Panasonic touchbook cf-53 mk2/mk4
  • mobilshok
    • Aug 2018
    • 4
    • Україна
    Hi to all.
    I have two touchbook cf-53, one mk2 the second mk4.
    The bios has a password.
    Help, prompt you successively the process of removing the password.
  • Andrew_R
    Banned
    • Jun 2018
    • 91
    • Poland
    Re: Panasonic touchbook cf-53 mk2/mk4
    Hi.
    Post your dump bios .
    • mobilshok
      • Aug 2018
      • 4
      • Україна
      Originally posted by Andrew_R
      Hi.
      Dump counted Universal BIOS Backup ToolKit 2.0
      • Andrew_R
        Banned
        • Jun 2018
        • 91
        • Poland
        Read full bios via programmer .
        • mobilshok
          • Aug 2018
          • 4
          • Україна
          programmer I bought in China
          how will I read and put out
          thank you now
          • AIR0
            • Sep 2018
            • 4
            • BELGIUM
            You find spi eeprom in motherboard ?
            BR
            • AIR0
              • Sep 2018
              • 4
              • BELGIUM
              dump Bios eeprom25Q128A- Panasonic touchbook cf-53 mk2
              I ask for help in finding a BIOS dump 16mb-
              with
              a known password or without a password.
              Thanks adavance (My chip has broken)
              • AIR0
                • Sep 2018
                • 4
                • BELGIUM
                Re: dump Bios eeprom25Q128A- Panasonic touchbook cf-53 mk2
                with
                ------S O L V E D------
                • kobz
                  • Jan 2019
                  • Ukraine
                  Hello! Could you share the BIOS Dump for Panasonic Toughbook CF-53 MK2
                  • Lukkas
                    • Apr 2012
                    • 7
                    • Slovakia
                    I need too the bios dump for this laptop.
                    Thanks.
                    • nolina
                      • Jan 2019
                      • Lithuania
                      Hi to all,
                      Can someone help me remove the password from my cf-53 mk4 bios? It seems I've tried everything and nothing helps. Thanks in advance!
                      • rioreno
                        • Feb 2009
                        • 540
                        • Indonesia
                        Originally posted by nolina
                        Hi to all,
                        Try this...
                        • nolina
                          • Jan 2019
                          • Lithuania
                          Originally posted by rioreno
                          Try this...
                          It works. Thank you very much!
                          • orteov
                            • Jun 2015
                            • 5
                            • Romania
                            me too need that dump ! Thanks!
                            • adicata2003
                              • Jan 2020
                              • România
                              Hi to all,
                              Can someone help me remove the password from my cf-53 mk2 bios? It seems I've tried everything and nothing helps. Thanks in advance!
                              • peste
                                • Dec 2016
                                • 13853
                                • ROMANIA
                                bios is not ok, half is empty...
                                • adicata2003
                                  • Jan 2020
                                  • România
                                  Hi, and how do I read it. What program to use?
                                  Thanks for understanding.
                                  • peste
                                    • Dec 2016
                                    • 13853
                                    • ROMANIA
                                    you have to remove the bios chip from the motherboard, put it in a programmer (tl866, ch 341, etc), read the bios chip, make a backup, check the copy in the hex program to see if it is right, put the copy here, and someone when they have time will help you ...
                                    • VurdD
                                      • Jan 2020
                                      • Украина
                                      Originally posted by VurdD
                                      Здравствуйте!Та же проблема,нужен биос ,флешка и ноут такие же.Спасибо!
                                      Hello! The same problem, we need a BIOS, a flash drive and a laptop are the same. Thank you!
                                      • afroindustries
                                        • May 2020
                                        • 6
                                        can someone post or pm the requested bios file? thank you. best regards
                                        • BigPete
                                          Panasonic Heatpump Dryer Repair
                                          by BigPete
                                          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                          Unfortunately the whole machine has to come apart to fix it.
                                          I have...
                                          11-01-2025, 06:40 PM
                                        • telpurleith
                                          Panasonic CF53 MK4 CF-532AWZYNG Password locked Bios
                                          by telpurleith
                                          Hello Guys, i have a CF53 MK4 with a locked bios. I wanna ask you if you could help me to remove it. I have read the bios by a programmer. I also tried to delete it by myself with a hex editor but no luck on MK4. I dont know what i am doing wrong.
                                          09-23-2023, 07:31 AM
                                        • AquaMan Ua
                                          by AquaMan Ua
                                          05-17-2025, 09:40 AM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • adil12
                                          Panasonic toughbook cf53-as-50de bios password removal help
                                          by adil12
                                          hello everyone, can you please help me to clear the bios password from Panasonic toughbook cf53-as-50de
                                          thank you...
                                          09-14-2021, 10:39 AM
