eMachines G640 MX25L1606EM2I 12G bios dump
  • soukehal
    • Dec 2012
    • 45
    • Algerie
    Hi guys good day.. please help me.. i need bios dump for my eMachines G640
    here is the board model: eMachines G640
    JE70-DN MB 09929-1 48.4HP01.011
    thanks guys
    • 20807
    Re: eMachines G640 MX25L1606EM2I 12G bios dump
    Try the one here, backup your bios first !
    https://www.badcaps.net/forum/showthread.php?t=47165
    • soukehal
      • Dec 2012
      • 45
      • Algerie
      ok thanks.
      • soukehal
        • Dec 2012
        • 45
        • Algerie
        with this dump the fan turns, but black screen, so it does not work thank you for the link.
          • 20807
          OK, try this one
          • soukehal
            • Dec 2012
            • 45
            • Algerie
            I thank you for the dump, it did not work, wind rotates black screen thank you.
              • 20807
              Try this one, if this doesn`t work then your problem isn`t the bios.
              • soukehal
                • Dec 2012
                • 45
                • Algerie
                thank you again for this dump, it did not work.
                I try it is three rom too.
                JE70D111.ROM
                JE70D115.ROM
                JE70D118.ROM
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  JE70D111.ROM
                  JE70D115.ROM
                  JE70D118.ROM
                  Post your old bios here. maybe someone can fix that.
                  • soukehal
                    • Dec 2012
                    • 45
                    • Algerie
                    I'm lost, I do not save the old bios, thank you
                      • 20807
                      All the bios i found online are a match with the virgin bios from emachines ,they should have worked. Do some tests next if you havn`t done so already. Test with an external monitor , change RAM , remove everything except 1 RAM stick , look for any burnt parts or liquid damage, feel the board for any hot parts.
                      • babanu
                        • Jan 2011
                        • 57
                        I try this bios on laptop packard-bell with motherboard JE70-DN MB,
                        Think you very much.
                        • Habble7
                          by Habble7
                          Suspected Cause:
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
                        • DynaxSC
                          by DynaxSC
                          11-17-2023, 10:56 AM
                        • MDSI
                          HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                          by MDSI
                          I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                          Details:
                          Model : HP OMEN 17-an012nf
                          Motherboard Part Number : DAG3BAMBAF0 REV : F
                          Serial Number (S/N) : 5CD7280D51
                          BIOS chip : Winbond W25Q64VSIQ
                          Programmer : EZP2023+
                          Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                          I already...
                          07-28-2025, 07:11 AM
                        • grimacelord
                          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                          by grimacelord
                          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                          Motherboard model number: DA0PAMB46A1 REV: A
                          Secondary motherboard model number: 0PAB
                          SKU: 685K4UA
                          Serial number is: 5CD3223BJP
                          Recently reflashed this laptop with latest BIOS and once...
                          05-07-2024, 08:06 AM
                        • DynaxSC
                          Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                          by DynaxSC
                          I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                          It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                          I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                          11-06-2022, 05:22 PM
