EFIBIN File MacBook Air A1466 (EMC 2632) 820-3437-B
hi all
i need unlock this efi files for macbook air a1466
Attached FilesComment
Every donation made will go towards server fees and maintenance costs.Comment
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
S/N C02N34GMG086
I lost my old bios region and tried all bios but the ssd won't boot in any biosAttached FilesComment
hi please can someone help me with this '
Device: Laptop
Brand: Apple
Model: Macbook A1466 emc 2632
Board number: 820-3437-a
Request: ME Cleaning, repairAttached FilesComment
hi there all techs
bios attached , from macbook 820-00165-A
some idiot flashed bios laptop works but serial info wrong require assistance in changing please
MacBook pro
model A1466
EMC 3178
serial C1MTQ9RKJ1WK
14.85V 3.05A max
MacBook Air "Core i5" 1.8 13" (2017) 1.8 GHz Core i5 (I5-5350U)
also what software is required for next time please
thanks in advance
god bless
Try thisAttached FilesComment
someone help me please remove efi password
Model - A1466
Boardcode - 820-3437-a
emc -2925
serial - C1MRM7PYH3QDAttached FilesComment
TryAttached Files↵
https://www.badcaps.net/donateComment
RetryAttached Files↵
by psdavid65I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
Channel: BIOS Requests ONLY!
by echothegamerHello all,
Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
Details:
Macbook 13' A1466
Board (820-3209-A)
Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
Pictures below of Boardview and schematic...
I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
It's an older model and it is very likely that battery has become... -
by kenzo2I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
I need dump file MACBOOK PRO A2159
TSB4232(256)
TSB4229(256)
Thanks -
by dbuergiHi all,
i got a A1466 with serious water damage. I was able to clean the whole board and only found a fuse with a coroded trace. Cleaning and resoldering did the job and the macbook started normal but after some time the screen began "flashing" like turning on and off while the Macbook was still running. I checked the board again but was not able to find the problem until now.
Any ideas where to look?... - Loading...
