hp probook 640 g3 BIOS NEEDED
  • bachir2004
    • Feb 2015
    • 439
    • maroc
    I NEDD hp probook 640 g3 clooney-6050a2860101-mb-a01 BIOS DUMP.SOMEONE HAS ALREADY PLAYED WITH THE DUMP.
    • 22035
    Re: hp probook 640 g3 BIOS NEEDED
    Try this one .
    • bachir2004
      • Feb 2015
      • 439
      • maroc
      thanks smdflea same result.i even tried an image made with fit including a new me and a bios from the hp site.
        • 22035
        Thats what i tried too .
        • davidfrank77
          • Sep 2017
          • 21
          Thanks bro working for me.. Little bit late display
          • hani55
            • 104
            • morocco
            help me brother
            i need reset password hp probook 640 g3 clooney-6050a2860101-mb-a01
            • peste
              • Dec 2016
              • 13698
              • ROMANIA
              try..
              • hani55
                • 104
                • morocco
                Originally posted by peste
                try..
                thank you my brother working 100/100
                • ameerrrr
                  • Aug 2015
                  • 42
                  • syria
                  i need clean password hp probook 650 g3 6050a2860101 mb-a01
                  • peste
                    • Dec 2016
                    • 13698
                    • ROMANIA
                    https://www.badcaps.net/forum/showthread.php?t=98539
                    • shybear
                      • Jan 2010
                      • 107
                      Feedback right for this clean dump BIOS.
                      With other NEWBIOS1 machine take a while to start and when I try to install OS machine doen't load files even if SSD or M.2 are seen.
                      I also tried to update BIOS but problem didn't solve.
                      Flashing with your BIOS solved all issues.
                      Thanks!
                      • shybear
                        • Jan 2010
                        • 107
                        hi,
                        I need help to find Feature Byte and build ID number to fill into BIOS information.
                        Searching over the the web its written its possibile to find it on HP Partsurfer but when I insert my s/n machine on fields just appears Feature byte and Build ID!
                        I attach here the backup of orginal BIOS where I think its possibile to see this numbers.
                        With this BIOS machine doesn't start and loop on/off. Thanks.
                        • shybear
                          • Jan 2010
                          • 107
                          Originally posted by shybear
                          hi,
                          Updates: I didn't notice that under the back over on the internal side there is an other label with these codes!
                          Unlucky the label was made bad and the right side has cut 2 caracters of the Feature Bytes.
                          I made several tries with CRC error all the times!
                          Lucky I've here also a Probook 640 G2 with intact label and this code worked even if its not for this machine.
                          • kingkong computers
                            • Sep 2018
                            • 211
                            • pakistan
                            this file no display plz fix my problem
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12361
                              HP ProBook 640 G3 Base Model Notebook PC
                              SERIAL NUMBER : 5CG7350D6S
                              Warning: Your device appears to have a password set, rebuilding the bios file does not remove the password or it will not work. This device has 4 months of warranty left, don't waste it.
                              • shahzad
                                • Jul 2014
                                • 6
                                • pakistan
                                6050a2860101-mb-a01
                                • peste
                                  • Dec 2016
                                  • 13698
                                  • ROMANIA
                                  Originally posted by shahzad
                                  6050a2860101-mb-a01
                                  • JersonP
                                    • Mar 2020
                                    • 30
                                    • mozambique
                                    clean me pleasse
                                    • peste
                                      • Dec 2016
                                      • 13698
                                      • ROMANIA
                                      Originally posted by JersonP
                                      clean me pleasse
                                      try..
                                      • JersonP
                                        • Mar 2020
                                        • 30
                                        • mozambique
                                        thank you
