HP Probook 4540s - BIOS
  • bokeboke
    • Jul 2021
    • 30
    • Albania
    #101
    Re: HP Probook 4540s - BIOS
    Hi friends i have this original proobook dump bios
    I tryed the uma version bios after removed the big coil on motherboard but still full fan spin..
    • peste
      • Dec 2016
      • 13701
      • ROMANIA
      #102
      try...
      • bokeboke
        • Jul 2021
        • 30
        • Albania
        #103
        Thanks PESTE It worked.. one more thing if I try to use amd graphic does this dump still works?
        THANK YOU GuYS
        • peste
          • Dec 2016
          • 13701
          • ROMANIA
          #104
          THANK YOU GuYS
          I don't know .. try ...
          • kraze
            • Jul 2022
            • 6
            • Ukraine
            #105
            Hi, my first (second) post here.
            I have two similar HP ProBook 4540s-es with Radeon HD graphics on board, one had a dead bios chip. I managed to revive it by dumping an image from the working one with UsbAsp, flashing it to the clean flash chip, and replacing it on the dead one.
            Now the problem that I cannot resolve, is how to replace UUID, SKU and CSN with the proper ones.
            I have replaced the relevant numbers with those proper to the case (UUID left intact), flashed the image, soldered the chip back in place, but the laptop would just blink the power button, as if BIOS is wrong.
            I replaced the old ones with FFFFs and the laptop does boot.
            Also,where can I find an UUID for it, I cannot seem to find it anywhere on the case.
            Dump with cleaned password and serials attached.
            Before you ask me - yes, I have tried NbDmiFit in various uses, but I cannot get MPM unlocked.
            I.e. uefimpmunlock.efi method with various versions gives me some MEFirmware error.
            FSMC.bin -> SMC.bin method just lights up the CapsLock lighgt and does not unlock MPM.
            So, the most sure method would be to replace the serials directly in the binary or , probably, have the MPM bit set to 1 therein, but I could not find any MPM-related stuff in the dump except for the counter and as specified above, the direct replacement of serial to something different to FFFF makes the system unbootable.
            Please provide an advice, method or modify my firmware to make it MPM unlocked.
            Thank you.
            • hoaca388
              Badcaps
              • Jan 2022
              • 12362
              #106
              Post the file before you correct the information to FF
              ​https://www.badcaps.net/donate
              • kraze
                • Jul 2022
                • 6
                • Ukraine
                #107
                Attached.
                • kraze
                  • Jul 2022
                  • 6
                  • Ukraine
                  #108
                  I posted above, as requested (sorry for bump).
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12362
                    #109
                    Try
                    • kraze
                      • Jul 2022
                      • 6
                      • Ukraine
                      #110
                      Thank you, will try.
                      • kraze
                        • Jul 2022
                        • 6
                        • Ukraine
                        #111
                        Yes, it boots to BIOS now. Also modified the UUID which also works.
                        • umesh
                          • May 2018
                          • 13
                          • sri lanka
                          #112
                          Re: HP Probook 4540s working BIOS
                          Originally posted by subroto
                          Happy new year friends....
                          This is working BIOS for HP Probook 4540s UMA version.
                          clean bios. Thank you.
                          • raajkumar
                            • Mar 2015
                            • 354
                            • Srilanka
                            #113
                            does anyone having Discrete Bios dump for this motherboard. someone worked before on this mb has removed the bios chip.
                            • peste
                              • Dec 2016
                              • 13701
                              • ROMANIA
                              #114
                              post your original bios..
                              • raajkumar
                                • Mar 2015
                                • 354
                                • Srilanka
                                #115
                                don't have old bios. i installed a new bios chip. old chip not found on this board.
                                • megafaith
                                  • Mar 2021
                                  • 10
                                  • nigeria
                                  #116
                                  Re: HP Probook 4540s roadrunner 1.1 12260-1 BIOS Please
                                  Originally posted by lakmal478
                                  Try this , works for me
                                  Thanks to you boss
                                  • iyori20
                                    Banned
                                    • Nov 2018
                                    • 43
                                    • maroc
                                    #117
                                    thanks
                                    • ivastchip
                                      • Mar 2023
                                      • 9
                                      • Bulgaria
                                      #118
                                      HP ProBook 4540s - Corrupted BIOS
                                      I need help with my HP ProBook 4540s BIOS. For some time I have a problem with the BIOS of my HP ProBook 4540s laptop: once or twice a year the laptop does not boot (black screen, fan spins, Caps Lock blinks continuously.) Each time this happens, after several restarts I manage to enter either into the BIOS or in Windows and then I'm able to update (flash) the BIOS by using the 'HP BIOS Update and Recovery' utility.
                                      Half a year ago, the CMOS battery died, and after I replaced it, the laptop no longer wants to start (with and without the battery): black screen and the fan spins at boot (Caps Lock no longer blinks.)
                                      I ordered a BIOS chip (Winbond 25Q64FVSIG) from eBay with pre-installed BIOS for my laptop model as I suspect my BIOS chip itself is deteriorated over time and no longer holds the memory well. Then the nearby computer service soldered the new chip onto the motherboard but with no luck: still the same behavior on startup. I suspect the BIOS on the new chip is not right for my laptop.
                                      So I think to flash the original BIOS to the new chip that is soldered to the motherboard, but I suspect that the original BIOS image is corrupted. That's why I attached it along with the specs of the laptop and I'm asking whoever is able and willing to look at it and fix it if possible. Thanks in advance to everyone who responds to my request!
                                      • peste
                                        • Dec 2016
                                        • 13701
                                        • ROMANIA
                                        #119
                                        Re: HP ProBook 4540s - Corrupted BIOS
                                        Originally posted by ivastchip
                                        I need help with my HP ProBook 4540s BIOS...
                                        try this..
                                        • ivastchip
                                          • Mar 2023
                                          • 9
                                          • Bulgaria
                                          #120
                                          Thank you very much for the quick response!
                                          I will try this image later on today or tomorrow and I'll let you know of the results.
                                          • to5it0
                                            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                            by to5it0
                                            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                            I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                            This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                            I have opened the laptop and identified the main BIOS chip...
                                            10-24-2025, 01:35 AM
                                          • studdy05
                                            Bricked HP Probook 450 G7 Bios questions
                                            by studdy05
                                            Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                            Ive got...
                                            07-08-2025, 09:24 PM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • maanee11
                                            Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                                            by maanee11
                                            Hello Everyone,
                                            I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                                            It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                                            In the website, you can only see specs etc.
                                            I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                                            Yesterday, 04:08 AM
                                          • m1ch43lzm
                                            Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                            by m1ch43lzm
                                            Hi everyone
                                            I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                            Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                            Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                            There's also an extra OTP Secu.R...
                                            09-06-2025, 05:47 PM
