asus x751ld bios
  • infoplus
    • Aug 2017
    • 83
    • ALGERIA
    Re: asus x751ld bios
    Any one have a solution Please
    • peste
      • 12601
      • ROMANIA
      try .. if it doesn't work, post pictures with the white stickers on the RAM memory
      • infoplus
        • Aug 2017
        • 83
        • ALGERIA
        thank you for you help
        sadly no working same issue
        • kiwin
          • May 2021
          • 11
          • Russia
          Re: Asus X751LD Black screen
          Bios main and EC.
          • fullls
            • Jul 2021
            • Россия
            I need bios for this model:
            Laptop model: X751LB
            Mainboard: X751LD REV 2.5
            CPU: i5-5200U SR23Y
            GPU: N16S-GT-S-A2
            I think that bioses for X751LD model, X751LD Rev 2.0 not working.
            Could someone help me?
            • qayyum786
              • Aug 2018
              • 1933
              • INDIA
              #26
              post your backup here
              • sourcebf
                • Jul 2016
                • 431
                • N/A
                #27
                hi for all,
                I have the same issu, laptop start without data on screen and consum 0,70 amps, all voltages are presents
                I tried :
                -flashing with dump of this Thread but befor i flash i used ME analyser to confirm compatibility
                - i disable on board ram
                - I clean ME by my self and flash again
                but still thhe same result and no changes are seen
                can someone check my files below thanks in advance
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11620
                  #28
                  Originally posted by sourcebf
                  hi for all,
                  i have the same issu, laptop start without data on screen and consum 0,70 amps, all voltages are presents
                  i tried :
                  -flashing with dump of this thread but befor i flash i used me analyser to confirm compatibility
                  - i clean me by my self and flash again
                  • infoplus
                    • Aug 2017
                    • 83
                    • ALGERIA
                    #29
                    Check Ram voltage value....
                    • sourcebf
                      • Jul 2016
                      • 431
                      • N/A
                      #30
                      Originally posted by hoaca388
                      Thanks bro but same result
                      • sourcebf
                        • Jul 2016
                        • 431
                        • N/A
                        #31
                        ram voltage is good 1.35 v
                        thanks bro
                        • mahlcom
                          • May 2020
                          • 12
                          • algerie
                          #32
                          hi i need bios asus x751ld rev 2.3
                          thnx
                          • peste
                            • 12601
                            • ROMANIA
                            #33
                            thnx
                            read this and post the original bios of the laptop
                            • walid98
                              • Dec 2017
                              • 5
                              • batna
                              #34
                              Hello everyone
                              Please i need bin file for Asus x751ld Rev 2.5
                              BOARD: X751LD REV 2.5
                              problem is only one blink power diode on board
                              this is the original bios bin
                              • peste
                                • 12601
                                • ROMANIA
                                #35
                                Originally posted by walid98
                                Hello everyone
                                try..
                                • durango legrand
                                  • May 2020
                                  • 15
                                  • benin
                                  #36
                                  Re: Need Bios dump for Asus X751LD, Rev 2,5
                                  try...
                                  Tested work 100%
                                  • bumper1
                                    • Jul 2014
                                    • 76
                                    • Poland
                                    #37
                                    Dump from SMDFlea (post #16) works with my MOBO: X751LD Rev: 2.3
                                    i5-5200U + N16S-GT-S-A2
                                    Thanks again!
                                    • luis3
                                      • Aug 2018
                                      • 5
                                      • Poland
                                      #38
                                      Dump from post #35 works on:
                                      Asus R752LN,
                                      MOBO: X751LD Rev. 2.3,
                                      CPU: SR23W,
                                      GPU: N15S-GT-S-A2
                                      THX!
                                      • razor_amd
                                        by razor_amd
                                        12-15-2020, 07:07 PM
                                      • grimacelord
                                        by grimacelord
                                        07-10-2025, 02:52 PM
                                      • throwaway327
                                        by throwaway327
                                        Model No: RC72LA
                                        Serial No: SBNVKD001014459
                                        06-18-2025, 05:52 PM
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
                                      • lrouw84
                                        Asus vivobook s510ua bios changed to x510un
                                        by lrouw84
                                        Hi there,
                                        I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                                        I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                                        01-28-2023, 01:31 PM
