bios dump elitebook 840 g3
  • prospa
    • Sep 2013
    • 21
    • greece
    #241
    Re: HP ELITEBOOK 840 G3 (6050A2892401-MB-A01) remove Bios password
    Originally posted by peste
    try..
    not working my friend.
    Thats why i need my bios cleared from password not another because it must suit with EC CHIP version
    • peste
      • Dec 2016
      • 12806
      • ROMANIA
      #242
      Try..
      • marcin02152
        • Oct 2014
        • 134
        • Polska
        #243
        try. this is bin generated with HPUnlocker tool. ( https://www.badcaps.net/forum/showpo...43&postcount=1 )
        • prospa
          • Sep 2013
          • 21
          • greece
          #244
          Thanks my friend
          Working great without password
          You are a god!!!!
          Can you explain the way you do it with some link from internet.
          • marcin02152
            • Oct 2014
            • 134
            • Polska
            #245
            I don't do this via the link from internet. @RethoricalCheese posted a proprietary program called "HPUnlocker_v1". The link points to this program. Just use it.
            • byulo
              ECT
              • 87
              • Philippines
              #246
              Re: HP 840 G3 bios needed
              I have the same problem with admin bios password in HP ELITEBOOK 840 G3, can anyone remove the password?
              Attach is my bin with password.
              TIA
              Raul
              • peste
                • Dec 2016
                • 12806
                • ROMANIA
                #247
                Try..
                • byulo
                  ECT
                  • 87
                  • Philippines
                  #248
                  It work.... like a charm kudos to you sir....its a big help for me....
                  again thank you very much....
                  Raul
                  • malek_bh
                    • Mar 2015
                    • 5
                    • alger
                    #249
                    please unlock bios pass , thank you!
                    • peste
                      • Dec 2016
                      • 12806
                      • ROMANIA
                      #250
                      try..
                      • malek_bh
                        • Mar 2015
                        • 5
                        • alger
                        #251
                        It work.
                        • myjunaid
                          • Nov 2019
                          • 32
                          • Spain
                          #252
                          Can some one please remove the password from my original bion file i will really appriciate
                          • peste
                            • Dec 2016
                            • 12806
                            • ROMANIA
                            #253
                            try...
                            • nyeznieka
                              • Nov 2019
                              • 3
                              • US
                              #254
                              hp 840 g3 clean bios needed. uefitool method did not work for me. i could not find the $vss_store block parameter to modify it with clean one. perhaps someone can help me? please and thank you
                              • myjunaid
                                • Nov 2019
                                • 32
                                • Spain
                                #255
                                try...
                                Thank you ,Do I need to give you the 2nd chip file as well or the one you unlocked I just reprogram that and try
                                • peste
                                  • Dec 2016
                                  • 12806
                                  • ROMANIA
                                  #256
                                  try what I sent you..
                                  • myjunaid
                                    • Nov 2019
                                    • 32
                                    • Spain
                                    #257
                                    try...
                                    Thank you very much Peste you are life saver it worked
                                    • omar mokhtar
                                      • Nov 2016
                                      • 38
                                      • egypt
                                      #258
                                      Re: bios dump elitebook 840 g3
                                      i have same problem this file only work its locked
                                      any one can help me
                                      • peste
                                        • Dec 2016
                                        • 12806
                                        • ROMANIA
                                        #259
                                        try...
                                        • omar mokhtar
                                          • Nov 2016
                                          • 38
                                          • egypt
                                          #260
                                          thank u
                                          its work
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            Yesterday, 05:12 AM
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • mediadoctor
                                            Need bios dump HP EliteBook G845 G8 with AMD and Touchscreen support
                                            by mediadoctor
                                            Can you help me upload Bios dump from HP EliteBook 845 G8 with AMD CPU and Touchscreen please 🤝
                                            07-20-2025, 09:38 AM
                                          • Guest
                                            Elitebook 850 G5 BIOS bricked
                                            by Guest
                                            I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                            I assume the BIOS update failed, so I searched for the BIOS chip.
                                            I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                            However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                            Can the corrupted...
                                            03-24-2025, 01:21 AM
