Asus x542u clean me bios need
  • ay_bulut
    • Feb 2016
    • 114
    • turkey
    MODEL :ASUS X542U
    CASE CODE : X542UR-GQ277T
    MAİNBOARD MODEL : X542UQ MAIN BOARD REV 2.0
    Backup bios : https://www.badcaps.net/forum/attach...0&d=1566396900
  • peste
    • Dec 2016
    • 12868
    • ROMANIA
    Re: Asus x542u clean me bios need
    try..
    https://www.badcaps.net/forum/showthread.php?t=77618
    • peste
      • Dec 2016
      • 12868
      • ROMANIA
      try..
      • ay_bulut
        • Feb 2016
        • 114
        • turkey
        i tried these
        opening late
        • peste
          • Dec 2016
          • 12868
          • ROMANIA
          try..
          • ay_bulut
            • Feb 2016
            • 114
            • turkey
            Originally posted by peste
            try..
            not working
            • peste
              • Dec 2016
              • 12868
              • ROMANIA
              try this one
              • ay_bulut
                • Feb 2016
                • 114
                • turkey
                try this one
                cleaning the me region please
                  • 21002
                  That bios has got clean ME firmware. Don`t you have the original bios backup ? Did you make a backup before trying any other bios.The link you posted at post #1 isn`t your bios is it,it from another thread on badcaps.
                  • peste
                    • Dec 2016
                    • 12868
                    • ROMANIA
                    try again
                    • ay_bulut
                      • Feb 2016
                      • 114
                      • turkey
                      there is
                        • 21002
                        Try this one,if its still opening late run Flash programming tool from dos,uefi or windows from the command line with this switch -greset e.g. if you run the win64 version from the command line then run:
                        FPTW64.exe -greset
                        • ay_bulut
                          • Feb 2016
                          • 114
                          • turkey
                          FPTW64.exe -greset
                          I tried , it is opening fastly but closing slowly.
                            • 21002
                            If its starting up quickly the bios is fixed.Shutting down slowly is a problem with windows 10,drivers,hard drive or other hardware.
                            • String2016
                              • Nov 2015
                              • 2238
                              • philippines
                              shutting down slowly cause by a bad hard drive or windows problem
                              • ay_bulut
                                • Feb 2016
                                • 114
                                • turkey
                                I understand. Thank you very much for your attention.
                                • battery.12v
                                  • 123
                                  • NW
                                  FPTW64.exe -greset
                                  You are the Savior !!!!
                                  Thank you a lot Bro
                                  • bilen
                                    • Aug 2014
                                    • 638
                                    • istanbul
                                    FPTW64.exe -greset
                                    i5 7th cpu and 930mx %100 working
                                    • razor_amd
                                      by razor_amd
                                      12-15-2020, 07:07 PM
                                    • grimacelord
                                      by grimacelord
                                      07-10-2025, 02:52 PM
                                    • jbonavita
                                      by jbonavita
                                      Some issues
                                      Things I tried
                                      04-29-2025, 09:38 PM
                                    • throwaway327
                                      by throwaway327
                                      Model No: RC72LA
                                      Serial No: SBNVKD001014459
                                      06-18-2025, 05:52 PM
                                    • lrouw84
                                      by lrouw84
                                      Hi there,
                                      01-28-2023, 01:31 PM
