita
    Some issues
    Things I tried
    04-29-2025, 09:38 PM
  • zenius
    by zenius
    12-08-2024, 06:13 AM
  • Wahaz
    by Wahaz
    10-30-2023, 08:42 PM
  • Bloodhoundje
    HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
    by Bloodhoundje
    I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
    I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
    After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
    I have desoldered the bios chip (GigaDevice...
    03-16-2024, 03:12 PM
