hp 250 g7 corrupt bios
  • ellu87
    • Mar 2023
    • 3
    Bios HP 250 G7 need help
    said NB recently tried a bios update (automatically?) said the owner. So I tried to flash the latest bios from HP using a repair stick.
    However, it only starts during the flash process until "initialize"... - after a few seconds it switches off and stays on with pwr_led.
    Bios backup file does not exist.
    Serial Nr: CND93963RY
    Screenshot of the label attached. Can someone help if possible with instructions or a link to it?
    Thanks in advance
      • 22279
      Re: Bios HP 250-G7 need help
      Thanks in advance
      do you have an SPI programmer ?
      • ellu87
        • Mar 2023
        • 3
        Re: hp 250 g7 corrupt bios
        Unfortunately no longer available...pensioner.
        • kaypdss
          • Feb 2015
          • 8
          • Argentina
          #44
          Originally posted by reset1986
          Thank you very much for the advice,
          i can't write bios with with Win + b,
          the tl866cs timer does not recognize me the main bios chip signed xmc qu64ah1g
          but I managed to dump 8mb by checking the check id, I attach the dump,
          the bid version 084AA
          i think the tl866cs will give writing problems for this i am trying to use the WIN + B procedure,
          I prepare the usb key and copy the bios to the current folder, I rename it 084AA.bin but it gives me error "Bios ID of Image does not match system"
          you also need another 084AA.s12 file
          thanks for the help
          Hi, how do you manage to obtain the bid version from the bin file?? i made a dump file of my bios but i can't find the version inside.
          Thanks!
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            #45
            Thanks!
            Upload the dump here.
            Become a Badcaps supporter
            Thanks to all supporters.
            • Dt90
              • Aug 2023
              • Deutschland
              #46
              please help, the same problem.
              What did i need to fix it?
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #47
                https://www.badcaps.net/forum/showthread.php?t=103526
                6. Finding bios update packages
                6.1.8. HP
                See:
                https://www.badcaps.net/forum/showthread.php?t=122195
                [Guide] How to extract ready for programming dump from HP update executable file
                https://www.badcaps.net/forum/showthread.php?t=121948
                • teoinsta2
                  • Sep 2023
                  • Italia
                  #48
                  where can i find the .s12 file?
                  • blackmamba
                    • Oct 2023
                    • 3
                    • italy
                    #49
                    Originally posted by SMDFlea
                    sp100745 is a diagnostics app,that version does not include any bios. The recovery methods are listed in this HP document - https://support.hp.com/in-en/document/c02693833
                    There is no bios update listed on the 250 G7 drivers support page but a full bios is is included on the latest HP PC HARDWARE DIAGNOSTICS 4-IN-1 USB KEY - http://ftp.hp.com/pub/softpaq/sp1035...0/sp103655.exe
                    Make another key from that and run it, if you still can`t recover the bios then extract the 4-in-one key with winrar or 7zip.Look in the folder called Field,then open the BIOSCopy.csv to find your bios name in the list.All the full bios are in the BIOS folder.Flash the bios with your tl866,then you`ll need to run hp BCU bios config utility from windows, nbdmifit from UEFI or use wndmifit from windows.
                    HP DMI Tool NBDmiFit - https://www.badcaps.net/forum/showthread.php?t=69204
                    EDIT: The bios.bin isn`t in the BIOS folder even though its listed in the BIOSCopy.csv file. The bios is 084A8 ,check your bios backup to make sure its the right one. Strangely the bios is included with an earlier version of the 4-in-one key for other models but not listed in the .csv , thanks HP ! .
                    Bios 084A8.bin attached .
                    hi i have the same problem with my hp 6BP85EA#ABZ 250g7 - the bios should be the f.22 mb 8532. Bios is corrupted and i have not a tls. Could you help me please?
                    • DaFluepp
                      • Oct 2019
                      • 57
                      • Deutschland
                      #50
                      Hi, can anybody repair my biosfile ?
                      Error : black screen , no blinking errors
                      HP 250 G7
                      Ser: CND0302FF4
                      Mainboard : LA-J951P
                      thx very much
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12441
                        #51
                        HP 250 G7
                        Ser: CND0302FF4
                        thx very much
                        DMI + Windows key : 400000h -> 40130Fh
                        Bid : 086C1
                        • DaFluepp
                          • Oct 2019
                          • 57
                          • Deutschland
                          #52
                          its working, thank youu very much !
                          • ARS
                            • Mar 2013
                            • 28
                            • Slovakia
                            #53
                            Error : black screen , 5 long, 3 short blinks
                            HP 250 G7
                            Ser: CND04212MC
                            thanks
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12441
                              #54
                              HP 250 G7
                              Ser: CND04212MC
                              thanks
                              The file you posted is for OMEN by HP - 17-w200nx and your serial number is also bogus.
                              • ARS
                                • Mar 2013
                                • 28
                                • Slovakia
                                #55
                                The BIOS may be wrong, im not first who flashed it. That means i dont have original file. But SN is from bottom cover.
