Need unlocked Zbook 15 G5 BIOS, dump enclosed
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Re: Need unlocked Zbook 15 G5 BIOS, dump enclosed
https://www.badcaps.net/forum/forumdisplay.php?f=41
Reminder: rules and organization of this section
https://www.badcaps.net/forum/showthread.php?t=117483
Read the rules before posting:
You MUST:
Read BIOS guides, methods, resources and tools
Try the method at BIOS guides, methods, resources and tools before requesting help
Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
Use search function in case someone already answered your request
Post under a related thread if it exists
Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
Name your thread with model numbers and request
Provide a BIOS/EC dump if possible
Attach files directly to your post instead of linking to external websites
Schematic Requests ONLY!
You MUST:
Alright noted,thank youComment
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
tryAttached FilesComment
Hi
I have Zbook G5 workstation with bios password
SN 2tk94304vs
sku 6xf92av
RCUnlocker_v_1_0 didn`t work for me
I will appreciate your help
thanks
Please read the rules, type as text the laptop serial number --> https://www.badcaps.net/forum/troubl...before-posting
Hello, I need a help. I removed second bios chip from mb and programmed with your second bios dump. It is working without bios password, but I have a another problem now. After changing it I get "there is a problem with the Endpoint security controller on this device". And I can not disable it or remove. I put old bios image back but it is again with bios passwordI send to you my original second bios bin. May be can you help me with unlocking it? Many thanks
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by loopsterHello guys,
could I please get some help cleaning the ME region of the attached Zbook 17 G1 bios dump (CH341a, neoprogrammer, chip-desoldered, dumped twice, identical checksum)?
Symptoms, delayed BIOS post (ca. 45 secs.) keyboard not working, touchpad not working, booting linux live, console says "Management engine not configured".
I tried following the ME firmware cleaning guide, but whatever Flash Image Tool version I try, I get the same error:
Error 10: Failed to open with processed commands.
Unable to open file: C:\Users\Elitebook...1 Photo-
Channel: BIOS Requests ONLY!
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by il60Hello,
i have an zbook 17 g3, i updated the bios, but the computer crash during update
now black screen
may you repair my bios in order to have work bios but keep all hp information (DMI sn..)
dump attached,
big thank you !!!...-
by grimacelordThis laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
Motherboard model number: DA0PAMB46A1 REV: A
Secondary motherboard model number: 0PAB
SKU: 685K4UA
Serial number is: 5CD3223BJP
Recently reflashed this laptop with latest BIOS and once...-
- Loading...
