HP 15 bs DKL50 LA-E802P
Model 15-bs106na
S/N: CND7487YGP
ProdID: 3DK41EA#ABU
RMN: TPN-C129
Board model number: DKL50 LA-E802P REV 1.0 2017-06-23
Chip BIOS: Winbond 25Q64JVSIQ 1743
I found these:
Feature Byte: 3K6b7B7K7P7WaBapaqasawbhbzcbdUdXdpdqfP.Me
Build ID: 17WW3JLT601#SABU#DABU
MD: 47830480
SPS: 934908-601
Date Code: 7J17C0
I miss them System Board ID, System Board CT Number and UUID šComment
tryAttached FilesComment
Hello good.
The screen went black after updating bios from the hp page.
When I have unzipped the files I get 5 files .bin and I don't know which one to choose.
My laptop is an hp 15-bs127-ns and the s/n: CND8125KMX
I have also received the CH341A usb but I cannot locate the chip on the motherboard either.
Thank you very much, you do an incredible job.āComment
The chip is on the back of the board. I also encountered this problem. I can't understand if this is a trick, to specifically upload an update that breaks the device?
Please help me restore the BIOS after updating via Windows.
Model 15-bs168cl
S/N: CND8086WYR
ProdID: 2NV94UA#ABA
BIOS chip: Gigadevice 25Q64CS1GāAttached FilesLast edited by ShruS; 01-26-2025, 09:23 AM.Comment
Model 15-bs168cl
S/N: CND8086WYR
ProdID: 2NV94UA#ABA
https://www.badcaps.net/forum/troubl...-0#post3496291Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
you have everything you need at post #6....08328
https://www.badcaps.net/forum/troubl...-0#post3496291Comment
also in that post you have the DMI interval..which must be completed..you pass it from the old bios to the new bios...copy-paste use the HxD program enter both bios there, select that interval in both bios and copy-paste..success...Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Thanks for your help, everything worked. You are the best )))Comment
HP 15-bs107 NT
Main board : DKL50 LA-E892P
BIOS : WINbond 25q74jvsiq 1720
Serial number: CND733531P
I need bios software that I can install with the Ch341a device
Hi, I have this notebook with GPU AMD that have black screen
SN: CND75O9101
Can you fix this bios?
ThanksAttached FilesComment
I only have the motherboard, I don't know which model, also the original bios is lost. (M.B: DKL50 LA-E802P Rev: 1.0), CPU: i7-8550U. Can someone give me a bios that works?Comment
The i7-8550U is a Kaby Lake-Uā CPU. Go to that thread that peste linked to above ,download and open each of those bios with with MEAnalyzer and look at the chipset support to narrow down which bios to try.Attached FilesComment
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
Channel: BIOS Requests ONLY!
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by BloodhoundjeHi everyone,
I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
I have desoldered the bios chip (GigaDevice...-
- Loading...
