need dell 7559 daam9amb8d0 ec+main bios
  • peste
    • Dec 2016
    • 13199
    • ROMANIA
    Re: need dell 7559 daam9amb8d0 ec+main bios
    Originally posted by jaglion19
    Sorry, too much fan noise and still no image
    use the main bios from post # 19, 8MB, together with the 4MB bios posted by you at post # 18.
    • jaglion19
      • Oct 2017
      • 102
      • TURKEY
      Originally posted by peste
      try..
      Need to clean the main bios. When I type main bios in me, there is image after 15 seconds
      • jaglion19
        • Oct 2017
        • 102
        • TURKEY
        The fan turns on in the 8mb you send, there is no image, with the 4mb from you, I have the image with 8mb, but it takes 15 seconds
        • HSBunlock
          • Mar 2021
          • 30
          • UK + PAK
          Hello friends in need Bios and EC of Dell Inspiron 7559 DAAM9API8D0 REV : D
          • eu7abz@tut.by
            • Sep 2018
            • 9
            • Беларусь
            Friends, I ask for help!
            Turns off after exactly 35 minutes. Can I somehow fix this problem by cleaning the ME region?
              • 21457
              Try these, flash both .
              • eu7abz@tut.by
                • Sep 2018
                • 9
                • Беларусь
                #27
                SMDFlea Also, I worked for 35 minutes and turned off. I won't say for sure, maybe 35 minutes or 30 minutes.
                • qayyum786
                  • Aug 2018
                  • 1955
                  • INDIA
                  #28
                  Did you change the CPU ?
                  • eu7abz@tut.by
                    • Sep 2018
                    • 9
                    • Беларусь
                    #29
                    Not
                      • 21457
                      Not
                      Has the PCH been changed
                      • eu7abz@tut.by
                        • Sep 2018
                        • 9
                        • Беларусь
                        #31
                        Also no. The device is not soldered, not filled with moisture. Works properly for exactly 30 minutes.
                          • 21457
                          Can you run this program from the command line and post your result in a text file: MEInfoWin64.exe -verbose
                          https://www.badcaps.net/forum/attach...9&d=1614086876
                          • jimore
                            • Nov 2020
                            • 178
                            • mexico
                            #33
                            tested proven... working for me
                            dell DAAM9AMB8DO REV MODEL:P57F
                            • claudiuccg
                              • Apr 2021
                              • 11
                              • Romania
                              #34
                              for me it's just fan spinning
                              • bilen
                                • Aug 2014
                                • 637
                                • istanbul
                                #35
                                service tag : 3CKT8B2
                                I tried all bios and ec files on the forum
                                Its EC and BIOS have been deleted.
                                Can you share the factory ec and bios for this device?
                                • kalilinux25
                                  • Mar 2018
                                  • 2089
                                  • ZAMBOANGA SIBUGAY
                                  #36
                                  please try and report
                                  • bilen
                                    • Aug 2014
                                    • 637
                                    • istanbul
                                    #37
                                    power on start and 0.50 amp fan full speed no screen.
                                    • borislav1989
                                      • Sep 2022
                                      • bulgaria
                                      #38
                                      i also tried all and none of them worked. on some the fans start spin at max speed right after power is plugin and draw 1.5amp no display , on some after pressing power button power draw 0,40 amp no fan spin no display and im getting ram code from power led 3 white 2 amber when power draw is 1.5amp - not when power draw is 0.4 - ram slots looks ok and ram sticks are tested working
                                      • hopkok
                                        • Oct 2014
                                        • 178
                                        • Slovakia
                                        #39
                                        Masters, anyone able to repair this BIOS?
                                        Stuck at 1,6Amps, no image.
                                        Inspiron 15-7559, daam9amb8d0, rev.D
                                        Intel i7 CPU, Discrete GPU.
                                        With files attached here, I did just 0,6AMps consumtion...
                                        Thank you​
                                        • yucel-yucel
                                          • Dec 2017
                                          • 145
                                          • türkey
                                          #40
                                          My Dell Inspiron 7559 arrived with a faulty hard drive and a swollen battery. I replaced the battery and hard drive. The device shuts down after 30 minutes of powering on. Can anyone help me resolve this issue? I've tried the main and supplemental BIOS solutions on the forum, but they didn't work. I'm attaching my own BIOS backup. When I looked at the device manager, I noticed that the "Intel Management Engine Interface" was missing. I've seen this device on working motherboards. Could this be the cause? I'd love to hear your thoughts.
                                          Mainboard ; DAAM9AMB8D0 Rev D
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • mikeybass
                                            by mikeybass
                                            04-23-2025, 04:30 PM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                            11-02-2024, 04:19 AM
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                          • mrrubik
                                            Dell Optiplex 7010 micro bad BIOS flash?
                                            by mrrubik
                                            Hi folks,
                                            I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                                            After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                                            Steps I took:
                                            1. Read BIOS with CH341a, verified hash twice
                                            2. Patched
                                            12-23-2024, 04:11 PM
