Razer RZ09 Bios
    • 21978
    Originally posted by piotr1902
    Hi Everyone.
    I search bios this laptop Razer Blade RZ09-0351G11 I tested different versions bios the laptop is either dead or does not turn on the screen, I found one BIOS version where the laptop works but the touchpad does not work. It has I2C HID Device error code 10
    The working bios is from version RZ09-0328x
    Thread merged. Post your original bios backup and Type and post the laptop serial number .Please read the rules and then you will know what info to post in future https://www.badcaps.net/forum/troubl...before-posting
    • bettabowl
      • Dec 2021
      • 9
      Originally posted by SMDFlea
      Re: Razer RZ09 Bios
      A few more to add .
      RZ09-02385 RZ09-02386
      RZ09-02705 RZ09-02810
      RZ09-02812 RZ09-02886
      RZ09-02887 RZ09-02888
      The RZ09-02888 file is 16 Mb but my chip is only 8 mb. Is there a smaller version of bios available?
      • hoaca388
        Badcaps
        • Jan 2022
        • 12340
        #123
        Your Bios only has 8MB, the remaining 8MB is FF
          • 21978
          Some programmers are very poor at auto-detect , choose the chip manually from the support list. What is your programmer and software version
          • piotr1902
            • Oct 2020
            • 3
            • Poland
            #125
            Hi Everyone.
            I'm still looking for bios and EC Details of the laptop model
            RZ-03519G11 Series no. 6221101M11000216
            The cast that is present is:
            OL510-MB PVT V1.0 board
            CPU - SRH8U
            GPU - N18E - G0- A1
            PCH - SRJAU
            KBC - IT8390E
            The biososcope is W25Q128JVSIQ
            Please help
            • peste
              • Dec 2016
              • 13656
              • ROMANIA
              #126
              Hi Everyone.
              CPU - SRH8U
              GPU - N18E - G0- A1
              PCH - SRJAU
              KBC - IT8390E
              Please help
              you've been told before..post the original bios content..
              • piotr1902
                • Oct 2020
                • 3
                • Poland
                #127
                I don't have the original BIOS version, the spi chip is damaged
                • Titoo73
                  • Nov 2020
                  • 99
                  • buenos aires
                  #128
                  Hi guys, can anyone provide me with the clean bios of RZ-0485? I post my backup and SN. I try to extract from the web but I can't.
                  ​SN: BY2308N30601635
                  thanks!
                    • 21978
                    thanks!
                    check the serial number again please
                    • Titoo73
                      • Nov 2020
                      • 99
                      • buenos aires
                      #130
                      this is BY2308N30601635
                        SMDFlea commented
                        Editing a comment
                        No bios update at razer support,only firmware. Can`t find it anywhere.
                    • rddube
                      Aspiring Expert
                      • Jun 2013
                      • 954
                      Hello friends, need a little help with a Razer model RZ09-01952W71 which is behaving as if it is a bios issue. When I turn it on, the fans spin very quickly about 1 second, then the keyboard goes into a ever changing color pattern and the ready light flashes very slowly green when plugged in and red when on battery. Then fans start spinning and they just spin no post.
                      Attached are the bios files U50 is the main bios I think, I did try another version (in fact 2 other versions that I got in the forums but no luck). U49 is I think EC, and I was able to try another version that SMDFlea uploaded here https://www.badcaps.net/forum/troubl...85#post1406885. I also tried the Bios of that link again no luck. The only Bios I was not able to find an equivalent is U44 @ 1MB, not sure what it does but it might be the culprit and be corrupted?
                      Any help would be most appreciated. Thank you!
                      • volinakis
                        • Jan 2021
                        • 2874
                        • N/A
                        #132
                        post serial no
                        • rddube
                          Aspiring Expert
                          • Jun 2013
                          • 954
                          Originally posted by volinakis
                          post serial no
                          Serial number is BY1648A23700080
                          • volinakis
                            • Jan 2021
                            • 2874
                            • N/A
                            #134
                            use "RZ09-01952" from post 1 and attached EC file. Leave 1Mb chipset alone, is thunderbolt or Vbios.
                            • rddube
                              Aspiring Expert
                              • Jun 2013
                              • 954
                              No unfortunately, same behavior. A burst of fan spinning this time, with merry go round of keyboard colors, power light green turning off and back on a few times then normal fan spinning, power light still looping and nothing on screen.
                              • rddube
                                Aspiring Expert
                                • Jun 2013
                                • 954
                                Any other ideas tests I could do? Thank you!
                                  • 21978
                                  You can start a new troubleshooting topic about the problem if you want. The bios and EC are both good so..
                                  • andychen
                                    • Jun 2014
                                    • 10
                                    Try this one.
                                    The bios from that post didn't turn on for me.
                                    Model: Razer Blade 15" Advanced (2022) | RZ09-0421PED3
                                    Motherboard: APF21006_MB MP V4.0
                                    Serial : BY2217M77401822
                                    Problem: Turns on no post. Customer said failed bios update
                                    • andychen
                                      • Jun 2014
                                      • 10
                                      Still looking for another bios for rz09-0421 from the above post if anyone has one to try
                                      • andychen
                                        • Jun 2014
                                        • 10
                                        Could someone possibly give me a hand trying to repair this original bios file? I cant seem to find a file for this model that will stay powered on like the original bios does.
                                        • vinaypundith
                                          Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                          by vinaypundith
                                          I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                          So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                          08-03-2024, 12:32 PM
                                        • 0xx
                                          2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
                                          by 0xx
                                          Hi folks,
                                          My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
                                          What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
                                          I assumed that Windows Update was interrupted due to closing...
                                          09-14-2025, 03:46 PM
                                        • Awdev
                                          Razer Blade 15 (2019) RZ09-03006E92 need BIOS Image
                                          by Awdev
                                          S/N is BY2011A72401766
                                          Full name: RZ09-03006E92-R3U1 Razer Blade 15” (2019) | RZ09-03006
                                          MB Model is: DA530-MB
                                          Dump is below, Laptop can do EC Reset but cannot boot. Suspect its BIOS or EC....
                                          10-18-2025, 02:13 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • gettindabelt
                                          Help find BIOS Chip on Razer Book 13 rz09-0357
                                          by gettindabelt
                                          Hello I have a Razer book model rz09-03571em1 that had a bad bios update a while back that put it out of commission. I have a chip programmer but am having a hard time locating the actual BIOS chip on the motherboard. I already have the BIOS file, but I was wondering if anyone could help me identify the chip or has any information on writing a new BIOS. Pictures of the board will be attached....
                                          08-09-2023, 04:27 PM
