HP Probook 4540s - BIOS
  • LP_tekh
    • Oct 2015
    • 95
    • Laos
    Re: In dire need of bios bin file for Probook 4540s
    Originally posted by rata@abv.bg
    thanks marcellodj ... you saved my probook
    Can you share the bios file.
    Thanks in advance
    • imranromi
      • Jan 2015
      • 1288
      • Pakistan
      Try this dump if u need.
      4540s.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3607
        • slovakia
        no rom on hp site?
        • samanthban
          • Feb 2014
          • 253
          • Sri lanka
          Originally posted by marcellodj
          mmm sell bios dumps? not a bad idea :-) ... if you click on fb like on the right box i will appreciate..suggest also to friends! ggl seo..
          sigpic
          • joropop
            • Dec 2013
            • 9
            • BULGARIA
            4540s.
            Thank you -work perfect
            • joropop
              • Dec 2013
              • 9
              • BULGARIA
              #26
              *******************[/url]
              Thanks working normali
              • joropop
                • Dec 2013
                • 9
                • BULGARIA
                #27
                with this bios motherboard started and not sees HDD (no bootable device)
                • bilinch
                  • May 2015
                  • 19
                  • Turkey
                  #28
                  Thanks marcellodj.
                  • subroto
                    • Oct 2015
                    • 230
                    • Bangladesh
                    #29
                    HP Probook 4540s working BIOS
                    Happy new year friends....
                    This is working BIOS for HP Probook 4540s UMA version.
                    • 580shahzad
                      • Jan 2012
                      • 61
                      • PAKISTAN
                      #30
                      Re: HP Probook 4540s working BIOS
                      thanks sir
                      • subroto
                        • Oct 2015
                        • 230
                        • Bangladesh
                        #31
                        Originally posted by 580shahzad
                        thanks sir
                        Welcome
                        • electronica
                          • Apr 2014
                          • 87
                          • algeria
                          #32
                          merci . thank you . شكرا . gracias mucho . danke .
                          • Pascal Komlassan
                            • Jan 2017
                            • 809
                            • TOGO
                            #33
                            Good bro
                            • fyaagoub
                              • Dec 2016
                              • 269
                              • maroc
                              #34
                              thanks sir
                              • razu
                                • Jan 2015
                                • 218
                                • Bangladesh
                                #35
                                hp probook 4540s bios file need argent
                                problem : adapter white led continuous flashing......3v,5v,switching volt found.. I flash bios on another file.....after this no 3v,5v only switching volt........
                                I attach old bios file, and board image
                                • razu
                                  • Jan 2015
                                  • 218
                                  • Bangladesh
                                  #36
                                  Re: hp probook 4540s bios file need argent
                                  motherboard other side image
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    #37
                                    Look here
                                    https://www.badcaps.net/forum/showth...t=26725&page=2
                                    • Pascal Komlassan
                                      • Jan 2017
                                      • 809
                                      • TOGO
                                      #38
                                      hp probook 4540s
                                      bios dump of HP Probook 4540s it's clean
                                      • pcanaliz
                                        • Jun 2017
                                        • turkiye
                                        #39
                                        thanks bios
                                        • Pascal Komlassan
                                          • Jan 2017
                                          • 809
                                          • TOGO
                                          #40
                                          Thank's bro
                                          • studdy05
                                            Bricked HP Probook 450 G7 Bios questions
                                            by studdy05
                                            Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                            Ive got...
                                            07-08-2025, 09:24 PM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • Forest79
                                            by Forest79
                                            However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                            07-23-2023, 07:39 AM
                                          • maanee11
                                            Help to get Lenovo BIOS bin file for Thinkpad T560
                                            by maanee11
                                            Hello Everyone,
                                            I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                                            https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                                            In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                                            05-15-2022, 11:59 AM
                                            HP ProBook 4540s 4000 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 4540s can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 4540s boardview and 4540s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ProBook 4540s is accurate,...
                                            09-06-2024, 05:27 AM
