hp 250 g7 corrupt bios
  • reset1986
    • Dec 2014
    • 340
    • italia
    hi, i have problems with this hp,
    always starts at the bios update screen, writes the bios from the hard disk and fails and repeats endlessly,
    I ran the WIN + B procedure prepared the USB key, writing this file from the HP site https://support.hp.com/it-it/drivers...ok-pc/24381316, sp100745
    but the BIOS does not find a file.bin is not saved in the USB key
    the bios chip is signed with XMC and the tl866cs programmer does not identify me
    thanks
  • lapfix
    • Mar 2020
    • 2778
    • my workshop
    Re: hp 250 g7 corrupt bios
    Today, only a part of what is commonly called bios is provided for the upgrade on the HP website .
    Better to post your bios backup here and someone gonna help you.
      • 25766
      sp100745 is a diagnostics app,that version does not include any bios. The recovery methods are listed in this HP document - https://support.hp.com/in-en/document/c02693833
      There is no bios update listed on the 250 G7 drivers support page but a full bios is is included on the latest HP PC HARDWARE DIAGNOSTICS 4-IN-1 USB KEY - http://ftp.hp.com/pub/softpaq/sp1035...0/sp103655.exe
      Make another key from that and run it, if you still can`t recover the bios then extract the 4-in-one key with winrar or 7zip.Look in the folder called Field,then open the BIOSCopy.csv to find your bios name in the list.All the full bios are in the BIOS folder.Flash the bios with your tl866,then you`ll need to run hp BCU bios config utility from windows, nbdmifit from UEFI or use wndmifit from windows.
      HP DMI Tool NBDmiFit - https://www.badcaps.net/forum/showthread.php?t=69204
      EDIT: The bios.bin isn`t in the BIOS folder even though its listed in the BIOSCopy.csv file. The bios is 084A8 ,check your bios backup to make sure its the right one. Strangely the bios is included with an earlier version of the 4-in-one key for other models but not listed in the .csv , thanks HP ! .
      Bios 084A8.bin attached .
      • reset1986
        • Dec 2014
        • 340
        • italia
        Thank you very much for the advice,
        i can't write bios with with Win + b,
        the tl866cs timer does not recognize me the main bios chip signed xmc qu64ah1g
        but I managed to dump 8mb by checking the check id, I attach the dump,
        the bid version 084AA
        i think the tl866cs will give writing problems for this i am trying to use the WIN + B procedure,
        I prepare the usb key and copy the bios to the current folder, I rename it 084AA.bin but it gives me error "Bios ID of Image does not match system"
        you also need another 084AA.s12 file
        thanks for the help
          • 25766
          Flash this bios with your programmer, use w25q128fv in the list,untick check-id .
          • reset1986
            • Dec 2014
            • 340
            • italia
            ok, I selected w25q128fv from the tl866cs and redone an original dump, the file is 16Mb I attach the corrupt 16mb dump, I found that by clearing the control id that I can write, I flash a 16mb file found on google but on the black screen
            It was my mistake the 8mb dump, I had selected the 8mb programmer memory
            Is it possible repair 16 Mb dump?
              • 25766
              My mistake telling you to use w25q128fv.
              If you only have an 8MB bios then flash the bios i posted again,this time using W25Q64FW .
              • reset1986
                • Dec 2014
                • 340
                • italia
                followed the instructions, bios spelled correctly, thanks you
                • RAVI KARAN
                  • May 2020
                  • 54
                  • INDIA
                  Share motherboard part no. Or upload m/b part no. Image
                  • reset1986
                    • Dec 2014
                    • 340
                    • italia
                    mainboard EPK50 LA-G073P
                    • Aditya11ttt
                      • Feb 2019
                      • 200
                      • India
                      • Knowledge
                      use this W25Q64JVSSIQ
                      • beppe84
                        • Sep 2020
                        • italy
                        hi, i have exactly this problem, same laptop same mb, bios update loop, sorry im a noob, can i ask if the problem has been resolved with or without tl866cs programmer ?
