eMachines G640 MX25L1606EM2I 12G bios dump
  • soukehal
    • Dec 2012
    • 45
    • Algerie
    Hi guys good day.. please help me.. i need bios dump for my eMachines G640
    here is the board model: eMachines G640
    JE70-DN MB 09929-1 48.4HP01.011
    thanks guys
    • 22276
    Re: eMachines G640 MX25L1606EM2I 12G bios dump
    Try the one here, backup your bios first !
    https://www.badcaps.net/forum/showthread.php?t=47165
    • soukehal
      • Dec 2012
      • 45
      • Algerie
      ok thanks.
      • soukehal
        • Dec 2012
        • 45
        • Algerie
        with this dump the fan turns, but black screen, so it does not work thank you for the link.
          • 22276
          OK, try this one
          • soukehal
            • Dec 2012
            • 45
            • Algerie
            I thank you for the dump, it did not work, wind rotates black screen thank you.
              • 22276
              Try this one, if this doesn`t work then your problem isn`t the bios.
              • soukehal
                • Dec 2012
                • 45
                • Algerie
                thank you again for this dump, it did not work.
                I try it is three rom too.
                JE70D111.ROM
                JE70D115.ROM
                JE70D118.ROM
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  JE70D111.ROM
                  JE70D115.ROM
                  JE70D118.ROM
                  Post your old bios here. maybe someone can fix that.
                  • soukehal
                    • Dec 2012
                    • 45
                    • Algerie
                    I'm lost, I do not save the old bios, thank you
                      • 22276
                      All the bios i found online are a match with the virgin bios from emachines ,they should have worked. Do some tests next if you havn`t done so already. Test with an external monitor , change RAM , remove everything except 1 RAM stick , look for any burnt parts or liquid damage, feel the board for any hot parts.
                      • babanu
                        • Jan 2011
                        • 61
                        I try this bios on laptop packard-bell with motherboard JE70-DN MB,
                        Think you very much.
                        • Ahari
                          by Ahari
                          I...
                          08-13-2025, 06:12 AM
                        • mkdj
                          by mkdj
                          Dear all,
                          10-19-2025, 04:41 AM
                        • Habble7
                          by Habble7
                          Suspected Cause:
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
                        • haitham sharabati
                          by haitham sharabati
                          Hello engineers 😀,
                          🔧 Device Info:
                          - Model: HP 15-da2007ne
                          - Product Number: 8XF55EA#ABV
                          - Serial Number: CND0338P0D
                          - CPU: Intel Celeron N4000
                          💀 Problem:😅
                          08-07-2025, 04:54 AM
                        • Citymin
                          by Citymin
                          S/N : 5RNK9FFT70...
                          08-05-2025, 05:12 AM
