I need the HP zbook 17 g5 DUMP BIOS, thank you.
  • Swen
    • Sep 2019
    • 19
    • Czech Republic
    #41
    Originally posted by sebulica
    The laptop keeps stalling in the same place.
    This happened after a bios update.
    It does not freeze,but it looks like it waits for a signal or something is returning an error but does not ouput it.
    I've tried to remove everything removable and replace the ram aswell.I don't have a GPU to test with another one,but this one at least outputs video...
    Any suggestions ?
    Plug in the Ethernet and you're good to go. But you mustn't run out of battery somewhere on the go. Then you have to connect again.
    I have the same problem.​
    • sebulica
      Beginner
      • Mar 2014
      • 50
      • Romania
      #42
      Thanks for the suggestions and it worked.The issues seems to be the LAN circuitry.I have not fully investigated it but disabling it from the bios seems to fix the issue with starting up.Now it starts as usual but without lan.The laptop still has issues with the power somewhere as sometimes does not start and reports issues with the board (6 white blinks) but if i leave the power cable connected it starts ok after a while.
      • jozlar
        • Mar 2022
        • 59
        • tbilisi
        #43
        HP ZBOOK 17 G5
        SN : 2TK9500QG5
        Hello, I need help. I flashed several BIOSes and it said HP ENDPOINT SECURITY CONTROLLER PROBLEM and I tried to solve it. Then I flashed one of the BIOSes. And since then it has not changed from white to yellow light and it will not turn on. Please help me. When they brought me the laptop, the old original BIOSes were lost, but I will post what I took out. Maybe you can help me.
        • hoaca388
          Badcaps
          • Jan 2022
          • 12278
          #44
          Originally posted by jozlar
          HP ZBOOK 17 G5
          SN : 2TK9500QG5
          Try
          • Spyeye
            • Oct 2024
            • 3
            • Georgia
            #45
            Originally posted by hoaca388
            Try
            no start bro
            • Spyeye
              • Oct 2024
              • 3
              • Georgia
              #46
              Try
              no starttt
              • Spyeye
                • Oct 2024
                • 3
                • Georgia
                #47
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12278
                  #48
                  Check the very small components around the bios chip pins to see if you have accidentally damaged or lost them.
                  • jozlar
                    • Mar 2022
                    • 59
                    • tbilisi
                    #49
                    Can you post a picture of the resistors and impedances?
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12278
                      #50
                      I don't have any motherboard.
                      • jozlar
                        • Mar 2022
                        • 59
                        • tbilisi
                        #51
                        I don't have any motherboard. It worked, thanks a lot, but 1 problem remains, securty end point, help please
                        • Stunt
                          • Oct 2019
                          • 195
                          • South Africa
                          #52
                          Hi guys i've got hp zbook 17 g5 stuck on protected by hp sure start. The problem i don't have serial number for it came without back cover.
                          I will appreciate if someone can help me and fix my dump. I've attached both bios EC and Main bios
                          • Abu Maha5
                            • Jan 2025
                            Hello i have zbook 17 g5
                            bios Password Not know
                            also bitlocker pls help
                            • peste
                              • Dec 2016
                              • 13451
                              • ROMANIA
                              #54
                              post S/N, full name and model, motherboard model, product number,post the original contents of the bios chip..,etc.
                              • peste
                                • Dec 2016
                                • 13451
                                • ROMANIA
                                #55
                                Don't post pictures unless asked....Write everything you're asked to here...you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                                • Abu Maha5
                                  • Jan 2025
                                  No other way ro delete bitlocker
                                  As reprogram chip
                                  • fastqwert
                                    • Sep 2024
                                    • 3
                                    • bulgaria
                                    #57
                                    Hello, can you help me i need vBios dump of Quadro P3200. Thank you!
                                    • peste
                                      • Dec 2016
                                      • 13451
                                      • ROMANIA
                                      #58
                                      post S/N, full name and model, motherboard model, product number,,etc.
                                      • fastqwert
                                        • Sep 2024
                                        • 3
                                        • bulgaria
                                        #59
                                        There are few things on the GPU that indicates serial numbers.
                                        Replace with HP Spare 30657-001
                                        HB21C1
                                        Model XW3 DAXW3UB5CD0 rev.D
                                        • peste
                                          peste commented
                                          Editing a comment
                                          Look on the label on the laptop case.
                                      • fastqwert
                                        • Sep 2024
                                        • 3
                                        • bulgaria
                                        #60
                                        HB21C1
                                        I dont have HP laptop i want to install the gpu in MSI laptop, i soldered vbios chip tried dell and msi vbios but no luck. I just need a vBios dump from one of you guys. Thank you.
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                          💀 Problem:😅
                                          - Device shows “Administrator Password”...
                                          08-07-2025, 04:54 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • loopster
                                          Need help cleaning ME region on Zbook 17 G1 bios dump
                                          by loopster
                                          Hello guys,
                                          could I please get some help cleaning the ME region of the attached Zbook 17 G1 bios dump (CH341a, neoprogrammer, chip-desoldered, dumped twice, identical checksum)?
                                          Symptoms, delayed BIOS post (ca. 45 secs.) keyboard not working, touchpad not working, booting linux live, console says "Management engine not configured".
                                          I tried following the ME firmware cleaning guide, but whatever Flash Image Tool version I try, I get the same error:
                                          Error 10: Failed to open with processed commands.
                                          Unable to open file: C:\Users\Elitebook...
                                          06-16-2024, 09:57 AM
