Need unlocked Zbook 15 G5 BIOS, dump enclosed
  • Needpass
    • Oct 2019
    • 7
    Looking to remove password from attached dump, thanks in advance!
  • marcin02152
    • Oct 2014
    • 134
    • Polska
    Re: Need unlocked Zbook 15 G5 BIOS, dump enclosed
    try this tool
    https://www.badcaps.net/forum/showpo...43&postcount=1
    • peste
      • 12911
      • ROMANIA
      try ... I used this tool...https://www.badcaps.net/forum/showpo...43&postcount=1
      • Needpass
        • Oct 2019
        • 7
        Thanks, I tried to flash the new image using FPWT64 but I'm getting this error:
        "Error 167: Protected range registers are currently set by bios, preventing flash access"
        I don't have a programmer and the machine is thousands of miles away. I'm trying to help a friend. Does anyone know of a way around this?
        • RethoricalCheese
          • Mar 2013
          • 1518
          • Estonia
          No, you need either programmer and soic8 clip or SMC.bin file from HP (but they don't give them anymore).
          Third way is to figure out the password. Some information is in this topic: https://www.badcaps.net/forum/showth...&highlight=840
          • Needpass
            • Oct 2019
            • 7
            I found a post on another site with a similar error #. They were able to boot to an EFI shell and run a command that toggled the BIOS lock bit. The address was found by using UEFITool but in the setup module but I can't find such a module in this BIOS.
            Here is the post:
            *************************d.com/t3908f16-GUIDE-Grub-Fix-Intel-FPT-Error-or-BIOS-Lock-Asus-Other-Mod-BIOS-Flash.html[/url]
            • AudioGuy88
              • Jun 2020
              • 35
              HP Zbook 15 G5 with Admin Bios PW
              Hi Everyone
              I have an HP Zbook 15 G5 laptop with admin bios password.
              Everything works (I'm using it right now) but can't change any bios settings or update bios.
              From what I've read I can read (dump) the data from the bios chip and there may be ways to remove the bios pw.
              I have ordered a CH341 programmer and waiting for it to arrive.
              I am pretty good with electronics and am confident I can read/write to the bios.
              I understand the chip is MX25L25673GZ4I-08G and the footprint is 8WSON. I couldn't find any clips for that footprint.
              To make sure I'm on the right track with my research is correct.
              Is the only way to read directly from the chip and paste it here and request for help? If so, can I solder wires to the pins while on the board? Or do I need to remove the chip from the board?
              TIA
              • Duranitron
                • Jul 2014
                • 544
                • Philippines
                Re: HP Zbook 15 G5 with Admin Bios PW
                first thing to consider is to find a working bios dump for your laptop model you can search it here in badcaps.net . you need to a take the bios ic out of the mobo to program it.. before you program your bios make sure to save the old bios file as backup. so that you can restore is back to original state if none of the bios dump you download works. hot air soldering tool is also needed to safely take off the chip. but if you are an experienced technician you can safely desolder the chip with just a soldering iron..gud luck ....
                • AudioGuy88
                  • Jun 2020
                  • 35
                  So to confirm a few things.
                  1. I'll have to remove the chip in order to read/write from it?
                  2. Rather than cleaning or removing the pw from my bios, the idea is to find a clean one and use that?
                    • 21117
                    You have a WSON8 chip,there`s a centre pad thats soldered so you can`t desolder with a soldering iron,you`d need to use a hot-air station to desolder it (don`t use a paintstripper type heat gun,you`ll damage the board).If you desolder it then you`ll need to use a WSON8 adapter, solder wires to the chip,or modify an existing adapter with jumper wires. https://www.aliexpress.com/item/32802865327.html
                    The board might also have the pads/footprint for a SOP8 chip, if it does you can solder wires to the pads,then to your adapter.
                    Either way, once you have a backup post it in the "Bios Requests ONLY!" sub-forum and one of the members will clean the pass for you.
                    Oh,and the software that comes with the CH341A is crap, use AsProgrammer instead - https://www.badcaps.net/forum/showpo...6&postcount=10
                    • AudioGuy88
                      • Jun 2020
                      • 35
                      I had no idea the WSON8 chip would be such a PITA.
                      I don't have a hot-air station. So already it's sounds like a more expensive and complicated exercise than I had anticipated.
                      Let's go down another route.
                      The laptop is still under warranty from HP, but the password issue is not covered (they quoted $1700+ AUD to replace the motherboard).
                      However if the motherboard was damaged or faulty, then it would be replaced for free under warranty.
                      Is there a simple way to make the motherboard faulty?
                      • Duranitron
                        • Jul 2014
                        • 544
                        • Philippines
                        i agree with smdflea you need a hot air station for that because the ic is soldered under the chip.. you can try to use a clip on to connect to the bios ic but there is only 60% chance of success. try it...
                        • AudioGuy88
                          • Jun 2020
                          • 35
                          I got the reader and I think I'm able to read the chip ... I soldered some wires to the chip on the board and took the wires to the 341A.
                          What chip/profile do I use to read the chip?
                          The writing on the chip says what looks like
                          NX25L25679GZ41-08G
                          The closest I can find was MX25L25635E (MACRONIX) and it seems to have read it ok.
                          I will upload to bios requests and ask for help, assuming it's ok.
                          Did I read it correctly? Or should I be using a different profile?
                          • AudioGuy88
                            • Jun 2020
                            • 35
                            Help remove HP Zbook 15 G5 Admin PW
                            I have an HP Zbook 15 G5 with an admin bios password.
                            Is anyone able to remove this for me?
                            • lapfix
                              • Mar 2020
                              • 2741
                              • my workshop
                              Re: Help remove HP Zbook 15 G5 Admin PW
                              Try
                              • Alassane
                                • Oct 2018
                                • 65
                                • MALI
                                good evening can someone help me to unlock my bios bin HP Zbook 15 G5. I tried with hpUnlockerTool but it didn't work. AND there is still the password. Here is my bios bin and the cell I made with hpUnlockerTool :
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  Upload the dump from the second chip - this will be easiest way to unlock, or if you prefer the file you've already attached can be edited to boot in MPM mode, but you'll have to manually input all DMI information later.
                                  Become a Badcaps supporter
                                  Thanks to all supporters.​
                                  • Alassane
                                    • Oct 2018
                                    • 65
                                    • MALI
                                    Ok I will send you the second dump right away. Anyway I looked there is no password in this dump.
                                    • Alassane
                                      • Oct 2018
                                      • 65
                                      • MALI
                                      here is :
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        here is :
                                        Use the RCUnlocker with that dump, leave the main dump (32MB) unmodified (original). At first boot reset bios settings to factory default, save/apply, then reset security settings and restart. That's it.
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • loopster
                                          Need help cleaning ME region on Zbook 17 G1 bios dump
                                          by loopster
                                          Hello guys,
                                          could I please get some help cleaning the ME region of the attached Zbook 17 G1 bios dump (CH341a, neoprogrammer, chip-desoldered, dumped twice, identical checksum)?
                                          Symptoms, delayed BIOS post (ca. 45 secs.) keyboard not working, touchpad not working, booting linux live, console says "Management engine not configured".
                                          I tried following the ME firmware cleaning guide, but whatever Flash Image Tool version I try, I get the same error:
                                          Error 10: Failed to open with processed commands.
                                          Unable to open file: C:\Users\Elitebook...
                                          06-16-2024, 09:57 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
