Razer Blade 15 (2019) RZ09-03006E92 need BIOS Image
  • Awdev
    • Feb 2025
    • 12
    • US
    S/N is BY2011A72401766
    Full name: RZ09-03006E92-R3U1 Razer Blade 15” (2019) | RZ09-03006
    MB Model is: DA530-MB
    Dump is below, Laptop can do EC Reset but cannot boot. Suspect its BIOS or EC.
    • 21841
    https://mysupport.razer.com/app/answ...pport-%26-faqs
    https://rzr.to/CaOyK
    Extract the exe with 7-zip , WinRAR or PeaZIP .The 16MB bios image is called DANA3_0103.bin
    • vinaypundith
      Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
      by vinaypundith
      I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
      So, I'm looking for a BIOS dump for this machine - a 16MB one....
      08-03-2024, 12:32 PM
    • Focus2005
      HP OMEN 16-C0114NW – no image after replacing CPU Ryzen 7 5800H with 5 5600H and flashing BIOS
      by Focus2005
      Hello everyone.
      I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...
      05-01-2025, 05:41 AM
    • DynaxSC
      by DynaxSC
      06-14-2024, 03:49 PM
    • Trodrigue
      razer blade stealth 13 2019
      by Trodrigue
      Hi everyone, I'm posting this message for help. I was given a Razer Blade motherboard because many people around me know that I like to tinker or make things with computer salvage.
      The problem with this board is that the person ripped out the keyboard port from the board.
      But in short, it's not a problem in itself because I'm planning to build a console with this motherboard.
      The problem is turning on the card without the keyboard.
      So I'm looking for another way to turn it on, either by
      using the pins or by using the ITE chip ref: IT8320VG-256 1920-DX0 EA07ZB....
      10-02-2025, 10:17 AM
    • grimacelord
      Latitude E6530 - Trouble Extracting BIOS Image From EXE
      by grimacelord
      Hi folks,
      I'm having a hard time extracting this Dell BIOS. I have a Dell Latitude E6530 that has BIOS corruption and I need to reflash with CH341A programmer. I have already taken dumps of both the 4MB and 8MB chips on the motherboard.
      Service tag number for this model is: "JYDWYW1".
      Link to latest BIOS for this Service Tag: https://dl.dell.com/FOLDER05371360M/1/E6530A22.exe
      I have tried:
      • Simply extracting with 7zip
      • PFSExtractor
      • Using "/writeromfile, /writehdrfile, and /writehexfile" commands
      • Check Temp folder
      10-26-2023, 08:15 AM