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12441
                                  #56
                                  Try # 51
                                  • lextar
                                    • May 2018
                                    • 12
                                    • ITALY
                                    #57
                                    Hi there, I got this laptop used and when it reboots it tries everytime to update the BIOS but it fails to write the bios and stucks at 1%.
                                    To power off the machine, i need to open it and remove the battery.
                                    I saw in the BIOS that the serial, model and windows serial info are missing. Maybe the previous owner messed with the BIOS for some reason, and now I don't have the DMI data.
                                    Maybe if I can manually insert back the values, I can proceed to update, but how can I add the values? I tried with the HP BIOS Tool but with no luck. I do have an SPI Programmer (using Raspberry PI)
                                      • 22279
                                      Did you try HP Bios Config Utility
                                      • lextar
                                        • May 2018
                                        • 12
                                        • ITALY
                                        #59
                                        Yes, No success. Always gave me NO PERMISSION/ ERROR CODE: 6, here 's part of the log:
                                        2024/08/08 23:44:52.685519 | 7236|Setting|HP::Shared::StreamLog::StreamLog| Log Severity Level >= Info
                                        2024/08/08 23:44:52.685519 | 7236|Info |HP::Shared::StreamLog::StreamLog| Begin.
                                        2024/08/08 23:44:52.685519 | 7236|Info |BiosConfigUtility::InitInstance| *****************************************************
                                        2024/08/08 23:44:52.685519 | 7236|Info |BiosConfigUtility::InitInstance| ** HP Bios Configuration Utility v. **
                                        2024/08/08 23:44:52.921323 | 7236|Info |BiosConfigUtility::InitInstance| Platform: 86C1 - InsydeH2O EFI BIOS
                                        2024/08/08 23:44:52.941419 | 7236|Info |BiosConfigUtility::InitInstance| BIOS version: 15.28 06/02/2020
                                        2024/08/08 23:44:52.941419 | 7236|Info |BiosConfigUtility::InitInstance| Manufacturer: HP
                                        2024/08/08 23:44:52.941419 | 7236|Info |BiosConfigUtility::InitInstance| Computer name: LAPTOP-O831BFTQ
                                        2024/08/08 23:44:52.941419 | 7236|Info |BiosConfigUtility::InitInstance| Serial number: ABCDEF0123
                                        2024/08/08 23:44:52.941419 | 7236|Info |BiosConfigUtility::InitInstance| Unicode password supported: Yes
                                        2024/08/08 23:44:52.941419 | 7236|Info |BiosConfigUtility::InitInstance| OS: Microsoft Windows 11 Home 64 bit
                                        2024/08/08 23:44:52.941419 | 7236|Info |BiosConfigUtility::InitInstance| OS version: 10.0.22631
                                        2024/08/08 23:44:52.941419 | 7236|Info |BiosConfigUtility::InitInstance| Command line: ["C:\Program Files (x86)\HP\BIOS Configuration Utility\BiosConfigUtility64.exe" /
                                        2024/08/08 23:44:53.831877 | 7236|Error |biosconfig::FileSettings::ApplySettings| Setting 'Serial Number' changeStatus='fail' returnCode=6 oldValue='ABCDEF0123' newValue='CND0260KL5'
                                        2024/08/08 23:44:54.113375 | 7236|Info |biosconfig::FileSettings::ApplySettings| Setting 'Keyboard Type' changeStatus='skip'
                                        2024/08/08 23:44:54.129002 | 7236|Info |biosconfig::FileSettings::ApplySettings| Settings processed: 36, errors: 1, warnings: 0, skipped: 35, succeeded: 0
                                        2024/08/08 23:44:54.129002 | 7236|Error |biosconfig::Utils::ShowMessage| <ERROR msg="An operation failed" />
                                        2024/08/08 23:44:54.129002 | 7236|Info |HP::Shared::StreamLog::~StreamLog| End.​
                                          • 22279
                                          Yes, No success. Always gave me NO PERMISSION/ ERROR CODE: 6, ​
                                          Ok.Post your bios backup and the laptop serial number
                                          • Bloodhoundje
                                            HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                                            by Bloodhoundje
                                            I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                                            I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                                            After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                                            I have desoldered the bios chip (GigaDevice...
                                            03-16-2024, 03:12 PM
                                          • TripTop
                                            Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                                            by TripTop
                                            Hi
                                            i have dell latitude E7270 with following symptoms:
                                            - takes long time to restart.
                                            - sometimes powers on and then off
                                            - sometimes while working it just dies,
                                            From googling online bios clean could possible resolve this?
                                            i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                                            As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                                            I reinstall...
                                            09-09-2024, 02:05 PM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • grimacelord
                                            Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                            by grimacelord
                                            Hello there.
                                            I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                            History:
                                            1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                            I searched for this error online and discovered...
                                            03-15-2023, 03:29 PM
