bios dump elitebook 840 g3
  • prospa
    • Sep 2013
    • 21
    • greece
    #241
    Re: HP ELITEBOOK 840 G3 (6050A2892401-MB-A01) remove Bios password
    Originally posted by peste
    try..
    not working my friend.
    Thats why i need my bios cleared from password not another because it must suit with EC CHIP version
    • peste
      • Dec 2016
      • 12555
      • ROMANIA
      #242
      Try..
      • marcin02152
        • Oct 2014
        • 134
        • Polska
        #243
        try. this is bin generated with HPUnlocker tool. ( https://www.badcaps.net/forum/showpo...43&postcount=1 )
        • prospa
          • Sep 2013
          • 21
          • greece
          #244
          Thanks my friend
          Working great without password
          You are a god!!!!
          Can you explain the way you do it with some link from internet.
          • marcin02152
            • Oct 2014
            • 134
            • Polska
            #245
            I don't do this via the link from internet. @RethoricalCheese posted a proprietary program called "HPUnlocker_v1". The link points to this program. Just use it.
            • byulo
              ECT
              • 87
              • Philippines
              #246
              Re: HP 840 G3 bios needed
              I have the same problem with admin bios password in HP ELITEBOOK 840 G3, can anyone remove the password?
              Attach is my bin with password.
              TIA
              Raul
              • peste
                • Dec 2016
                • 12555
                • ROMANIA
                #247
                Try..
                • byulo
                  ECT
                  • 87
                  • Philippines
                  #248
                  It work.... like a charm kudos to you sir....its a big help for me....
                  again thank you very much....
                  Raul
                  • malek_bh
                    • Mar 2015
                    • 5
                    • alger
                    #249
                    please unlock bios pass , thank you!
                    • peste
                      • Dec 2016
                      • 12555
                      • ROMANIA
                      #250
                      try..
                      • malek_bh
                        • Mar 2015
                        • 5
                        • alger
                        #251
                        It work.
                        • myjunaid
                          • Nov 2019
                          • 32
                          • Spain
                          #252
                          Can some one please remove the password from my original bion file i will really appriciate
                          • peste
                            • Dec 2016
                            • 12555
                            • ROMANIA
                            #253
                            try...
                            • nyeznieka
                              • Nov 2019
                              • 3
                              • US
                              #254
                              hp 840 g3 clean bios needed. uefitool method did not work for me. i could not find the $vss_store block parameter to modify it with clean one. perhaps someone can help me? please and thank you
                              • myjunaid
                                • Nov 2019
                                • 32
                                • Spain
                                #255
                                try...
                                Thank you ,Do I need to give you the 2nd chip file as well or the one you unlocked I just reprogram that and try
                                • peste
                                  • Dec 2016
                                  • 12555
                                  • ROMANIA
                                  #256
                                  try what I sent you..
                                  • myjunaid
                                    • Nov 2019
                                    • 32
                                    • Spain
                                    #257
                                    try...
                                    Thank you very much Peste you are life saver it worked
                                    • omar mokhtar
                                      • Nov 2016
                                      • 38
                                      • egypt
                                      #258
                                      Re: bios dump elitebook 840 g3
                                      i have same problem this file only work its locked
                                      any one can help me
                                      • peste
                                        • Dec 2016
                                        • 12555
                                        • ROMANIA
                                        #259
                                        try...
                                        • omar mokhtar
                                          • Nov 2016
                                          • 38
                                          • egypt
                                          #260
                                          thank u
                                          its work
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • Guest
                                            Elitebook 850 G5 BIOS bricked
                                            by Guest
                                            I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                            I assume the BIOS update failed, so I searched for the BIOS chip.
                                            I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                            However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                            Can the corrupted...
                                            03-24-2025, 01:21 AM
                                          • grimacelord
                                            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                            by grimacelord
                                            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                            Motherboard model number: DA0PAMB46A1 REV: A
                                            Secondary motherboard model number: 0PAB
                                            SKU: 685K4UA
                                            Serial number is: 5CD3223BJP
                                            Recently reflashed this laptop with latest BIOS and once...
                                            05-07-2024, 08:06 AM
                                          • DynaxSC
                                            Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                                            by DynaxSC
                                            I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                                            It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                                            I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                                            11-06-2022, 05:22 PM
