ThinkPad T460s NM-A421 BIOS DUMP
  • mnaeempn
    • Jan 2015
    • 16
    • Saudia
    Re: ThinkPad T460s NM-A421 BIOS DUMP
    PATCH TRY BUT SAME ISSUE
    machine on no display 5 beeps 2 time and shut down
    • hopkok
      • Oct 2014
      • 179
      • Slovakia
      Hi masters, my T460s died during BIOS update, so I flashed this one from here, long time to turn ON, cleaned ME region, now starting well, but my LAN port has error message, "can not start" code 10...any ideas? Thank you
      • peste
        • 13566
        • ROMANIA
        do you still have the original bios of the laptop ??? as corrupt as it is? post it here ..
        • hopkok
          • Oct 2014
          • 179
          • Slovakia
          Hi, this is original one.
          • peste
            • 13566
            • ROMANIA
            try..
            • hopkok
              • Oct 2014
              • 179
              • Slovakia
              #26
              Originally posted by peste
              try..
              5 beeps, same as before...
              • peste
                • 13566
                • ROMANIA
                #27
                try..
                • hopkok
                  • Oct 2014
                  • 179
                  • Slovakia
                  #28
                  Hi, no more beeps, but black screen
                  • hopkok
                    • Oct 2014
                    • 179
                    • Slovakia
                    #29
                    try..
                    Hi, do you have some more ideas?
                      • 21845
                      Post a link to the one that is working. The GBE region can be copied out from your backup using UEFITool and edited into the working one using a hex editor.
                      • hotxboy
                        • Feb 2022
                        • 17
                        • Hong Kong
                        #31
                        good bios to use
                        • hopkok
                          • Oct 2014
                          • 179
                          • Slovakia
                          #32
                          This one is fully working, instead of LAN.
                            • 21845
                            Try this .
                            • hopkok
                              • Oct 2014
                              • 179
                              • Slovakia
                              #34
                              Try this .
                              still the same problem, do you have some more ideas? If not, gonna leave like that...big thanks for try to help, to all of you guys
                                • 21845
                                Was the lan working AOK before the bios update,have you tried with linux just to rule out a windows issue
                                • hopkok
                                  • Oct 2014
                                  • 179
                                  • Slovakia
                                  #36
                                  OS newly installed, unit was in docking station connected by LAN, so was working before. I have got one more board here, so the best idea will be test that mobo with this bios and we will see...
                                  • hopkok
                                    • Oct 2014
                                    • 179
                                    • Slovakia
                                    #37
                                    Second motherboad LAN is working well, but if I clean ME region, I got error, code 10...can anyone try to clean this Bios for me? Maybe I did something wrong...
                                    • hopkok
                                      • Oct 2014
                                      • 179
                                      • Slovakia
                                      #38
                                      Guys can anyone clean ME region in Bios above, just to compare if problem persist? Thanks
                                      • Shone77
                                        • Oct 2020
                                        • 26
                                        • Serbia
                                        #39
                                        ThinkPad T460s 2 beeps problem
                                        Hello Friends, can someone help me with this problem:
                                        I have a problem with Lenovo T460s, worked normaly then black screen and only 2 beeps when power on. CPU i7 6600. Tryed some bios from random posts and i'm getting 4 or 5 beeps only. Tryed few memory modules. Nothing helped.
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 12322
                                          #40
                                          guys can anyone clean me region in bios above, just to compare if problem persist? Thanks
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • mkdj
                                            by mkdj
                                            Dear all,
                                            10-19-2025, 04:41 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Joluvillas
                                            Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                                            by Joluvillas
                                            Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                                            06-18-2024, 10:35 PM
                                            Lenovo ThinkPad T460s Grade T1A Notebook T Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad T460s Grade T1A Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T460s Grade T1A boardview and T460s Grade T1A schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 08:47 AM
