you can't write the bios chip correctly unless you remove it from the motherboard...you need an SPI programmer..here is a video as an example...https://www.youtube.com/watch?v=DWWigscuQDY
HP 15 bs DKL50 LA-E802P
Every donation made will go towards server fees and maintenance costs. -
Thank you for answering! I'll buy the programming tools soon. However, I don't have desoldering/soldering skills. I'll have to try out ch341a programming with soic8 test clip on the BIOS chip while it still is on the motherboard first.you can't write the bios chip correctly unless you remove it from the motherboard...you need an SPI programmer..here is a video as an example...https://www.youtube.com/watch?v=DWWigscuQDYComment
I managed to flash the Bios in system without removing the chip but the key was to feed external 3V3 (ch341B with test clip). Even though the circuit only draws 40 mA the 3V3 oscillate violently, so simply feed the 3V3 externally and you are good to go.
I would also like to thank all the helpers from this forum. This enabled me to save my laptop myself after a failed BIOS update. I love fixing things and this forum is a gold mine. Keep it up, you're great.😍
No Display Issue .Plz Solve
Model hp 15-bs190od dkl50 la-e802p rev1.0Attached Filesif you find these attachements useful please consider making a small donation to the site
hi try thisAttached Filesif you find these attachements useful please consider making a small donation to the site
Howdy!
I need BIOS for:
model: 15-bs1xx dkl50 la-e802p rev 1.0
motherboard id: 832B
cpu: i5 8250uComment
HI try new file dmi addAttached Filesif you find these attachements useful please consider making a small donation to the site
Thanks for answering! How can I add the dmi file?
Here's my current BIOS configuration and lacks TPM Device, TPM State and other related settings (I got it using HP BCU)Attached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/forum/troubl...22#post3497022
post the S/N, post the original content of the bios chip, etc.Comment
Sorry for not answering soon, I was trying to find a way to copy/dump BIOS bin without programming tools (I don't have them yet - late delivery due to civil unrest protests after political election).
Gladly enough, I found a way. Here it is
Now that I analyzed things thoroughly, that's not the current generic BIOS I'm using now that's the BIOS bin file update that bricked my laptop.Comment
I need BIOS for:
model: 15-bs754tx
Part board : DKL50 LA-E802 Rev.1
Sn: CND8073DJC
thank youAttached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
Model 15-bs106na
S/N: CND7487YGP
ProdID: 3DK41EA#ABU
RMN: TPN-C129
Board model number: DKL50 LA-E802P REV 1.0 2017-06-23
Chip BIOS: Winbond 25Q64JVSIQ 1743
Problem: black screen after bios update
Help me please 😢Attached Filesif you find these attachements useful please consider making a small donation to the site
Thread merged with LA-E802P topic. What you have posted are the bios updates from HP support. What we need in order to help you is your bios backup from the bios chip on the motherboard. To make the backup you will need an SPI bios programmer.
So I messed up, I flashed a BIOS I found online (DKL50 LA-E802P REV 1.0 2017-06-23 216-0867071 BIOS), the PC starts but the model, SN and everything else have changed, how do I make a backup if the chip has been rewritten? 🤦Comment
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by piratiHello everyone,
Product ID: RZ09-0421
Motherboard: CH580
Bios File Size: 32,768 KB
Dear Forum Readers!
!!! MY RAZER BLADE...-
11-24-2025, 05:52 PM -
- Loading...
