HP Probook 4540s - BIOS
  • servicepcpascani@gmail.co
    replied
    peste thanks for the bin file, but it doesn't work..i think the gpu is dead..
  • peste
    replied
    Originally posted by servicepcpascani@gmail.co
    4540s
    sn 2ce3161dbg
    pn h5v03es#abb
    cpu i7, gpu radeon
    It starts by itself when the power supply is connected, the power LED flashes intermittently, the display doesn't seem to light up at all and doesn't display anything.
    I'm attaching the bin file read from the board.
    try...
    replied
    4540s
    sn 2ce3161dbg
    pn h5v03es#abb
    cpu i7, gpu radeon
  • ivastchip
    replied
    Hi peste, I just checked how the forum is going and I was happy to see that you are still here to help those in need. Congratulations on your tireless work and may God bless you!
  • Bilal@pc
    replied
    Originally posted by String2016
    Re: HP Probook 4540s Charging LED goes Amber color and goes off
    try to flash the bios first try with this dump
    Thinks its OK OK
  • volky70
    replied
    Thanks Peste.
    I
  • peste
    replied
    Originally posted by volky70
    HP ProBook 4540s Notebook PC (Intel i5-3210M)
    SERIAL NUMBER 2CE2461XHW
    PRODUCT NUMBER C5C83EA#AB9
    M/O:000021433783 55.4SI01.038G24502064KS1A
    MB-CT: PCWBF1A2F3O2JG 55.4SI01.038G
    Motherboard Rocky Intel MB 11243-1 48.4SI01.011​
    try..
  • volky70
    replied
  • peste
    replied
    Hi friends.
    HP ProBook 4540s. 683494-601Power Led is blinking. No Start.
    Attached the old BIOS and Data
    post S/N, full name and model, motherboard model, product number,etc.
  • volky70
    replied
    Hi friends.
  • sergio_ua
    replied
    Originally posted by mahmoodjavan
    HP Probook 4540s 683494-001 bios
    683494-001 bios
    Thanks so much!
    replied
    Originally posted by Agris
    I wanted to fix the serial numbers myself, it turned out that the mpm was blocked. I tried to unlock the mpm with various programs, but it didn't work.
    https://www.badcaps.net/forum/troubl...-tool-nbdmifit
  • Agris
    replied
  • Agris
    replied
    Good morning. Thank you very much for your help. My bios worked, I just need to sort out the serial numbers. Could you please correct the serial numbers in my dump, which I would take from my corrupted dump that I sent earlier? Now I will attach the dump that is working. Thank you.
  • peste
    commented on 's reply
    try post #22,29...
  • Agris
    replied
    Lavakar. Thanks, I understand now. But I only have 9 pages. Post #23 is on page 2 and post #23 does not have a bios file attached.
  • peste
    ok.. on this page there is a #number next to each post, to the right of it....this is the post number...bottom right there is the page number..so this is page number 10...now look for the post with #23,30...now do you understand??
  • Agris
    replied
    I don't understand how you can find post #23,30.
  • peste
    Look at this page and think about what I should do to get to that post...
  • Agris
    replied
    Hello, thank you, how to find that post? I'm a new user here.
  • to5it0
    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
    by to5it0
    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
    I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
    This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
    I have opened the laptop and identified the main BIOS chip...
    10-24-2025, 01:35 AM
  • studdy05
    Bricked HP Probook 450 G7 Bios questions
    by studdy05
    Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
    Ive got...
    07-08-2025, 09:24 PM
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
  • maanee11
    Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
    by maanee11
    Hello Everyone,
    I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
    It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
    In the website, you can only see specs etc.
    I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
    Today, 04:08 AM
  • m1ch43lzm
    Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
    by m1ch43lzm
    Hi everyone
    I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
    Programmer models: XGecu TL866II Plus / T48 / T56 / T76
    Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
    There's also an extra OTP Secu.R...
    09-06-2025, 05:47 PM
