hp probook 650 g3
  • anubys
    • Dec 2021
    • 13
    • Hungary
    #41
    Re: hp probook 650 g3
    650 G3 is having issue as Capslock+Numlk flashing 5 times, then fan goes max speed, black screen.
    When I captured bios dump from the bios chip, ME Analyzer got crashed upon tried to read ME info from it, I guess this means, that original BIOS is corrupt? I have attached it anyway as 650_G3_corrupt.zip
    Then I have attempted to clean ME based on dump can be found at #17, and using 11.8.50.3470_COR_LP_C_NPDM_PRD_RGN.bin as ME Region.bin from the repository, then built up a clean BIOS.
    After wrote clean ME BIOS, situation is the same with the laptop.
    Is there a better BIOS dump You could suggest, I can try to flash? (or if I made any mistake while assembled BIOS clean ME?)
    • peste
      • Dec 2016
      • 13661
      • ROMANIA
      #42
      see what motherboard you have... look here on the site for a bios verified by someone else as being ok, with the same motherboard number, and clean the ME region
      • anubys
        • Dec 2021
        • 13
        • Hungary
        #43
        Thanks for the hint!
        MB is: clooney-6050a2860101-mb-a01
        Following BIOS dumps have been tried, same result:
        https://www.badcaps.net/forum/showthread.php?t=74873 post#19
        https://www.badcaps.net/forum/showthread.php?t=89553 post#3
        https://www.badcaps.net/forum/showthread.php?t=76903 post#6
        • eric35
          • Nov 2021
          • 45
          • France
          #44
          Hello all,
          I have a problem with password bios on my 650 g3.
          I have save my bios.
          thank you
          • hoaca388
            Badcaps
            • Jan 2022
            • 12354
            #45
            Originally posted by eric35
            Hello all,
            thank you
            https://www.badcaps.net/forum/showth...ght=rcunlocker
            • eric35
              • Nov 2021
              • 45
              • France
              #46
              Thank you
              • eric35
                • Nov 2021
                • 45
                • France
                #47
                not work for me. my computer 2 bips longs and 2 bips short.
                thanks a lot.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12354
                  #48
                  thanks a lot.
                  No, RCUnlocker definitely works with your model, check your bios flash process, solder the bios chip to the mainboard...
                  • eric35
                    • Nov 2021
                    • 45
                    • France
                    #49
                    however the flash works. When I read the chip is it correctly written and there is no error during the operation
                    I flashed with my save and there are no beeps on startup
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12354
                      #50
                      If re-flashing the original file will the device work?
                      • eric35
                        • Nov 2021
                        • 45
                        • France
                        #51
                        Yes
                        • hardware1
                          • Sep 2021
                          • 2948
                          • N/A
                          #52
                          Yes
                          Try this one.
                          all donations are welcome,
                          • eric35
                            • Nov 2021
                            • 45
                            • France
                            #53
                            It’s ok. Thank you brother!! You are the best !
                            • munir100
                              • Dec 2018
                              • 188
                              • uae
                              #54
                              HP 650 G3 NOT SHOW graphic IN BIOS HERE IS BIOS
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12354
                                #55
                                Originally posted by munir100
                                hp 650 g3 not show graphic in bios here is bios
                                hp 650 g3
                                • ba114
                                  • Feb 2023
                                  Does anyone know how to unlock additional BIOS settings?
                                  i need to change the IRQ on the serial port from 5 to 4 however theres no option to do that in the BIOS.
                                  It seems however that the desktop version of the BIOS does provide that feature.
                                  • zmeutul
                                    • Apr 2018
                                    • 17
                                    • Romania
                                    #57
                                    Can anyone help to fix this dumb, died during update. I tried bios from site, it worked but no dmi information. Original dumb attached
                                    • zmeutul
                                      • Apr 2018
                                      • 17
                                      • Romania
                                      #58
                                      hp probook 650 g3
                                      Can anyone help to fix this dumb? Died during update. I tried bios from site, it worked but no dmi information. Original dumb attached.Thank you
                                      • lapfix
                                        • Mar 2020
                                        • 2765
                                        • my workshop
                                        #59
                                        Try and Give Feedback.
                                        New built+ your DMI + you win key + clean ME
                                        • zmeutul
                                          • Apr 2018
                                          • 17
                                          • Romania
                                          #60
                                          Thank you. I will teste and give feedback
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • mkdj
                                            by mkdj
                                            Dear all,
                                            10-19-2025, 04:41 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • studdy05
                                            Bricked HP Probook 450 G7 Bios questions
                                            by studdy05
                                            Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                            Ive got...
                                            07-08-2025, 09:24 PM
                                          • haitham sharabati
                                            [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                            by haitham sharabati
                                            Hello engineers 😀,
                                            I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                            🔧 Device Info:
                                            - Model: HP 15-da2007ne
                                            - Product Number: 8XF55EA#ABV
                                            - Serial Number: CND0338P0D
                                            - CPU: Intel Celeron N4000
                                            - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                            💀 Problem:😅
                                            - Device shows “Administrator Password”...
                                            08-07-2025, 04:54 AM
