hp probook 650 g3
  • anubys
    • Dec 2021
    • 13
    • Hungary
    #41
    Re: hp probook 650 g3
    650 G3 is having issue as Capslock+Numlk flashing 5 times, then fan goes max speed, black screen.
    When I captured bios dump from the bios chip, ME Analyzer got crashed upon tried to read ME info from it, I guess this means, that original BIOS is corrupt? I have attached it anyway as 650_G3_corrupt.zip
    Then I have attempted to clean ME based on dump can be found at #17, and using 11.8.50.3470_COR_LP_C_NPDM_PRD_RGN.bin as ME Region.bin from the repository, then built up a clean BIOS.
    After wrote clean ME BIOS, situation is the same with the laptop.
    Is there a better BIOS dump You could suggest, I can try to flash? (or if I made any mistake while assembled BIOS clean ME?)
    • peste
      • Dec 2016
      • 12262
      • ROMANIA
      #42
      see what motherboard you have... look here on the site for a bios verified by someone else as being ok, with the same motherboard number, and clean the ME region
      • anubys
        • Dec 2021
        • 13
        • Hungary
        #43
        Thanks for the hint!
        MB is: clooney-6050a2860101-mb-a01
        Following BIOS dumps have been tried, same result:
        https://www.badcaps.net/forum/showthread.php?t=74873 post#19
        https://www.badcaps.net/forum/showthread.php?t=89553 post#3
        https://www.badcaps.net/forum/showthread.php?t=76903 post#6
        • eric35
          • Nov 2021
          • 40
          • France
          #44
          Hello all,
          I have a problem with password bios on my 650 g3.
          I have save my bios.
          thank you
          • hoaca388
            Badcaps
            • Jan 2022
            • 11209
            • Viet Nam
            #45
            Originally posted by eric35
            Hello all,
            thank you
            https://www.badcaps.net/forum/showth...ght=rcunlocker
            • eric35
              • Nov 2021
              • 40
              • France
              #46
              Thank you
              • eric35
                • Nov 2021
                • 40
                • France
                #47
                not work for me. my computer 2 bips longs and 2 bips short.
                thanks a lot.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11209
                  • Viet Nam
                  #48
                  thanks a lot.
                  No, RCUnlocker definitely works with your model, check your bios flash process, solder the bios chip to the mainboard...
                  • eric35
                    • Nov 2021
                    • 40
                    • France
                    #49
                    however the flash works. When I read the chip is it correctly written and there is no error during the operation
                    I flashed with my save and there are no beeps on startup
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11209
                      • Viet Nam
                      #50
                      If re-flashing the original file will the device work?
                      • eric35
                        • Nov 2021
                        • 40
                        • France
                        #51
                        Yes
                        • hardware1
                          • Sep 2021
                          • 2897
                          • N/A
                          #52
                          Yes
                          Try this one.
                          all donations are welcome,
                          • eric35
                            • Nov 2021
                            • 40
                            • France
                            #53
                            It’s ok. Thank you brother!! You are the best !
                            • munir100
                              • Dec 2018
                              • 178
                              • uae
                              #54
                              HP 650 G3 NOT SHOW graphic IN BIOS HERE IS BIOS
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11209
                                • Viet Nam
                                #55
                                Originally posted by munir100
                                hp 650 g3 not show graphic in bios here is bios
                                hp 650 g3
                                • ba114
                                  • Feb 2023
                                  Does anyone know how to unlock additional BIOS settings?
                                  i need to change the IRQ on the serial port from 5 to 4 however theres no option to do that in the BIOS.
                                  It seems however that the desktop version of the BIOS does provide that feature.
                                  • zmeutul
                                    • Apr 2018
                                    • 15
                                    • Romania
                                    #57
                                    Can anyone help to fix this dumb, died during update. I tried bios from site, it worked but no dmi information. Original dumb attached
                                    • zmeutul
                                      • Apr 2018
                                      • 15
                                      • Romania
                                      #58
                                      hp probook 650 g3
                                      Can anyone help to fix this dumb? Died during update. I tried bios from site, it worked but no dmi information. Original dumb attached.Thank you
                                      • lapfix
                                        • Mar 2020
                                        • 2581
                                        • my workshop
                                        #59
                                        Try and Give Feedback.
                                        New built+ your DMI + you win key + clean ME
                                        • zmeutul
                                          • Apr 2018
                                          • 15
                                          • Romania
                                          #60
                                          Thank you. I will teste and give feedback
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • TripTop
                                            Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                                            by TripTop
                                            Hi
                                            i have dell latitude E7270 with following symptoms:
                                            - takes long time to restart.
                                            - sometimes powers on and then off
                                            - sometimes while working it just dies,
                                            From googling online bios clean could possible resolve this?
                                            i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                                            As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                                            I reinstall...
                                            09-09-2024, 02:05 PM
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • solomost
                                            need bios dump for HP ProBook 640 G2
                                            by solomost
                                            HI I need bios dump for HP ProBook 640 G2 PLZ☺☺
                                            prblm: black screen caps lock blinking 5 times then fan spening
                                            CT: PFKCT00WB69310 REV : 1.20
                                            motherboard : HSB J Mv-6 94v-0 E89382
                                            03-21-2025, 06:22 AM
                                          • ktcar214
                                            Need help for HP ProBook 445R G6 Secure boot key removal from BIOS dump
                                            by ktcar214
                                            Hello.
                                            I tried to add a custom secure boot key (for secure booting Linux) to my bios, but after this, my laptop bricked. After adding secure boot key (via PowerShell) and enabling secure boot my laptop turns on, shows HP logo, and after 5 seconds it turns off and on, and it repeats forever.
                                            My goal is to either turn off secure boot or remove my custom key from BIOS dump.
                                            I'll attach my bios dump (version R79_011700) from my bios chip 25b127dsig, my keys (PK/KEK/db), and bios dump from another HP ProBook 445R G6(I found it on this forum. URL: https://www.ba...
                                            12-07-2021, 08:57 AM