                        Thanks for your patience
                        • MEMETRONIK
                          • May 2020
                          • México
                          I was able to program qu64ah1g in the tl866 selecting MX25U6435F 1.8V, I leave you more versions of bios with the .s12 files for LA-G073P
                          • gerardo
                            Engineer
                            • Feb 2016
                            • 60
                            • Argentina
                            Thanks! @MEMETRONIK It helped me, I also managed to read the eeprom using this model (without 1.8v adapter)
                            • Drivit
                              • Mar 2021
                              • 5
                              • Mexico
                              Hi, guys! I have this laptop: HP Notebook 15-da0019la, with frozen BIOS after a Windows update.
                              I have the same main board (EPK50 LA-G073P) and the same BIOS chip (XM25QU64A). I tried to reprogram my chip with an EZP2019 (using the 084A8.bin file) and everything went well. But when I turned up the laptop, the caps lock was blinking the code 5.3. So, I tried with another BIOS file (084AA.bin), but again I got the 5.3 code blinking.
                              My last chance is to use the 084A6.bin file (which is included in the HP BIOS Utility for my laptop: https://support.hp.com/us-en/drivers...model/21909979), because this utility extracts the bin files that I mentioned, and I tried with two of them, but nothing working yet.
                              I'm afraid to try again and get nothing but a 5.3 blinking code.
                              Any suggestions? I really appreciate your help!
                              • 69d0b913
                                • Mar 2018
                                • 146
                                • BR
                                • Computing, Machines, Motorcycles, Cars
                                I had a problem with a Dell 5410 XMC chip, it just solved without errors after selecting that chip model. MX25U6435F 1.8V
                                • digix
                                  • Nov 2013
                                  • 19
                                  • România
                                  Hi ! I need a bios dump for HP 250 G7, mainboard GPI52 LA-J951P Rev:1.0 chip XMC QH128AHIG.
                                  • peste
                                    • 16564
                                    • ROMANIA
                                    try..
                                    If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
                                    It only takes 1 minute:
                                    https://www.badcaps.net/settings/subscriptions
                                    • tsok
                                      • Feb 2019
                                      • 14
                                      • philippines
                                      need help po to clean my LA-G073P bios backup
                                      need help po to clean my bios backup issue blinks the code 5.3 in the caps lock
                                      thank you much guys and admin
                                      Brand:hp
                                      Model:15-0014tu[bckup
                                      Board Code:EPK50 LA-G073P Rev: 1.0
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12710
                                        Re: need help po to clean my bios backup thank admin
                                        Brand:hp
                                        Did you try to clear ME this bios before?
                                        If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
                                        Subscribe to support us. It only takes 1 minute:
                                        • Bloodhoundje
                                          by Bloodhoundje
                                          03-16-2024, 03:12 PM
                                        • TripTop
                                          Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                                          by TripTop
                                          Hi
                                          i have dell latitude E7270 with following symptoms:
                                          - takes long time to restart.
                                          - sometimes powers on and then off
                                          - sometimes while working it just dies,
                                          From googling online bios clean could possible resolve this?
                                          i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                                          As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                                          I reinstall...
                                          09-09-2024, 02:05 PM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • Trademark
                                          Acer Predator Triton 16 PT16-51-99GL (DA0ZQDMB8AE Rev. E) - Looking for original 32MB BIOS dump (Winbond W25Q256JVEN)
                                          by Trademark
                                          I’m hoping someone can help me locate a verified original BIOS dump for my Acer laptop.
                                          This is NOT a BIOS password removal request.
                                          I’m looking for an original 32MB SPI BIOS dump to use as a reference in case my BIOS firmware is corrupted. My plan is to first dump and back up my own BIOS as soon as my programmer arrives. I am not planning to blindly flash someone else’s BIOS.
                                          Laptop Information
                                          • Model: Acer Predator Triton 16 PT16-51-99GL
                                          • Motherboard: DA0ZQDMB8AE Rev. E
                                          • Main SPI flash: Winbond W25Q256JVEN (32MB)
                                          • Secondary
                                          07-22-2026, 08:57 AM
                                        • cr4zychriss
                                          by cr4zychriss
                                          • Rebrand: PC Specialist
                                          11-14-2025, 04:04 PM
