hp 640 g2 password need bios dump
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria šŸ‡§šŸ‡¬
    #61
    Re: hp Probook 640 g2 bios password
    Originally posted by SMDFlea
    The ME firmware in your bios was corrupt.Try this bios with your pass removed and new ME firmware .
    Probably the chip was not read correctly, and the dump posted by theGenova is corrupted.
    Yes indeed, just checked the file too:
    Become a Badcaps supporter
    Thanks to all supporters.​
    • Genova
      • Jan 2020
      • 116
      • FRANCE
      #62
      We are programming 640G2_ME CLEAN with AsProgrammer 1.41 with the unlock, erase, programm, verify.
      In progress...
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria šŸ‡§šŸ‡¬
        #63
        Originally posted by Genova
        How can i read in total commander the content of the chip ??
        Check the pictures:
        • Genova
          • Jan 2020
          • 116
          • FRANCE
          #64
          Originally posted by Vesko356
          Check the pictures:
          So after programming the file 640G2_ME CLEAN into the bios i need to save the the bios to a new file to compare ?
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria šŸ‡§šŸ‡¬
            #65
            After programming just close the AsProgrammer, open the program again, read the content of the chip, save the file as let's say TEST.bin, then compare the TEST.bin with the 640G2_ME CLEAN.bin with the Total Commander.
            • Genova
              • Jan 2020
              • 116
              • FRANCE
              #66
              The two files are identical
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria šŸ‡§šŸ‡¬
                #67
                Excellent, so you do the programming of the chip fine.
                Try to power up the laptop.
                • Genova
                  • Jan 2020
                  • 116
                  • FRANCE
                  #68
                  Exactly the same, num lock and maj flashing 7x
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria šŸ‡§šŸ‡¬
                    #69
                    OK, since your initial dump was apparently corrupted there is no need to try again with it, try the dump in that post, it should be OK.
                    HERE:
                    • Genova
                      • Jan 2020
                      • 116
                      • FRANCE
                      #70
                      OMG you are amazing guys !
                      After some bip bip bip the laptop coming back to life.
                      Just a red message in top : blabla in manufacturing Mode....34
                      Enter in bios is good no password now
                      Have to go home, the rest of the adventure: tomorrow
                      Thanks again to all here for your precious help
                      • Genova
                        • Jan 2020
                        • 116
                        • FRANCE
                        #71
                        just a little feedback about manufacturing mode after flash with HP640G2 cleared ME region file.
                        After found all specs about the laptops, serial, uuid, etc..
                        Laptop is now fully functional thanks again to all member for help provided
                        • damian13030
                          • Mar 2020
                          • 10
                          • Polska
                          #72
                          Re: hp 640 g2 need bios dump
                          Hello I have HP probook 640g2, (i5 6300) I have fault 3/2 and 2/2 (bios) .Will the other bios from the posts above work?
                          • peste
                            • Dec 2016
                            • 12806
                            • ROMANIA
                            #73
                            put the bios backup here
                            • damian13030
                              • Mar 2020
                              • 10
                              • Polska
                              #74
                              Someone has already soldered, I don't know if it is original.
                              • peste
                                • Dec 2016
                                • 12806
                                • ROMANIA
                                #75
                                try..
                                • damian13030
                                  • Mar 2020
                                  • 10
                                  • Polska
                                  #76
                                  not work, the same fault.
                                  • peste
                                    • Dec 2016
                                    • 12806
                                    • ROMANIA
                                    #77
                                    try that too..
                                    • damian13030
                                      • Mar 2020
                                      • 10
                                      • Polska
                                      #78
                                      not work.
                                        • 20898
                                        Originally posted by damian13030
                                        not work.
                                        Can you post a picture of the serial number on the base cover sticker, or write it here.
                                        • damian13030
                                          • Mar 2020
                                          • 10
                                          • Polska
                                          #80
                                          Stickers in motherboard
                                          • Buzzfuzz2k
                                            Bios password removal on a Unowhy dump
                                            by Buzzfuzz2k
                                            Hi Everyone,
                                            I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                            The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                            the Computer is a Unowhy small pc
                                            N° UYM6524702229
                                            After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                            My first attempt was to get the bios dump from windows...
                                            11-13-2023, 07:37 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
                                          • kingiii
                                            downloaded bios is smaller than the original bios dump
                                            by kingiii
                                            Can someone help me explain how to fix the original bios when downloaded and exacted bios is much smaller than the original one?
                                            Thank you very much
                                            06-07-2025, 04:21 PM
