hp 640 g2 password need bios dump
    Hi, Who can help me to retrieve the password from the BIOS file?
    I read a lot of post and search the website, but it is not easy for me.
    The model is is HP 640G2. bios file attached.
    I appreciate your help.
      Rule 1: post serial number. This is a forum rule.
      Rule 2: use RC unlocker.
      Become a Badcaps supporter
      Thanks to all supporters.
        Thread merged. You can unlock it yourself as Hoaca388 has said - https://www.badcaps.net/forum/troubl...19#post1808619
          Got it, Thank you for your reply. I can do RC unlocker, but I have a few of laptops are with same password, I worry about to damage the chipor motherboard when I remove chip from mothermboard, one motherboard was broken because I'm not a professonal soldering guy.
          If it is possiable to retrive the password from bios file, it would be helpful. Thank you.
            That is impossible.
              That is impossible.
              Thank you so much. I got it. Is it possible to flash a unlocked bios file to same password laptop? so as to save time to unlock it one by one. Thank you.
                Bạn dùng lập trình viên nào ?
                Try the clip. Click image for larger version  Name:	2024-08-05 22_04_29-Kẹp Thử SOIC8 SOP8 Cho Lập Trình EEPROM 93CXX _ 25CXX _ 24CXX + 2 Bộ Điều Hợp _ .png Views:	0 Size:	1.11 MB ID:	3323001
                  I'm using a RT809F serial ISP Programmer, I can buy one clip and try it. Thank you
                    I think RT809F can be used with clamp.
                      Thank you. do you have a universal BIOS file for HP640G2? so I just flash it without unlock it? Thank you.
                        I tried a few BIOS from here, the result is as follows:
                        HP640G2 cleared ME .bin : It works, but there is a red bar on the top when boot, it says Manufacture mode
                        N76 0145.bin, doesn't work
                        Ir Factory unlock.bin, it works, but it is very very slow to boot
                        pssw 640G2 unlock.bin, it doesn't work.
                        Any suggestions? hoaca388 Thank you.
                          HP640G2 cleared ME .bin : It works, but there is a red bar on the top when boot, it says Manufacture mode ( Use HP Bios Config Utility to fill in the DMI )
                          Ir Factory unlock.bin, it works, but it is very very slow to boot (Clean the ME firmware )
                          Unlock the original bios per machine,one at a time.
                            Hi Man, Thank you for your reply. could you please help me to Clean the ME firmware for my unlock file? I read a few postings and download some prgoram, but I can not make it successful.
                            Thank you.
                              HP 640 G2
                              AFER BIOS UNLOCK WHITE RCUnlocker MY HP takes a long time to start up
                              can anyone help me TO CLEAN ME REGION FOR MY BIOS
                              Originally posted by ragoub44 View Post
                              HP 640 G2
                              fixed me
                                SMDFlea commented
                                Editing a comment
                                Do not help until the serial number/SNID or service tag is posted please ...........
                              hp 640 g2 bios password
                              please help to clear bios password
                              serial number : 5CG6351YK6
                                hi, try and feedback
                                  THANKS
