Asus X550V (X550VX-XX057D) bios Request
  • ramzi2019
    • Apr 2019
    • 56
    • tunisia
    Re: Asus X550V (X550VX-XX057D) bios Request
    Thanks a lot. I'm going to try it.
    • ramzi2019
      • Apr 2019
      • 56
      • tunisia
      Thanks a lot.
      With your help, i restored my previous state (cpu fan, power button,..)
      My original problem was the display but i think this is a graphical problem ( i was dealing with before the bios problem arrive). So back to work
      Take care of yourself
      • asliyucegsm
        • Jun 2011
        • 347
        • Turkiye
        asus x550vx bios
        my friend
        asus x550 vx SR2C4 INTEL CHIPSET draws 0.16 amp after chip replacement Could there be a bios problem?
        thanks
        Bios ClearME
        • lapfix
          • Mar 2020
          • 2750
          • my workshop
          Re: asus x550vx bios
          Try and give feedbak
          • asliyucegsm
            • Jun 2011
            • 347
            • Turkiye
            thanks my friend perfect work
            • asliyucegsm
              • Jun 2011
              • 347
              • Turkiye
              #26
              ASUS X550VX clean me
              my friend
              asus
              x550vx rev.2.0
              25q64
              thanks
              • lapfix
                • Mar 2020
                • 2750
                • my workshop
                #27
                Re: ASUS X550VX clean me
                Try and give feedback
                • asliyucegsm
                  • Jun 2011
                  • 347
                  • Turkiye
                  #28
                  When the button is pressed, the LED is on. 0.06 amp remains.
                  Could there be an IT8995E program error ?
                  my programier Vertyanov
                  Ite has 3v on the legs 26, 50, 92,114, 121 when power is inserted into the motherboard
                  thanks
                  • peste
                    • Dec 2016
                    • 13070
                    • ROMANIA
                    #29
                    thanks
                    bios consisting of the original + update site + clean me..you will not need an EC bios because at Asus when the bios is changed, the EC bios is automatically updated at the first start after the new bios ...
                    • dhan
                      • Jun 2018
                      • 134
                      • hp
                      #30
                      hello heres my bios dump.
                      please help to fix / clean.
                      x550vx rev 2.0
                      • peste
                        • Dec 2016
                        • 13070
                        • ROMANIA
                        #31
                        x550vx rev 2.0
                        try..
                        • ascxc0
                          • Jan 2022
                          • Türkiye
                          #32
                          Originally posted by peste
                          try..
                          Tank you
                          • AlexVG
                            • Apr 2022
                            • 135
                            • SPAIN
                            #33
                            Originally posted by SMDFlea
                            Try this bios.
                            Is it dump OK in case if HUB Cheap was replaced to a new one?
                            Thank you.
                            • Vesko356
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              #34
                              Thank you.
                              It's a redundant question - the file name contain "ME Clean" witch means yes, it's OK for that purpose.
                              Become a Badcaps supporter
                              Thanks to all supporters.​
                              • AlexVG
                                • Apr 2022
                                • 135
                                • SPAIN
                                #35
                                Thank you.
                                It's running but found out another problem:
                                I replaced HUB on ASUS main MB1504 (201) X550VX with i7.
                                And put RTL8821AE wifi module (I attached it. It is ANATEL Combo module) from the same MB1302 (202) X550VX with i5.
                                But it works only in BT mode. MAIN cannot recognise it at all.
                                So, mainboard with i7 processor wears different wifi module (only brand) but with the same RTL8821AE cheap. (I attached it. It is as a AzureWave AW-CB161H module)
                                I guess it's BIOS issue, don't it?
                                Or Is it HUB replaced problem?
                                Or must I use only the same AzureWave AW-CB161H module?
                                Is it possible to change module in BIOS?
                                Thank you for your opinion.
                                • AlexVG
                                  • Apr 2022
                                  • 135
                                  • SPAIN
                                  #36
                                  Hi, I bought AzureWave AW-CB161H module but it gave me nothing. It is another kind of problem(((
                                  • AlexVG
                                    • Apr 2022
                                    • 135
                                    • SPAIN
                                    #37
                                    It was HUB problem. Short circuit in HUB on lines going to AW-CB161H.
                                    I changed HUB twice and its running.
                                    Thank you.
                                    • Renato Ourives
                                      • Jan 2025
                                      • 3
                                      • portugal
                                      #38
                                      Someone has the bios bin file for the ASUS (R510VX-DM236T)?
                                      MB references:
                                      PN:60NB0BB0-MB1504 (201) X550VX
                                      Thank You.
                                      • peste
                                        • Dec 2016
                                        • 13070
                                        • ROMANIA
                                        #39
                                        MB references:
                                        Thank You.
                                        post S/N,post the contents of the bios chip even if it is corrupted..,etc.
                                        • Renato Ourives
                                          • Jan 2025
                                          • 3
                                          • portugal
                                          #40
                                          Hello.
                                          I send all references of MB in the image bellow. I dont have the original bios image because the backup i did came out corrupted.
                                          SN:H1N0CV15W197038
                                          Thanks.
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • skurvysyn
                                          BIOS request - Asus Rog Zephyrus GA503RS - DANJPMB3AA0 Rev. A
                                          by skurvysyn
                                          laptop had dead cpu, 3x UP9030P, audio (5v+3v+MEM short) i replaced all, now laptop turns on, vcore=1.1V, vddnb=1v, vcore_gpu=0,7v, vmem=1.1, vmem_gpu=1,2v, now to not make this a diag req. - just extra info, basically:
                                          original bios not available, dead bios chip, the laptop model is GA503RS, serial: N3NRCX13C597136, equipped originally with ryzen 7 6800HS, rtx 3080 - i replaced cpu, was ballsy, now there is 100-000000544 (i think its ryzen 9 6900HS/HX) - original bios behaviour=laptop turns on, cpu gpu warm, vrms continually get hotter, fan spin lower, gets faster with hotter...
                                          01-08-2025, 04:45 PM
