I...
Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
hp probook 650 g3
Posted Photos
9 Photos
by Ahari
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by kinojk2Hi, Thanks for all you do here.
I have attached my 16MB dump.
EDIT2: All hardware working fine, I think I just need to update my linux booatloader and all gucci
EDIT:
I can get into bios now! I reflashed as instructed elsewhere. With a minimal POST (just 1 stick of ram , GPU, CPU, no drives) I have loaded into BIOS. I am about to reinstall my other hardware components now.
The clips are such a pain to use, soldering would be a great skill to have.
Thanks for the advice in other threads!
To answer my own question, I didn't...-
03-24-2026, 05:55 AM -
by studdy05Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
Ive got... -
by dragic98Model: Lenovo Yoga Slim 7 15ILL9
Machine Type Model: 83HM
Motherboard ID: LNVNB161216
TLDR: I would like to have the clean BIOS dump file for my laptop model.
Issue: First, my speaker wasn't working/showing up, so I downloaded the recommended BIOS update (from Jan 4, 2026) on Lenovo Support for my laptop. This didn't fix the speaker issue after restarting, so then I shut it down and pressed the power button for 60 seconds to perform a reset. I'm guessing I somehow messed up the BIOS because now the laptop won't turn on even after trying the NOVO button on...-
Channel: BIOS Requests ONLY!
- Loading...
