BIOS REQUEST HP 430 g3
  • vikivng
    • Feb 2019
    • 228
    Hi guys,
    hope I did this correctly..
    Here is my bin for help in getting a clean one.
    When I connected using a test clip I got manufacturer unknown, unknown memory.
    However it read the chip and im posting the bin here.
    Thnx
  • Claudiomfa
    • Nov 2015
    • 455
    • Portugal
    Re: BIOS REQUEST HP 430 g3
    your uploaded file is completely empty
    read chip again
    • vikivng
      • Feb 2019
      • 228
      IM thinking this may not have done it correctly.
      Are these test clips usually hard to connect to the chip.?
      • vikivng
        • Feb 2019
        • 228
        read chip again
        LOL,,ok..having trouble using the test clip..
        • peste
          • Dec 2016
          • 13721
          • ROMANIA
          remove your chip from the motherboard before reading or writing..do not use the clip, you may have errors ..
          • vikivng
            • Feb 2019
            • 228
            ok
            • vikivng
              • Feb 2019
              • 228
              What size should the file be after read.?
              • servis_null
                • Oct 2014
                • 82
                • Croatia
                Should be 16.384KB
                • vikivng
                  • Feb 2019
                  • 228
                  HI again
                  I have directly soldered wires from the clip cable to the chip.
                  The detect tells me the manufacturer is unknown,also memory name and size.
                  It does show memory type manufacture r id ,memory capacity and device id.
                  Just want to make sure I have not made any wrong connections before I desolder the chip since I now have solid connections straight to the pc.
                  red wire goes to pin 1 etc .No shorts..
                  pls help.
                  When I click verify it tell me chip and its contents are in disagreement.'
                  • servis_null
                    • Oct 2014
                    • 82
                    • Croatia
                    HI again
                    pls help.
                    As Peste mention, you MUST remove eeprom from board in order to autodetect, read, erase, write etc etc and avoid damaging motherboard.
                    Soldering wires is same as using clip
                    • vikivng
                      • Feb 2019
                      • 228
                      Hi again
                      is this one correct.?
                      • servis_null
                        • Oct 2014
                        • 82
                        • Croatia
                        Hi again
                        looks like wrong eeprom, find another one on the board
                        • vikivng
                          • Feb 2019
                          • 228
                          Can someone show a pic of where the correct chip is on the HP 430 G3 LAPTOP?
                          • servis_null
                            • Oct 2014
                            • 82
                            • Croatia
                            Should be next to bios battery..
                            Write here you eeprom model here, should be something like 25B128
                              • 22093
                              Try AsProgrammer software instead,select the ch341a under hardware first, then choose the bios chip manually https://www.badcaps.net/forum/showpo...6&postcount=10
                              Attach the charger to the laptop before making a backup,be careful not to short anything out with the clip.
                              • vikivng
                                • Feb 2019
                                • 228
                                Originally posted by servis_null
                                should be next to bios battery..
                                Write here you eeprom model here, should be something like 25b128
                                winbond
                                25q128f
                                • vikivng
                                  • Feb 2019
                                  • 228
                                  This is right next to the round battery yes.
                                  • vikivng
                                    • Feb 2019
                                    • 228
                                    OMG,,how do I change asprogrammer to english?? driving me nuts.
                                    sorry guys.
                                    ok was using 1.4,,2.0 defaults to english.
                                    • vikivng
                                      • Feb 2019
                                      • 228
                                      HI again guys.
                                      here is my file ,hopefully its now correct.
                                      Read with asprogrammer.
                                      Ok im guessing this also not right.
                                      I dont understand what I am doing wrong.
                                      Im sure the chip has been soldered the correct way with the dots matching.
                                      I assume nothing else is meant to be connected (adapters etc)to the programmer apart from the chip itself.
                                      The software sees it..I click read ic' ,progress bar takes a min or so..can someone help pls.
                                      • lapfix
                                        • Mar 2020
                                        • 2765
                                        • my workshop
                                        empty one , you waste your time .
                                        your bios is near bios battery ...the only one .
                                        https://ae01.alicdn.com/kf/HTB1_D3nb...3-I7-6500U.jpg
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • hotcrossedbuns999
                                          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                          by hotcrossedbuns999
                                          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                          3. I could only locate two chips that look like bios chips. Could someone verify this
                                          01-03-2025, 12:32 PM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
