eMachines G640 MX25L1606EM2I 12G bios dump
  • soukehal
    • Dec 2012
    • 45
    • Algerie
    Hi guys good day.. please help me.. i need bios dump for my eMachines G640
    here is the board model: eMachines G640
    JE70-DN MB 09929-1 48.4HP01.011
    thanks guys
    • 20709
    Re: eMachines G640 MX25L1606EM2I 12G bios dump
    Try the one here, backup your bios first !
    https://www.badcaps.net/forum/showthread.php?t=47165
    • soukehal
      • Dec 2012
      • 45
      • Algerie
      ok thanks.
      • soukehal
        • Dec 2012
        • 45
        • Algerie
        with this dump the fan turns, but black screen, so it does not work thank you for the link.
          • 20709
          OK, try this one
          • soukehal
            • Dec 2012
            • 45
            • Algerie
            I thank you for the dump, it did not work, wind rotates black screen thank you.
              • 20709
              Try this one, if this doesn`t work then your problem isn`t the bios.
              • soukehal
                • Dec 2012
                • 45
                • Algerie
                thank you again for this dump, it did not work.
                I try it is three rom too.
                JE70D111.ROM
                JE70D115.ROM
                JE70D118.ROM
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  JE70D111.ROM
                  JE70D115.ROM
                  JE70D118.ROM
                  Post your old bios here. maybe someone can fix that.
                  • soukehal
                    • Dec 2012
                    • 45
                    • Algerie
                    I'm lost, I do not save the old bios, thank you
                      • 20709
                      All the bios i found online are a match with the virgin bios from emachines ,they should have worked. Do some tests next if you havn`t done so already. Test with an external monitor , change RAM , remove everything except 1 RAM stick , look for any burnt parts or liquid damage, feel the board for any hot parts.
                      • babanu
                        • Jan 2011
                        • 57
                        I try this bios on laptop packard-bell with motherboard JE70-DN MB,
                        Think you very much.
                        • Habble7
                          by Habble7
                          Suspected Cause:
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
                        • DynaxSC
                          by DynaxSC
                          11-17-2023, 10:56 AM
                        • grimacelord
                          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                          by grimacelord
                          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                          Motherboard model number: DA0PAMB46A1 REV: A
                          Secondary motherboard model number: 0PAB
                          SKU: 685K4UA
                          Serial number is: 5CD3223BJP
                          Recently reflashed this laptop with latest BIOS and once...
                          05-07-2024, 08:06 AM
                        • DynaxSC
                          Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                          by DynaxSC
                          I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                          It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                          I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                          11-06-2022, 05:22 PM
                        • TacticalFahrrad
                          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                          by TacticalFahrrad
                          I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                          BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                          06-30-2025, 04:09 AM
