HP Probook 4540s - BIOS
  • bokeboke
    • Jul 2021
    • 30
    • Albania
    #101
    Re: HP Probook 4540s - BIOS
    Hi friends i have this original proobook dump bios
    I tryed the uma version bios after removed the big coil on motherboard but still full fan spin..
    • peste
      • Dec 2016
      • 12880
      • ROMANIA
      #102
      try...
      • bokeboke
        • Jul 2021
        • 30
        • Albania
        #103
        Thanks PESTE It worked.. one more thing if I try to use amd graphic does this dump still works?
        THANK YOU GuYS
        • peste
          • Dec 2016
          • 12880
          • ROMANIA
          #104
          THANK YOU GuYS
          I don't know .. try ...
          • kraze
            • Jul 2022
            • 6
            • Ukraine
            #105
            Hi, my first (second) post here.
            I have two similar HP ProBook 4540s-es with Radeon HD graphics on board, one had a dead bios chip. I managed to revive it by dumping an image from the working one with UsbAsp, flashing it to the clean flash chip, and replacing it on the dead one.
            Now the problem that I cannot resolve, is how to replace UUID, SKU and CSN with the proper ones.
            I have replaced the relevant numbers with those proper to the case (UUID left intact), flashed the image, soldered the chip back in place, but the laptop would just blink the power button, as if BIOS is wrong.
            I replaced the old ones with FFFFs and the laptop does boot.
            Also,where can I find an UUID for it, I cannot seem to find it anywhere on the case.
            Dump with cleaned password and serials attached.
            Before you ask me - yes, I have tried NbDmiFit in various uses, but I cannot get MPM unlocked.
            I.e. uefimpmunlock.efi method with various versions gives me some MEFirmware error.
            FSMC.bin -> SMC.bin method just lights up the CapsLock lighgt and does not unlock MPM.
            So, the most sure method would be to replace the serials directly in the binary or , probably, have the MPM bit set to 1 therein, but I could not find any MPM-related stuff in the dump except for the counter and as specified above, the direct replacement of serial to something different to FFFF makes the system unbootable.
            Please provide an advice, method or modify my firmware to make it MPM unlocked.
            Thank you.
            • hoaca388
              Badcaps
              • Jan 2022
              • 11807
              #106
              Post the file before you correct the information to FF
              • kraze
                • Jul 2022
                • 6
                • Ukraine
                #107
                Attached.
                • kraze
                  • Jul 2022
                  • 6
                  • Ukraine
                  #108
                  I posted above, as requested (sorry for bump).
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11807
                    #109
                    Try
                    • kraze
                      • Jul 2022
                      • 6
                      • Ukraine
                      #110
                      Thank you, will try.
                      • kraze
                        • Jul 2022
                        • 6
                        • Ukraine
                        #111
                        Yes, it boots to BIOS now. Also modified the UUID which also works.
                        • umesh
                          • May 2018
                          • 13
                          • sri lanka
                          #112
                          Re: HP Probook 4540s working BIOS
                          Originally posted by subroto
                          Happy new year friends....
                          This is working BIOS for HP Probook 4540s UMA version.
                          clean bios. Thank you.
                          • raajkumar
                            • Mar 2015
                            • 354
                            • Srilanka
                            #113
                            does anyone having Discrete Bios dump for this motherboard. someone worked before on this mb has removed the bios chip.
                            • peste
                              • Dec 2016
                              • 12880
                              • ROMANIA
                              #114
                              post your original bios..
                              • raajkumar
                                • Mar 2015
                                • 354
                                • Srilanka
                                #115
                                don't have old bios. i installed a new bios chip. old chip not found on this board.
                                • megafaith
                                  • Mar 2021
                                  • 10
                                  • nigeria
                                  #116
                                  Re: HP Probook 4540s roadrunner 1.1 12260-1 BIOS Please
                                  Originally posted by lakmal478
                                  Try this , works for me
                                  Thanks to you boss
                                  • iyori20
                                    Banned
                                    • Nov 2018
                                    • 43
                                    • maroc
                                    #117
                                    thanks
                                    • ivastchip
                                      • Mar 2023
                                      • 9
                                      • Bulgaria
                                      #118
                                      HP ProBook 4540s - Corrupted BIOS
                                      I need help with my HP ProBook 4540s BIOS. For some time I have a problem with the BIOS of my HP ProBook 4540s laptop: once or twice a year the laptop does not boot (black screen, fan spins, Caps Lock blinks continuously.) Each time this happens, after several restarts I manage to enter either into the BIOS or in Windows and then I'm able to update (flash) the BIOS by using the 'HP BIOS Update and Recovery' utility.
                                      Half a year ago, the CMOS battery died, and after I replaced it, the laptop no longer wants to start (with and without the battery): black screen and the fan spins at boot (Caps Lock no longer blinks.)
                                      I ordered a BIOS chip (Winbond 25Q64FVSIG) from eBay with pre-installed BIOS for my laptop model as I suspect my BIOS chip itself is deteriorated over time and no longer holds the memory well. Then the nearby computer service soldered the new chip onto the motherboard but with no luck: still the same behavior on startup. I suspect the BIOS on the new chip is not right for my laptop.
                                      So I think to flash the original BIOS to the new chip that is soldered to the motherboard, but I suspect that the original BIOS image is corrupted. That's why I attached it along with the specs of the laptop and I'm asking whoever is able and willing to look at it and fix it if possible. Thanks in advance to everyone who responds to my request!
                                      • peste
                                        • Dec 2016
                                        • 12880
                                        • ROMANIA
                                        #119
                                        Re: HP ProBook 4540s - Corrupted BIOS
                                        Originally posted by ivastchip
                                        I need help with my HP ProBook 4540s BIOS...
                                        try this..
                                        • ivastchip
                                          • Mar 2023
                                          • 9
                                          • Bulgaria
                                          #120
                                          Thank you very much for the quick response!
                                          I will try this image later on today or tomorrow and I'll let you know of the results.
                                          • studdy05
                                            Bricked HP Probook 450 G7 Bios questions
                                            by studdy05
                                            Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                            Ive got...
                                            07-08-2025, 09:24 PM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • Forest79
                                            by Forest79
                                            However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                            07-23-2023, 07:39 AM
                                          • maanee11
                                            Help to get Lenovo BIOS bin file for Thinkpad T560
                                            by maanee11
                                            Hello Everyone,
                                            I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                                            https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                                            In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                                            05-15-2022, 11:59 AM
                                            HP ProBook 4540s Notebook 4000 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 4540s Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 4540s boardview and 4540s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ProBook 4540s...
                                            09-06-2024, 05:27 AM
