asus x751ld bios
  • infoplus
    • Aug 2017
    • 83
    • ALGERIA
    Re: asus x751ld bios
    Any one have a solution Please
    • peste
      • Dec 2016
      • 13924
      • ROMANIA
      try .. if it doesn't work, post pictures with the white stickers on the RAM memory
      • infoplus
        • Aug 2017
        • 83
        • ALGERIA
        thank you for you help
        sadly no working same issue
        • kiwin
          • May 2021
          • 11
          • Russia
          Re: Asus X751LD Black screen
          Bios main and EC.
          • fullls
            • Jul 2021
            • 4
            • Россия
            I need bios for this model:
            Laptop model: X751LB
            Mainboard: X751LD REV 2.5
            CPU: i5-5200U SR23Y
            GPU: N16S-GT-S-A2
            I think that bioses for X751LD model, X751LD Rev 2.0 not working.
            Could someone help me?
            • qayyum786
              • Aug 2018
              • 1959
              • INDIA
              #26
              post your backup here
              • sourcebf
                • Jul 2016
                • 433
                • N/A
                #27
                hi for all,
                I have the same issu, laptop start without data on screen and consum 0,70 amps, all voltages are presents
                I tried :
                -flashing with dump of this Thread but befor i flash i used ME analyser to confirm compatibility
                - i disable on board ram
                - I clean ME by my self and flash again
                but still thhe same result and no changes are seen
                can someone check my files below thanks in advance
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12441
                  #28
                  Originally posted by sourcebf
                  hi for all,
                  i have the same issu, laptop start without data on screen and consum 0,70 amps, all voltages are presents
                  i tried :
                  -flashing with dump of this thread but befor i flash i used me analyser to confirm compatibility
                  - i clean me by my self and flash again
                  • infoplus
                    • Aug 2017
                    • 83
                    • ALGERIA
                    #29
                    Check Ram voltage value....
                    • sourcebf
                      • Jul 2016
                      • 433
                      • N/A
                      #30
                      Originally posted by hoaca388
                      Thanks bro but same result
                      • sourcebf
                        • Jul 2016
                        • 433
                        • N/A
                        #31
                        ram voltage is good 1.35 v
                        thanks bro
                        • mahlcom
                          • May 2020
                          • 12
                          • algerie
                          #32
                          hi i need bios asus x751ld rev 2.3
                          thnx
                          • peste
                            • Dec 2016
                            • 13924
                            • ROMANIA
                            #33
                            thnx
                            read this and post the original bios of the laptop
                            • walid98
                              • Dec 2017
                              • 5
                              • batna
                              #34
                              Hello everyone
                              Please i need bin file for Asus x751ld Rev 2.5
                              BOARD: X751LD REV 2.5
                              problem is only one blink power diode on board
                              this is the original bios bin
                              • peste
                                • Dec 2016
                                • 13924
                                • ROMANIA
                                #35
                                Originally posted by walid98
                                Hello everyone
                                try..
                                • durango legrand
                                  • May 2020
                                  • 15
                                  • benin
                                  #36
                                  Re: Need Bios dump for Asus X751LD, Rev 2,5
                                  try...
                                  Tested work 100%
                                  • bumper1
                                    • Jul 2014
                                    • 77
                                    • Poland
                                    #37
                                    Dump from SMDFlea (post #16) works with my MOBO: X751LD Rev: 2.3
                                    i5-5200U + N16S-GT-S-A2
                                    Thanks again!
                                    • luis3
                                      • Aug 2018
                                      • 5
                                      • Poland
                                      #38
                                      Dump from post #35 works on:
                                      Asus R752LN,
                                      MOBO: X751LD Rev. 2.3,
                                      CPU: SR23W,
                                      GPU: N15S-GT-S-A2
                                      THX!
                                      • razor_amd
                                        by razor_amd
                                        12-15-2020, 07:07 PM
                                      • pirati
                                        by pirati
                                        10-27-2025, 04:20 PM
                                      • grimacelord
                                        by grimacelord
                                        07-10-2025, 02:52 PM
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
                                      • throwaway327
                                        by throwaway327
                                        Model No: RC72LA
                                        Serial No: SBNVKD001014459
                                        06-18-2025, 05:52 PM
