Plz i need to clear bios password for lenovo thinkpad T470...thanks
Lenovo ThinkPad T470 bios password decrypt
Tags: None
anyone can remove password from this dump t470
hi all i read bios dump from t470 locked with password is there away to resend me dump unlocked to write it and if there is any tuto how to remove it will be really appreciated
thx in advanceAttached FilesComment
Re: anyone can remove password from this dump t470
your solution can be found here https://www.badcaps.net/forum/showth...=824459&nojs=1Comment
here is the unlocked bios for T470Attached FilesComment
Re: Lenovo ThinkPad T470 bios password
Read bios with programmer and post here!Comment
The rom file =16 megaAttached FilesComment
Try this, please confirm!Attached FilesComment
Thank you CraterM for your help..but unfortunately not showing picture / backlight..can you please patch my second dump ( there's a picture with it ) who give me this error : bad CRC security in efi variable.
thank youAttached FilesLast edited by asem18; 02-29-2020, 08:01 AM.Comment
Hi all
just came across this forum when searching for info to reset a ThinkPad T470 supervisor password. Quick question to get me started on my journey.
Can i use a raspberry pi to read/write the ThinkPad T470 bios chip (W25Q128JV
), i found some instruction on youtube but i would like to check before i start messing - https://www.youtube.com/watch?v=vgbWtxv_hqM
Thank you in advanceComment
Hi all
After reading some posts on this forum in regards to Thinkpad T470's and the supervisor password resets ive got a SOIC8 clip and a raspberry pi and i believe successfully read the W25Q128JV bios.
Can anyone help me with removing/reseting the supervisor password section from this .bin file
Thanks in advanceAttached FilesComment
Re: Lenovo ThinkPad T470 bios password decrypt
Hi all
by RMDUiFTGood day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
I have a few questions:- If I would buy this laptop and have
Channel: BIOS Requests ONLY!
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM -
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
- Loading...
