Asus x542uq rev 2.0 bios
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi I need a bios for this motherboard , I cant make it power on it just pump 800 milliamp on the board
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Asus x542uq rev 2.0 bios
    post your dump here as asus provides only update file.
    • cacla
      • Apr 2015
      • 444
      There is 2 models here are 2 bios one is yours
      • sel3370
        • Aug 2017
        • 18
        • turkey
        Thank you test ok
        • ahmetermin
          • Mar 2015
          • 38
          • batman
          asus x542ur-GQ276
          MOTHERBOARD :Asus x542uq rev 2.0 bios plase
          • peste
            • Dec 2016
            • 13451
            • ROMANIA
            Try..
            • cengiz47
              • Feb 2020
              • 1
              • türkiye
              thanks my friend
              • vougheart
                • Jul 2020
                • 65
                • philippines
                can anyone tested file for my no display same board?
                • peste
                  • Dec 2016
                  • 13451
                  • ROMANIA
                  post the original laptop bios
                  • jocig58297
                    • Jan 2021
                    • 7
                    • ds
                    Hi i've an ASUS X542UR laptop, i need a BIOS Firmware is the X542UR-AS.rar good? i dumped one, i think is good.
                    • jocig58297
                      • Jan 2021
                      • 7
                      • ds
                      Hi, do you have any suggestion for that laptop
                      How can i send the fw that i dumped?
                      • Mazorca
                        • Jan 2017
                        • 463
                        Compress the dump, usually it's a .bin file with Winrar or similar, then add as an attachment to your reply.
                        • jocig58297
                          • Jan 2021
                          • 7
                          • ds
                          I dumped this and verified 6 times, so i think it's a good image.
                          This dump works, but it ask an unknow password at bios startup and i cannot go into Windows.
                          I dind't read the allowed file type... i was using a 7z file...
                          • Mazorca
                            • Jan 2017
                            • 463
                            Your file decompresses to 8,193 KB, I don't know if that is a problem. I managed to get a cleaned ME Region. Try it and give feedback please.
                            • jocig58297
                              • Jan 2021
                              • 7
                              • ds
                              u're right, it's better i try to dump it again?
                              • jocig58297
                                • Jan 2021
                                • 7
                                • ds
                                flashed, but it's still asking for that password, and i cannot enter the BIOS or start Windows
                                • Mazorca
                                  • Jan 2017
                                  • 463
                                  What is the date that it gives you? Press ALT key + r key then look at date. Another way is to remove the CMOS battery and/or the main battery if it doesn't have one, in order to reset the BIOS date to the earliest one possible. Then look for that date/password in the internet for Asus.
                                  • jocig58297
                                    • Jan 2021
                                    • 7
                                    • ds
                                    new laptops not have data, alt+r trick not working and there's no CMOS battery.
                                    For this reason i'm looking for a new flash
                                      • 21692
                                      The password is: nuovapasswordpc
                                      • jocig58297
                                        • Jan 2021
                                        • 7
                                        • ds
                                        wow...u're right, man!! i'm crying!!! How??? Tell me, please!!!
                                        • razor_amd
                                          [TUTORIAL] fix asus bios with bios from asus web support (by razor_amd)
                                          by razor_amd
                                          With ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
                                          For example, you can have 3 similar ASUS motherboards, all being the same model, all of which will have different BIOS versions.
                                          I will give you an example and my version of preparing BIOS from ASUS website and in the process I am always cleaning Intel ME while doing it so you have fully cleaned BIOS, no DMI data, no password, nothing.
                                          This is the picture of 3 similar ASUS motherboards, all of them being X555LD...
                                          12-15-2020, 07:07 PM
                                        • grimacelord
                                          ASUS TUF GAMING Z790-PLUS WIFI - BIOS Help
                                          by grimacelord
                                          I have spent the last hour on this and I guess this is just over my head, so here I am.
                                          I have an ASUS TUF GAMING Z790-PLUS WIFI motherboard here that needs to have the BIOS updated in order to accept the latest CPUs.
                                          The BIOS chips seem to come as a set of two: GD25B64ESIG and GD25B128ESIG. My guess is one of them is a fail-safe for the main BIOS? I really don't know. Or one of them is ME and other is BIOS? I don't know.
                                          Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...
                                          07-10-2025, 02:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • throwaway327
                                          Asus ROG Ally X -RC72LA - changed hidden bios settings with 'Smokeless-UMAF', won't get past boot logo
                                          by throwaway327
                                          ASUS ROG Ally X - (Handheld Gaming PC)
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          Hi all, I've spent the past week digging through the forums and guides to try correct my foolish mistake of changing hidden settings while tinkering around, and to be honest my heads overloaded so I'm hoping you'll be able to help.
                                          I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...
                                          06-18-2025, 05:52 PM
                                        • lrouw84
                                          Asus vivobook s510ua bios changed to x510un
                                          by lrouw84
                                          Hi there,
                                          I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                                          I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                                          01-28-2023, 01:31 PM
