ThinkPad T460s NM-A421 BIOS DUMP
  • polytek
    • Dec 2013
    • 496
    • TUNISIA
    hi badcaps friends,
    need this bios please share;
    thanks.
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Re: ThinkPad T460s NM-A421 BIOS DUMP
    try this
  • polytek
    • Dec 2013
    • 496
    • TUNISIA
    Thankyou very much. i will try this
    • Esse
      • Apr 2014
      • 317
      • TOGO
      Try this
      • polytek
        • Dec 2013
        • 496
        • TUNISIA
        Originally posted by Esse
        Try this
        thankyou my friend;
        very nice work.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          which one worked?? please confirm.
          • jasko_jacker
            • Oct 2014
            • 1137
            • italy
            It's the same dump, I remove vinafix to exclude problems with vinafix administrator
            • polytek
              • Dec 2013
              • 496
              • TUNISIA
              Originally posted by jasko_jacker
              try this
              Try this
              thanks for friend jasko_jacker and Esse for helping me in bios; your bios file are working ok on my board rev 3.0 but the problem is password is not removed the laptop is returned to the customer.
              • jasko_jacker
                • Oct 2014
                • 1137
                • italy
                The password, if I remember well, is stored in another chip but if you erase it return an error at start up, there are two solution:
                1- there is a guy on internet that make a right BIN with it's own programm
                2 - substitute BIN file on securiry chip and main bios taked from the same machine
                • v11
                  • May 2016
                  • 44
                  Hello ... after all did someone get the bios password from the T460s i7 generation 6 ?
                  25L12873F
                  THX.
                  • v11
                    • May 2016
                    • 44
                    Can programmer read,write MEC1633 chip? Is MEC1633 programmable ?
                    is there any programming interface for it now?
                    THX
                      • 31020
                      that wont help, the password and other stuff is also in the tpm chip
                      maybe coreboot is the solution
                      • v11
                        • May 2016
                        • 44
                        Thanks, for this model T460s is not yet a file to make it ...
                        br
                        • mnaeempn
                          • Jan 2015
                          • 16
                          • Saudia
                          Aoa friends,
                          T460s BT460 NM-A421 REV:4.0 bios password attach the dump file plz help for patch file thanx
                            • 20898
                            Originally posted by mnaeempn
                            Aoa friends,
                            Already patched - https://www.badcaps.net/forum/showthread.php?t=81573
                            • mnaeempn
                              • Jan 2015
                              • 16
                              • Saudia
                              AOA FRIEN
                              I try this patch but not working machine is not going on
                              • mnaeempn
                                • Jan 2015
                                • 16
                                • Saudia
                                Bro i try this patch but machine is not going on
                                no disply and 5 beep
                                  • 20898
                                  try this one,and follow the instructions in that thread.There might be a switch to press down as well , not sure .
                                  • mnaeempn
                                    • Jan 2015
                                    • 16
                                    • Saudia
                                    SMDFlea is online now Report Post
                                    Thanx bro
                                    For rply but same issue power on but no display after 4 or 5 second machine 5 beeps 2 time and turn off
                                    • Maxpower3
                                      Bad Veteran
                                      • Feb 2018
                                      • 1226
                                      • France
                                      Thanx bro
                                      patched try
                                      • Habble7
                                        by Habble7
                                        Suspected Cause:
                                        Troubleshooting Attempts:
                                        05-22-2025, 07:28 AM
                                      • Joluvillas
                                        Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                                        by Joluvillas
                                        Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                                        06-18-2024, 10:35 PM
                                        Lenovo ThinkPad T460s Grade T1A Notebook T Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad T460s Grade T1A Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T460s Grade T1A boardview and T460s Grade T1A schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-06-2024, 08:47 AM
                                      • Citymin
                                        by Citymin
                                        S/N : 5RNK9FFT70...
                                        Yesterday, 05:12 AM
                                        Lenovo ThinkPad T460s Ultrabook T Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad T460s Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T460s boardview and T460s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                        09-06-2024, 06:38 AM
