need dell 7559 daam9amb8d0 ec+main bios
Every donation made will go towards server fees and maintenance costs. -
Re: need dell 7559 daam9amb8d0 ec+main bios
The fan turns on in the 8mb you send, there is no image, with the 4mb from you, I have the image with 8mb, but it takes 15 secondsComment
Friends, I ask for help!
Turns off after exactly 35 minutes. Can I somehow fix this problem by cleaning the ME region?Comment
SMDFlea Also, I worked for 35 minutes and turned off. I won't say for sure, maybe 35 minutes or 30 minutes.Comment
Also no. The device is not soldered, not filled with moisture. Works properly for exactly 30 minutes.Comment
https://www.badcaps.net/forum/attach...9&d=1614086876Comment
tested proven... working for me
dell DAAM9AMB8DO REVMODEL:P57F
Attached FilesComment
i also tried all and none of them worked. on some the fans start spin at max speed right after power is plugin and draw 1.5amp no display , on some after pressing power button power draw 0,40 amp no fan spin no display and im getting ram code from power led 3 white 2 amber when power draw is 1.5amp - not when power draw is 0.4 - ram slots looks ok and ram sticks are tested working
Masters, anyone able to repair this BIOS?
Stuck at 1,6Amps, no image.
Inspiron 15-7559, daam9amb8d0, rev.D
Intel i7 CPU, Discrete GPU.
With files attached here, I did just 0,6AMps consumtion...
Thank youComment
My Dell Inspiron 7559 arrived with a faulty hard drive and a swollen battery. I replaced the battery and hard drive. The device shuts down after 30 minutes of powering on. Can anyone help me resolve this issue? I've tried the main and supplemental BIOS solutions on the forum, but they didn't work. I'm attaching my own BIOS backup. When I looked at the device manager, I noticed that the "Intel Management Engine Interface" was missing. I've seen this device on working motherboards. Could this be the cause? I'd love to hear your thoughts.
Mainboard ; DAAM9AMB8D0 Rev DAttached FilesComment
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
by mrrubikHi folks,
I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
Steps I took:- Read BIOS with CH341a, verified hash twice
- Patched
- Loading...
