Re: Panasonic Toughbook CF-53 Mk3 BIOS Password Removal
The dump that I uploaded
Hi guys! Someone can help me with the problem. CF-53SGV2QMG without BIOS ((I flashed similar bios CF-53 MK3. Now I have a long boot and it is not possible to turn on WI-FI.Leave a comment:
Attached FilesLeave a comment:
i have here also a bios locked.
Can someone unlock it for me?
Thank you.Attached FilesLeave a comment:
@scsi
Unlocked!
Next time do it yourself... It's easy!Attached FilesLeave a comment:
Hello!
Сan you reset the bios password for my dump file (CF-53)?Attached FilesLeave a comment:
@sayedmansoorpuya
Unlocked!Attached FilesLeave a comment:
please remove password panasonic cf 53Attached FilesLeave a comment:
weird. the password for the bios is still thereLeave a comment:
Unlocked:Attached FilesLeave a comment:
thanksAttached FilesLeave a comment:
thanksAttached FilesLast edited by gpatadia; 09-27-2021, 12:53 AM.Leave a comment:
Hi, I have a CF-53 that is also locked,
can someone help me ?Leave a comment:
Hello, I have done what you indicate, and it has worked for me. It asked me for a password to enter the BIOS, and now it no longer asks me for it. Thanks a lot!!!Leave a comment:
Please help me to reset CF-53 password.
What is the procedure?Leave a comment:
Ok, i'll let you know when i receive the pallet. Thank you!Leave a comment:
yes, beware the address changes for each bios.
Search with the keywords "AMITSESetup".(the second often)
I gave you the technique for the supervisor password.
It can have the user's password too.
It is just above if there is a.
It will always start with 5B.
Look at my picture here you will understand.
https://www.badcaps.net/forum/showthread.php?t=88289Leave a comment:
by AquaMan UaHello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...2 Photos
Channel: BIOS Requests ONLY!
by aa10aa10Good day,
I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....-
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM -
by adil12hello everyone, can you please help me to clear the bios password from Panasonic toughbook cf53-as-50de
thank you...-
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM - Loading...
