hp 640 g2 password need bios dump
  • powervc
    • Feb 2023
    • 9
    • canada
    #221
    Hi, Who can help me to retrieve the password from the BIOS file?
    I read a lot of post and search the website, but it is not easy for me.
    The model is is HP 640G2. bios file attached.
    I appreciate your help.
    • hoaca388
      Badcaps
      • Jan 2022
      • 11906
      #222
      Rule 1: post serial number. This is a forum rule.
      Rule 2: use RC unlocker.
        • 21219
        Thread merged. You can unlock it yourself as Hoaca388 has said - https://www.badcaps.net/forum/troubl...19#post1808619
        • powervc
          • Feb 2023
          • 9
          • canada
          #224
          Got it, Thank you for your reply. I can do RC unlocker, but I have a few of laptops are with same password, I worry about to damage the chipor motherboard when I remove chip from mothermboard, one motherboard was broken because I'm not a professonal soldering guy.
          If it is possiable to retrive the password from bios file, it would be helpful. Thank you.
          • hoaca388
            Badcaps
            • Jan 2022
            • 11906
            #225
            That is impossible.
            • powervc
              • Feb 2023
              • 9
              • canada
              #226
              That is impossible.
              Thank you so much. I got it. Is it possible to flash a unlocked bios file to same password laptop? so as to save time to unlock it one by one. Thank you.
              • hoaca388
                Badcaps
                • Jan 2022
                • 11906
                #227
                Bạn dùng lập trình viên nào ?
                Try the clip. Click image for larger version  Name:	2024-08-05 22_04_29-Kẹp Thử SOIC8 SOP8 Cho Lập Trình EEPROM 93CXX _ 25CXX _ 24CXX + 2 Bộ Điều Hợp _ .png Views:	0 Size:	1.11 MB ID:	3323001
                • powervc
                  • Feb 2023
                  • 9
                  • canada
                  #228
                  I'm using a RT809F serial ISP Programmer, I can buy one clip and try it. Thank you
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11906
                    #229
                    I think RT809F can be used with clamp.
                    • powervc
                      • Feb 2023
                      • 9
                      • canada
                      #230
                      Thank you. do you have a universal BIOS file for HP640G2? so I just flash it without unlock it? Thank you.
                      • powervc
                        • Feb 2023
                        • 9
                        • canada
                        #231
                        I tried a few BIOS from here, the result is as follows:
                        HP640G2 cleared ME .bin : It works, but there is a red bar on the top when boot, it says Manufacture mode
                        N76 0145.bin, doesn't work
                        Ir Factory unlock.bin, it works, but it is very very slow to boot
                        pssw 640G2 unlock.bin, it doesn't work.
                        Any suggestions? hoaca388 Thank you.
                          • 21219
                          HP640G2 cleared ME .bin : It works, but there is a red bar on the top when boot, it says Manufacture mode ( Use HP Bios Config Utility to fill in the DMI )
                          Ir Factory unlock.bin, it works, but it is very very slow to boot (Clean the ME firmware )
                          Unlock the original bios per machine,one at a time.
                          • powervc
                            • Feb 2023
                            • 9
                            • canada
                            #233
                            Hi Man, Thank you for your reply. could you please help me to Clean the ME firmware for my unlock file? I read a few postings and download some prgoram, but I can not make it successful.
                            Thank you.
                            • ragoub44
                              • Feb 2022
                              • 6
                              • morocco
                              #234
                              HP 640 G2
                              AFER BIOS UNLOCK WHITE RCUnlocker MY HP takes a long time to start up
                              can anyone help me TO CLEAN ME REGION FOR MY BIOS
                            • shiyab
                              • Sep 2023
                              • 1506
                              • india
                              #235
                              Originally posted by ragoub44
                              HP 640 G2
                              fixed me
                                SMDFlea commented
                                Editing a comment
                                Do not help until the serial number/SNID or service tag is posted please ...........
                            • sancheti81
                              • May 2014
                              • 191
                              • India
                              #236
                              hp 640 g2 bios password
                              please help to clear bios password
                              serial number : 5CG6351YK6
                              • LBTT1121
                                • Nov 2024
                                • 619
                                • Việt Nam
                                #237
                                hi, try and feedback
                                • sancheti81
                                  • May 2014
                                  • 191
                                  • India
                                  #238
                                  THANKS
                                  • zonkil
                                    • Mar 2018
                                    • Karkow
                                    #239
                                    Hello i need reset password.
                                    ProductName HP ProBook 640 G2
                                    Processor1 Intel(R)Core(TM) i5-6300UCPU@2.40GHz
                                    Memory Size 8192MB
                                    SystemBIOS N76Ver.01.07 04/18/2017
                                    SERVICE
                                    BornOnDate 00/00/000000/00/0000
                                    SerialNumber 5CG7190TFH
                                    SKUNumber X8T44EP#ABB
                                    Universally Unique Identifier (UUID) D1936296-346F-11E7-B13B-641CE402A013
                                    Asset Tracking Number 5CG7190TFH
                                    Feature Byte 3Q3X476J6S6Z6b7H7M7Q7W7saBaEapaqauawbtdUdpdqgd.FE
                                    System BoardD 80FD
                                    System BoardCTNumber PFKCT00WB764MT
                                    • piszpunta
                                      • Jan 2019
                                      • 249
                                      • poland
                                      #240
                                      Originally posted by zonkil
                                      Excuse my mistake.
                                      Please delete the previous post.
                                      Memory Size 8192MB
                                      SERVICE
                                      System BoardD 80FD
                                      System BoardCTNumber PFKCT00WB764MT​
                                      try
                                      • Buzzfuzz2k
                                        Bios password removal on a Unowhy dump
                                        by Buzzfuzz2k
                                        Hi Everyone,
                                        I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                        The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                        the Computer is a Unowhy small pc
                                        N° UYM6524702229
                                        After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                        My first attempt was to get the bios dump from windows...
                                        11-13-2023, 07:37 AM
                                      • traxformania
                                        TONGFANG "GM7TG7P" Bios Password Problem?
                                        by traxformania
                                        I tried :
                                        -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                        11-15-2023, 07:32 AM
                                      • Nopslide
                                        by Nopslide
                                        04-01-2024, 04:27 PM
                                      • outsider
                                        Panasonic FZ-G1 MK5 - BIOS password returning
                                        by outsider
                                        Hello
                                        I removed the BIOS password thanks to the help of one of the friends of this forum.
                                        https://www.badcaps.net/forum/troubl...61#post3637661
                                        The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                        06-17-2025, 12:51 AM
                                      • kingiii
                                        downloaded bios is smaller than the original bios dump
                                        by kingiii
                                        Can someone help me explain how to fix the original bios when downloaded and exacted bios is much smaller than the original one?
                                        Thank you very much
                                        06-07-2025, 04:21 PM
